Question about RCA P52812BL 52" Rear Projection Television
RCA HomeTheater blew fuse. Replacing fuse just results in another blown fuse.
What is my next step?
  • RCA Master
  • 8,617 Answers
Check for a shorted horizontal output transistor.
Posted on Jan 31, 2008
2010 Buick Lucerne. AC does not work. Had it serviced. Blowers work. Full of freon. Fuse revealed it was blown. Replaced and blew again. Service tech tried 4-5 times and fuse blew each time.
not much of a service tech that keeps replacing fuses without fixing the fault
It suggests that the ac compressor clutch coil needs replacing
Jul 26, 2018 | Buick Cars & Trucks
F1 Blowing after replacing RCA cable Technics
ability to switch between 110 and 220 voltages. is it set at the wrong setting to power on? why did you need to replace inside wires? maybe something was touching inside and has blown the fuse. see legitimate repair shop.
Sep 11, 2012 | Panasonic Technics Sl-1210 Mk2 Turntable...
Is there a separate fuse for the power locks
There are actually four fuses that are involved with the power door lock circuits on your 1996 Buick LeSabre. There is also an electronic control module, switches, and several other components that can keep your door locks from working. Replacing a blown fuse will only result in another blown fuse if the reason that the fuse blew is not properly diagnosed and repaired.
For more information, please review the following article:
Where's The Fuse?
Apr 13, 2012 | 1996 Buick LeSabre
Sony 6060F blown fuse
hello!
there is a standard procedure for proper replacement of blown fuse: CRT TVs: unplug degaussing coil, replace blown fuse with 2amp fuse and turn on the set. If it works, reconnect degaussing coil, replace the fuse with correct value(5-8) amp, depends on model(see fuse note next to holder). Enjoy the show! If in a process of replacing the blown fuse with 2amp w/o degaussing coil it blows again, forget about the next step. Set need repair. It could be an easy one, replacing 1 or 2 shorted diodes or bridge rectifier, but could be real piece of work if the power supply got "fried". If your knowledge won't go further, than fuse replacement, I'd recommend local TV repair shop.
good luck,
Alex.
Jan 15, 2012 | Televison & Video
I have a 2006 Hitachi Plasma 42HDS69 that will not turn on. When you power up the TV, the fuse blew. Replaced fuse, powered up the TV, could hear relay click in and fuse blew at the same time. Is this...
You have defective power supply board, Are you OK to strip it down and inspect the board? You will either have to replace the board or have it replaced/repaired professionally.
I hope I have been of help
Feb 14, 2011 | Hitachi 42HDS69 42 in. Plasma Television
Maytag washer model LAT9306AAE won't come on - replaced blown fuse in machine & it blew again right away.
Fuses are there to protect from overheating and further damage to the appliance and/or wiring. A blown fuse is seldom ever the root cause of a problem... It is a symptom of a short or overload somewhere else in the circuit.
Check wiring to be sure there are no bare wires showing or shorting out against each other or the frame of the machine. Check that drive and pump motors turn freely (with power cord unplugged).
Your problem is NOT the fuse alone. Replacing it without correcting the root cause will result in yet another blown fuse.
Jan 01, 2010 | Maytag Washing Machines
RCA TV blown fuse
Hi
you have bad Rectifier Diode or Ic regulator.. check first the unregulated power supply before you go to regulated power section! then check,.
Thanks!
Likha
Oct 23, 2008 | RCA F27242GY 27" TV
Have a Toshiba MW24F11 combo tv. Near lightning strike through surge suppressor. Will not turn on. 6.3 amp fuse blown; replace, blew again. Next step, or start looking for replacement. Set is 25...
power surges generally damage diodes and capacitors causing the fuse to blow, any reputable tv shop can repair for a fraction of replacing this set.
Sep 15, 2008 | Televison & Video
Full sound not working
I had the same problem and also traced it back to two of the four 7-amp fuses were blown. I replaced the fuses, but they immediately blew again. I used higher capacity fuses (10 amp) to see how bad the problem was and those blew. Testing the problem a third time with the speakers disconnected yielded the same results.
There's an internal short in the system.
The solution? Don't buy RCA again.
Nov 12, 2007 | RCA RS2656 Shelf System
Televison & Video Logo
77 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
