Question about Brother MFC 4350 All-In-One Laser Printer
Ink Cartridge When we receive a fax, the paper is covered in ink. I've taken the cartridge out and looked at it, looks fine, have no idea what to do. Any ideas?
Most likely there is toner that has spilled inside the machine... try to use canned air and blow out the fax machine.
Posted on May 20, 2008
When fax comes through paper is blank. I've tried 2 different cartridges
Replace the print cartridge
When you notice that the print becomes light or ink low or when install new ink
cartridge appears in the display, replace the print cartridge. The part number for
replacement cartridges is HP 701.
1. Take out a cartridge from its packaging and carefully remove the tape covering the
Hold the cartridge by the colored top or black areas only. Do not touch the copper
2. Press the Access Cartridge button on the control panel.
The cartridge carrier moves to the install position.
1 Access Cartridge
Care and maintenance 45
3. Open the control panel and cartridge compartment cover (it will click and remain
4. Push the cartridge down and remove it.
5. To load the cartridge insert the cartridge as shown below. When the cartridge is
pushed to the back of the cartridge carrier, push the top of the cartridge until it clicks
into place.
If the cartridge moves loosely in the carrier, it has not clicked into place. Repeat this
1 Control panel
2 Cartridge compartment
46 Care and maintenance
Clear jammed documents and paper
6. Close the cartridge compartment cover and control panel.
7. Press Start/Enter.
8. Press 1 for new cartridge, or 2 for the old one.
• When you put in a new cartridge, you must choose 1:New
• When you put in a used cartridge, choose 2:Used. This helps you to check the
correct amount of ink you have left.
TIP: If you mix up several used cartridges, it is not possible to check the correct amount
of remaining ink. Once you have put in a new cartridge, use it until it is completely
Nov 11, 2011 | HP 640 Inkjet Fax Machine
I have a brother intellifax 1840c (which is great, by the way). I need to change the ink cartridge & have no idea how to get into it. Is there a latch or button to help open it? Please help.
1 Close the document support and the document tray.
2 Lift the top cover to the open position until it locks securely into
place. If one or more ink cartridges are empty, for example Black, the
LCD shows Ink Empty Black and Open Cover.
3 Pull the ink cartridge hook toward you and remove the ink
cartridge for the color shown on the LCD.
You can find the procedure on changing the ink cartridges in the user manual, page 12-25.
User Manual can be downloaded:
May 25, 2011 | Brother IntelliFAX 1840C Plain Paper...
How to change ink?
Press print button. Choose replace ink. Ignore this two steps if the display on your printer is Colour Ink is Empty.
Open cover. Press the round side of the ink cartridge holder arm and the holder will pop up. Take out the ink cartridge. Put in the new cartridge and pop the holder arm back by pressing it down.
Remember to remove the seal below the new ink cartridge before replacing it.
Jun 10, 2010 | Brother MFC-3220C Plain Paper Inkjet Fax
My fax won't print, neither faxes nor copies. The paper goes through & it makes sounds like it is printing but nothing on the paper. The machine says the ink level is 6/8. I "aligned" and...
Though the ink level it said was "6 / 8", when I removed the cartridge to examine it looked bone dry empty to me. I replaced the ink cartridge. It works fine, and reports the ink level as "8 / 8".
Sep 09, 2009 | HP 1040 Plain Paper Inkjet Fax
Message: Intall new ink cartridge. Ink Low
When you hear the fax ringing, press the start button. It sounds like you are not set to AUTO RECEIVE
Jan 20, 2009 | HP 1040 Plain Paper Inkjet Fax
move ink cartridge to center
remove ink cartridge
knock off the mountain off dried ink where the ink cartridge normally sits
plug back in
press function 7
tel/dial key slowly 4 times
1 (for off)
look in the bottom of the paper tray and push backstop flush up to the paper
Jan 03, 2009 | Panasonic Panafax UF-333 Plain Paper...
Fax will not print after installation of new cartridge
Look at your NEW print cartridge again, very carefully. I'll bet there's another piece of tape on the bottom of it. That's what happened to me.
Dec 03, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Check Cartridge Error - Sharp UX-B700 Plain Paper Inkjet Fax
I replaced my new $40 cartridge with another new cartridge and it worked.
Feb 23, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Replaced Ink Cartridge
turn fax machine off open cover and put 3 drops of 3 in 1 oil on the the big silver bar the ink cartridges ride along perform alignment and try to recieve fax if this doesnt work clean all the rubber feed rollers with isopropanol alcohol (rubbing alcohol) applied to a microfiber towel then try.
Jan 15, 2008 | HP 1220 Plain Paper Inkjet Fax
It will not print anything
The problem lies with the refilled cartridge. 1.) Try wiping the bottom of the cartridge with a moist paper tower, to clear up any dried ink. 2.) Put cartridge back in and use the "clean nozzle" feature on the fax machine. 3.) If these steps don't work, it is best to take the refilled cartridge back to the place and have them take a look. Sometimes it can be salvaged. WHY: The print-head (bottom part of the cartridge, retangular shaped, where the ink comes out) is blocked, thus the ink isn't able to come through. This is NOT any fault of the ink refilling service, but rather a wear and tear issue with the cartridges. Most refilled cartridges will work perfectly fine and save you a lot of money.
Aug 29, 2006 | Sharp UX B700 Plain Paper Inkjet Fax
Brother MFC 4350 All-In-One Laser Printer Logo
56 people viewed this question
James Cagle
James Cagle
Jim Keysor
