SOURCE: I have a T62 Stanton
Is it connected to a "PHONO" input or something not labeled explicitly for PHONO?
"PHONO" is the only designated connection on an audio device that is literal and exclusive.Nothing but PHONO will work right on it and old-school turntables would require it to preamplify the tiny current produced by a Phono cartridge.
If your unit doesn't have a PHONO connection you will have to get a Phono Preamp to connect between the TT and any Line Level input, like Aux.
eBay always has some... http://shop.ebay.com/?_from=R40&_trksid=p3984.m570.l1311&_nkw=phono+preamp&_sacat=See-All-Categories
SOURCE: stanton turntable: STR8-30 need to
You look at the cartridge, determine its make/model number if visible and web search for that with 'replacement stylus'. There is no way we can tell what is installed on it.
SOURCE: how do i attatch preamp to marantz sr9200 for phono
If you are talking about a phono preamp, take the output rca cables from the turntable, "red and white" plug it into the preamp input, "labled" next take a red and white cable wire male ends, "3 to 6" feet long, and plug the one end in the output of the preamp, "labled" and finally plug the remainder into the AUX input of the Marantz receiver matching the colour codes so the left and right channels don't get mixed up, you now should be good to go.
SOURCE: Stanton T.92 USB power problems
You should return it to where you purchased it from you are entitiled to either your money back or a replacement under law.
Google "Stanton T.60 Turntable cartridge" and sift through the multitude of offerings.
For example:
