Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
My calculator wont let me get off the opening screen
It wont let me use any buttons and the cursor wont move. it is like it is frozen but the cursor blinks
  • kocsenc Feb 01, 2009
    same problem. i turn it on, cursor blinks but no response to any buttons, replaced all batteries.
$10 at most general stores, if you are in the US
Posted on Dec 12, 2007
Why is my calculator frozen?
Is the cursor checkered? If so, there is no more space on the entry line. Use the DEL key to shorten it or clear it. Clear the RAM also.
Jul 19, 2014 | Texas Instruments TI-84 Plus Silver...
My calculator keeps rounding to the tenths place, I read I need to go to mode and change a setting, but I cannot find mode?
I am describing the procedure for the CAS with OS version 2.1 But it should work for your calculator.
  1. Turn calculator ON
  2. Press The HOME (House icon) button.
  3. Press digit key 5 to open Settings and status.
  4. In menu options, select [2:Settings]
  5. Use the arrow (right) to open the submenu options and select [1:General]
  6. The cursor should be on drop down box labeled Display Digits
  7. Use down arrow to open the number display format, and select Float 6 (an appropriate choice most of the time. If you want more digits, set Float 12)
  8. Press [ENTER] or Click to validate your selection.
  9. The drop down box will close.
  10. Use the TAB button to move to another Configuration setting. Pressing the TAB twice will take you to Exponential format.
  11. Use down arrow to unfold the Exponential format menu.
  12. If you do not need Scientific Format, use Normal and validate.
  13. Press TAB several times until cursor reaches OK.
  14. At this point Press ENTER to save Configuration.
  15. This should solve the problem.
As I said, this describes the procedure for OS version 2.1. Once you find out how to enter the setting screen, do as I described above, and do not forget to validate by getting the cursor on OK and validate.
May 01, 2011 | Texas Instruments TI-Nspire Graphic...
My calculator is completely non responsive. When I hit the on button, the calculator cursor comes up but does not blink or allow me to type anything in. I have to hold the on button to keep the cursor...
It sounds as if the batteries are dead. If you are having to hold the power button on to keep the cursor on the screen, that is because the batteries only have enough power to flash a cursor, holding the power key means that the flash is constant. Try changing the batteries, this should solve the problem.
Apr 27, 2011 | Texas Instruments TI-84 Plus Calculator
How do I get my ti-nspire to give me answers in degrees? I have everything set to degrees, yet it spits out the wrong answer.
The following screen captures pertain to TI Nspire OS 2.1
Turn calculator ON. It calculator is not in HOME screen press the HOME button.k24674_32.jpg
Press digit key 5:Settings and status. Select 2:Settings, then 1:General
On sdecond line Angle open the drop down window and select Degree.
Use TAB a few times to move cursor to the OK button. and press ENTER.
Mar 10, 2011 | Texas Instruments Office Equipment &...
I get ERR: DOMAIN everytime I try to inverse a matrix
  1. First, Press the "MATRX" button
  2. Next, enter a matrix into the calculator. To enter a matrix, press the arrow that points to the right two times when the cursor highlights letter "A." This moves the top cursor to "Edit." Press "Enter" to select the "Edit" option.
  3. Next,, enter the matrix's numbers into the matrix on the calculator. Press "Enter" to move the cursor over one column. Press a button that has a dash symbol within parenthesis [( - )] to move down one row. Repeat the steps until the matrix is completed.
  4. Next, Press "2nd" then "Mode" to go back to the home screen. Press "MATRX" to enter the matrix screen again.
  5. Finally, press "Enter" when the cursor highlights matrix "A" then press "[x^ -1]." Your screen should read "[A]^ -1." Press "Enter" again to display the inverse matrix.
    I got this information from
Dec 07, 2010 | Texas Instruments TI-83 Plus Calculator
How do get the determinant from a 4 x 4 matrix
To create the matrix (in case you do not know.)
  1. Press [2nd][X^-1] to access the (MATRIX) menus.
  2. Use the right arrow key to move to the tab [EDIT]
  3. Under tab EDIT, press 1 to name the matrix as [A]
  4. A matrix template opens (default dimensions are 1x1)
  5. Change the dimensions to 4x4: Press digit 4 key and ENTER. Cursor move to 2nd dimension. Type in 4 and press [ENTER] to validate.
  6. The matrix template changes: screen shows a matrix, filled with 0.
  7. Enter the value of each coefficient and press [ENTER]. The cursor move to next coefficient.
  8. After you validate all values, press [2nd][MODE] to (QUIT) the matrix editor.
To calculate the determinant of a matrix that is already defined.
  1. In main calculator screen press [2nd][X^-1] to open the (MATRIX) functions.
  2. Use the right arrow once to highlight the [MATH] menu.
  3. Select [1:det(] and press [ENTER]
  4. The command det( echoes on main screen.
  5. Press [2nd][X^-1] to opent the (Matrix) menus again.
  6. Select the number in list that corresponds to your matrix (presumably 1:[A]) and press [ENTER]
  7. The command line shows det( [A]
  8. Complete the command by closing the parenthesis and pressing [ENTER]
  9. Wait for the result to be displayed.
Nov 01, 2010 | Texas Instruments TI-83 Plus Calculator
Im in the matrix B, but I do not know how to erase the 2x2 off there to start over again?
You can open the memory management program and delete the Matrix B.
  1. Press [2nd][+] to open (MEM)ory management.
  2. Select [2:Mem Mgt/Del..]
  3. Press [5:Matrix]
  4. In the list of Matrices , use the down Arrow to move cursor to the level of Matrix B and press [DEL] to delete it.
  1. Press [2nd][X^-1] to open the (Matrix) editor
  2. Use the right Arrow to highlight [EDIT],
  3. Use the DownArrow to highlight [B] or press [2:[B]]
  4. The editor screen opens, with the cursor blinking on the first dimension
  5. Change the first dimension
  6. Use the right arrow move cursor to the 2nd dimension and change it, then [ENTER]
  7. In the matrix template that opens, type in the values: the old values will not be erased, so make sure you change them if necessary.
May 05, 2010 | Texas Instruments TI-84 Plus Calculator
Dell wireless mouse cursor froze in middle of screen.
Hi, my cursor had frozen on my screen after my grand daughter pressing something. After trying everything I decided to take it to a local computer shop, it was fixed in seconds. He held the arrow tab(below the caps lock tab) and then pressed F9 it worked!!
Hope this will fix your problem
Jul 27, 2009 | Logitech 3-Button Cordless Optical Scroll...
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
840 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
