If you have connected it to a power source and it wont turn on after say 30 mins of charge... then it may well be a collapsed battery. But most times in these situations you get a glimmer of start. Replace battery..
If nothing happens at all, feel the transformer part of the charger ( unless its USB PC type) to see if there is any warmth to indicate it is working. If you have a multi meter place the MM needles on the outer barrel of the plug and the inner and set voltage to 5.5 or ^v if you get a reading then the unit is OK and back to the GPS.
You also need to inspect the input plug to ensure it has not detatched itself from the board. There is no internal fuse or user servicable parts inside, other than the battery. This can be removed and replaced if you are careful when opening it and not lose screws.
It is often better to send it to a Magellan agent to have this done as it then has either 30 days warranty or sometimes 3 months.
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Magellan Roadmate 1200 Car GPS
switch will not turn on when on battry power but will on external power. system settings shows...
(More)
switch will not turn on when on battry power but will on external power. system settings shows battery to be fully charged
i have my unit pluged into the wall to charge and it is telling me it is connected to the USB on the...
(More)
i have my unit pluged into the wall to charge and it is telling me it is connected to the USB on the computer and that i need to follow the instruction on the computer.
i have it plugged into the wall to charge and it says it is USB connected and is askinf=g me to...
(More)
i have it plugged into the wall to charge and it says it is USB connected and is askinf=g me to follow the instructions from the computer. but its not pluged into the computer.
I have a megellan 1200 I lost my car adapter, I tried two different universal 5V, 1 AMP,chargers....
(More)
I have a megellan 1200 I lost my car adapter, I tried two different universal 5V, 1 AMP,chargers. Now all I get is a white screen that says I that the USB port is now connected to a PC. I get no maps, the only thing I get is this screen
