Question about Maytag Neptune MDE5500AY Electric Dryer
I have a neptune maytag dryer with one of the guides inside the drum is loose.
How do I tighten it?
  • maytagmissy Dec 20, 2007
    One of the guides ("teeth") inside has been loose. It finally came apart a little and I see that the screw must be accessed from inside the shell of the dryer. There is a gap under the guide, which has sucked up a few socks!
    How do I get behind the drum?
  • petcobra Dec 31, 2007
    I also have a guide that came off, the other two are still tight in the drum but I would like to screw the guide back on. What steps must I take to do this? I see screws in the front by the lint panel, I assume that's one step. Thanks.
The panel removes from the front, after the doors have been removed. Make sure you unscrew and take off the doors evenly, being careful not to break the clips on the hinge side of the doors. The front panel pops off, and you can gently rotate the drum so you can access the guides from the side opposite the motor. We used a screwdriver and lug wrench to loosen, reposition, and tighten the screws. It took about 30 minutes from start to finish.
Posted on Jan 02, 2008
This is for a Neptune MDE5500AY front loading Dryer.
UNPLUG THE DRYER.
Take the screws out of the white spacers inside the door opening. Remove spacers. Take the screws out of the door hinges. Remove door. Grab the front panel and lift up and pull the top out. The front hinges at the bottom. Lay the front down slightly and then pull the bottom away from the dryer.
To access the drum, you must lift the top. Before you can do this, you must remove the bare metal plate on the back of the dryer that connects the control panel the the main part of the dryer. Just remove the 5 or 6 screws and take the panel off. Then you must remove the 2 screws (one on either side, of the front panel, about 1/3 of the way down from the top of the dryer. These screws fasten two metal hold downs to the front panel, and hook up and outboard through the front part of the dryer top. With the screws out, the hold downs should fall right out. The top of the dryer will now hinge up (top will rotate back on the white plastic hinges). You now have access to the drum and can see where the teeth screw in to the drum from the back side. Roll the drum around with your hand to put the loose tooth on top and replace or tighten the screws. (While you have access, be sure to tighten all the screws on all the teeth.) (Also while the dryer is open, its a good idea to vacuum out any accumulated dust and lint.)
To put stuff back together, reverse the process. Drop the top down and replace the hold downs and screws. Put the metal plate back on the back of the control panel and replace the screws. Put the bottom of the front panel into the pivot points at the bottom of the dryer, and pivot the front up, then drop it down slightly until it snaps into place. Replace the plastic spacers on one side of the door opening, and replace the door hinges on the other side of the door opening using the appropriate screws.
Plug dryer back in.
    Master:
  • 619 Answers
Unplug power cord , open the rear cover the drum are visible.
Posted on Jan 01, 2008
3 Suggested Answers
  • 905 Answers
SOURCE: i have a maytag neptune dryer and the drum is
Why do you say that the drum is loose? Are you able to wobble it by hand? If so, that is evidence of a bad roller that the drum sits on.
If the drum doesn't turn as fast as it did, that is probably a loose belt, which would indicate that the belt tensioner is not working or belt has jumped the tensioner.
Posted on Jun 13, 2010
mc1bean
  • 3053 Answers
SOURCE: loose baffle in my Maytag Neptune MDE5500AY electric dryer
Hello, sheila I was trying to help you out here. I wasgoing back to some customers that asked questions in the past and it appearedthat no one answered them, so I thought I would take some of my personal timeto see if I can help. Here is a link to about everything you want to know aboutyour dryer, from repair to trouble shooting it. If you go to this link andclick around, I am sure you will find out so much about your dryer, you willknow more that the company that made it. Here Is the link for you to click onhttp://home.howstuffworks.com/how-to-repair-a-dryer.htmPlease if this helped you at all, if youcan find the time to rate my help and some kind words written would beappreciated for my free help , I would appreciate it. Here is also my direct link to my own pagesof other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike http://beta.fixya.com/users/mc1bean
Posted on Oct 26, 2011
Fin that tumbles clothing inside dryer coming loose, how can I tighten it?
These fins are usually screwed on from the outside of the drum. If you're up to it this is a simple but time consuming fix. Take the cabinet off the front of the dryer, the top will come off as well. be careful of the wires from the control console, they will stay attached to the dryer. Tighten the tumbler fins on the drum and then re-assemble the cabinet. Typically the screws you need to access are the same used for the door latch and hinges. They go back together easy ........
Feb 14, 2011 | Maytag Neptune MDE7500AY Electric Dryer
Maytag neptune dryer making banging noise on each rotation on the left side facing the front. its almost like a thumping noise what do i need to do please?
The drum baffle screw has unscrewed itself and the head is thumping against the inside top panel. Pull door, lift lid, rotate drum to find screw sticking out and tighten.
Aug 03, 2010 | Maytag MDE5500AYW Electric Dryer
I have a maytag neptune dryer and the drum is loose how do i tighten it?
Jun 13, 2010 | Maytag MDE2400AYW Neptune Electric Dryer
Inside tumbler is loose - how do you tighten
If the tumbler is loose and you can move it from side to side the bearings in the rear of the drum may be going bad. The bearings aren't an expensive part, the job is just time consuming because you need to remove the outer casing of the dryer and take the drum out. The sides of the dryer stay together the front should come straight off and if the top doesn't come straight off it will tip back on hinges so the wires stay intact. You may need two people to replace the bearings once you get the drum off because they are generally screwed in from inside the drum.
May 02, 2010 | Maytag Neptune MDG5500AW Gas Dryer
BAFFLE INSIDE THE DRUM IS LOOSE. HOW DO I TAKE FRONT OF CABINET OFF SO THAT I CAN GET TO OUTSIDE OF DRUM TO TIGHTEN SCREWS HOLDING BAFFLE?
Open the front door where you load the machine.
Look towards the top where the door normaly closes, there ususualy two screws that you can unscrew there.
Once loose the top pannel should come off, which allowes you to remove the front panel with 2 screws as well.
Nov 14, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Paddle inside dryer came loose how do we tighten
You have to open up the dryer to expose the clothes drum. Most paddles are fastened by two or three 1/4" sheet metal screws. Look for your lost screw in the dryer or replace it with the same. Use a drop or two of lock-tite to keep screws in place. Good time also to clean out all lint which can become a fire hazard, replace the drum belt and redo all of the screws.
Oct 15, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Rattle inside dryer drum
remove the front cover and then you can access the top cover screws to open top then you can locate and tighten screws
Jul 27, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Inside of drum baffles coming loose on maytag neptune dryer
Hello.
Remove the door and the plastic pieces on the opposite side. Take the front panel off. There will be one metal bracket on each side holding the top panel down. Remove those brackets and lift the top. Turn the drum where the loose baffle is up top and tighten loose screws or replace missing ones.
Jul 18, 2009 | Dryers
Loose shelf in Maytag Neptune dryer
Hi, UNPLUG the dryer. There are two screws on each side of the door opening. Remove them screws and the front should pull toward you and release.The door can either lift off or remain on. You can reach under the drum and tighten the screws.
I hope this helps you. Please let me know if I can assist you further.
Thanks
Vic
May 31, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer making clanking noise
I had this problem and the cause was a loose screw holding on one of the "paddles" inside the drum. I removed the door, front panel, lifted the top, manually rotated the drum until I saw the screw head which had worked loose and was slapping the side of the dryer. A quick tighten of the screw and the noise was gone.
Jan 10, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
174 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
