To ask another question does the broil work but not bake or are they both not working? have you done a self clean in some models after you have done a self clean there is a fuse at the back of the oven that pops causeing both bake and broil not to work. So it is possible for the control board to be bad usually there are 2 relays on the board one for bake and one for broil when you look at the board... usualy there are 2 red wires going to the relay and the relay is marked bake/broil. check straight across with a volt meter and see if you have voltage after you have selected bake. if you have voltage there you have a bad board if you have no voltage there that means that the realy is closeing and sending voltage to your heaters but before it gets to your heaters it goes to a thermal fuse. you can also check straight at your element and see if you have 240v if you do you have a bad heater. i hopes this helps if you have any other questions pls let me know
My range is electric. Yes, to breaker question
gas or electric? have you flipped your breaker?
