This is very strange and I have to admit, I have not come across a situation where I've seen (or heard about) this degree of intermittent behavior. I've seen a couple of buttons require a bit more pressure to operate and then clear itself up and act up again - with or w/o doing firmware updates, so I do understand your frustration. Your post is already quite old, so I wonder if you were able to find a solution somewhere. In any event, I wanted to tell you that it looks like you have done all of things that I would have recommended and I'm not sure there is anything else to try. You could try jarring the remote a bit by banging it against your hand to see if anything changes (this is the old 'brute force' approach). This may help identify a loose connection somewhere. But, my sense is that it is more software related, since typically when hardware starts to go it does not repair itself and a failing component or solder joint would usually affect a smaller area, not the majority of your buttons, both hard and 'soft'. So, another thing you can try is starting over. Since there is no way for you to initialize the remote back to 'Factory Defaults' or restore the remote with a previous version of the firmware, you could create a new account and add only 1 activity (watch TV) using only 1 device (the TV). Update the remote with this configuration and see if that helps clear it up. If that takes care of the problem, add back your other activities and devices. I hope this is helpful, though I'm not optimistic.
SOURCE: Harmony 880 universal remote
Had same problem. Update software and firmware. It worked for me.
SOURCE: Harmony 880 universal remote re-charging problem
For Battery and charging related problems with the Harmony 880 checkout the following very useful post and thread:
http://dan.langille.org/2005/11/27/harmony-880-remote-battery-problems/
Hope this helps folks with a variety of different issues.
SOURCE: Harmony 880 Logitech tv remote - won't change channels on direct tv
If you have an infrared remote and your Direct Tv remote is using an RF signal then you need to call Direct Tv and they will help you program your DVR to the remote.
SOURCE: Harmony 880 does not change input with Onkyo HT-R520 amplifier
You will either have to use your Onkyo remote to teach the Harmony those functions or try one of the similar model receivers in the Harmony software. I had to chose a similar DVD player in the list in order to get my Harmony to play nice with my DVD player.
SOURCE: Programming Harmony 880 Remote to Mute with CC on Sony Bravia KDL-40W4100
Do you use a Home Theater receiver along with your televison? Are other components, such as a DVD player, VCR, Blu-ray player, etc. connected?
If so, it's possible that the Mute function on your remote is muting the sound from your receiver, and not the TV itself.
If that's the case, you'll need to look at the details of the "default" buttons for your activities, and see whether the Mute function is associated with your TV or your receiver. If it's set for the receiver, you need to change it to be associated with the TV.
