Question about Samsung HLN617W 61" Rear Projection HDTV
Smasung 50 Green Screen
I have a samsung 59" dlp tv, everything has been fine until yesterday when I went to turn on the tv. Now i have a green plaid sceen on every input. Any idea were I can shart troubleshooting?
  • 1 more comment
  • ajspop Apr 23, 2008
    I have the same problem with my Samsung 50" DLP. The reseting (holding down the power button while unplugging) has helped but I also have yet to find the cause or solution. I emailed Samsung with pics of the problem and I'll post their response when and if I get one.
  • BSchade May 23, 2008
    I have a Samsung 50" DLP as well and experiencing the same issues with the green screen. I followed the instructions posted (hold down power button while unplugging) and it's now working again without issue. It's only been a few hours back in service but from reading the other posts, I'm sure it will continue. Please let me know when a solution is found. Thanks so much!
  • bill6106 Jul 11, 2008
    After power outage, i get a green (varies) plaid overlay on my picture. Tried resets to no avail on samsung hl-r5067w.
I had a 50" DLP sampson with the green screen problem plus it has a power off problem; meaning the TV shuts off for about 10 seconds then turns back on when watching Hd TV it got to be a problem when if happend about ever half hour. The analog TV stations are the only green screen. You had to unplug TV to get rid of green for short time.
If you feel the back cover of theTV, the cover is hot to the touch, so hot in places to make you **** your hand back from the heat.
I removed the lower back section ( had to unplug all cables from back cover,Don''t forget the power cable) I used my shop vac placed the hose on blow outlet and blew out all the dust inside the set. (DON"T put hose to close to TV's componits!) Next I removed TV's LOWER back cover, found vent in back for the TV"s fan (over the heat sink), marked the back vent then I went to local Electronics store.
I purchased one 115 volt fan , one cord that pluged into fan and other end into eletricial outlet. Locating center of TV fan on TV's back cover
find best location to mount fan. ( I check fan before mounting by plugging it in to wall outlet to find out air flow direction) I wanted the air flow pulling air out of TV. I mounted my fan on outside of TV's cover left and up from THE TV"s FAN CENTER.
Remount TV's cover with fan. Plug in all your cables, plug in power and fan. turn on TV. After I done above proseager After 8 hours of tv bring on no green screens, no power shut down. The back pannel of TV is cold to the touch except the vent for the projecter lamp.
The Fan I used is a Orion coolong Fan (Knight Eletronics) Part number OA92AP-11-1TB total cost: Fan and cord, nuts, washers and & bolts Under $25.00. Not bad even if TV just last another few months
Posted on Mar 20, 2010
  • 1 more comment
  • RIFAT KAYIN Sep 20, 2013
    thanks .1000 times. it works very well. for that reason l love internet.my nightmare is finished with your advise. thanks again.
    I unpluged power source of TV only. that's all .it works again.
    No need other section. First do it and try again.
Apparently this is caused by a surge in yr electricty supply- burns 4 or so IC's and a part called SPF- Samsung dealers can do the repairs for you but since ist power related, its not under warranty.hope this helps
Posted on Jun 10, 2009
If you are using a hdmi cable to a cable providers cable box, it is a firmware issues with the tvs hdmi port. Check with samsung for firmware upgrade for tv.
Posted on Oct 14, 2009
After posting the issue I was reading all the other issues and someone mention resetting the tv by holding the power button and unplugging. It worked to were i can use the tv but the issue of the green screen still comes back about once a week and have to reset. So no, I have not found out what the issue is but found a short term fix. Also found that when the green screen appears that the HD channels are not affected? Haven't done any research yet to narrow down the issue yet.
Posted on Dec 29, 2007
I saw you left a message on my post with the same problem. I haven't had any luck despite posting it on 3 different message boards. I guess I'll have to all a repair service. The only problem is that I live in a fairly small town and the closest authorized repair dealer is over an hour away. Have you had any luck with helping your problem?
Crm123
Posted on Dec 28, 2007
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
SMASUNG DLP 50 HDTV
defininatly the fan that cools the lamps is either not working or going out and needs replaced
Nov 12, 2007 | Samsung DLP HL-P5663W 56" TV
I have a Samsung Hlr5667wax/xaa DLP TV and the screen has gone green/green plaid pattern.
when the color wheel stops the picture will be all over the place. and you will have lines when it starts to fail as its not going fast enough for the picture. wining sound is it wearing out.
May 29, 2017 | Samsung Hlr5667w 56-inch Dlp Hd Tv
Yesterday my 46" dlp samsung
you can not solve this by your self you must have technication to open the set,,,thir must be some thing wrong,may be deg plug had moved from its place
Dec 23, 2010 | Samsung DLP HL-P5663W 56" TV
Green Plaid Screen
Are you able to access the on-screen menus (like brightness/contrast etc)?
If those menus are appearing over the green screen, then it might be a cable or image source problem. I've often seen this green screen when the HDMI encryption between my cable box and my TV gets messed up. Only solution has been to power cycle the cable box.
If you can use something other than an HDMI cable to connect your TV to your picture source, I suggest trying that and seeing if you can get SD channels again. If you do get them back, it was a cable issue. If you still can't get them, contact your cable/satellite provider, see if there's something up with their signal.
May 30, 2009 | Samsung HLP5067W Television
Green Plaid then Vertical Lines, Failure of hard controls, Analog Board?
You are absolutely correct, When anyone complains of vertical lines or bars, the next step is to see if it happens on only digital inputs ( digital board ) , only analog inputs ( analog board ) , or both ( DMD board ) .
Analog board can be purchased at www.partstore.com ,
Jun 04, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Green Plaid screen
had same problem with ours. at end of one year had green problem and service replaced color wheel. know 1 year after starting to have same problem again. I will not buy this brand anymore.
Jan 27, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
SMASUNG DLP 50 HDTV
The ballast that powers the lamp is bad
Oct 12, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung HLN617W 61" Rear Projection HDTV Logo
4,745 people viewed this question
Jerry Greenberg
Jerry Greenberg
