OPTOMA not Optima the later is health care company.
EP729 you forget the EP part? typing?
a 15 year old projector good luck with that.
NO PC stated (make nor model)
no OS stated., windows what? w10?
the PROJ< has an OSD , and remote control ,did you lose that.
RTM free.
https://www.projectorcentral.com/Optoma-EP729.htm
to use the USB port , you need the CUSTOM PC software (now gone)
what is the chance 15 year old software runs on windows 10?
call them and ask them, their web site forgot it existed.
https://www.optoma.com/us/
the maker shows zero support on 15 year old products.
the manual does not cover this software name or usage. (my guess other manuals lost for that)
for USB port. sorry
SOURCE: warning light
HELLO MATE
IVE GOT THE MANUAL AND THAT LIGHT IS YA COOLANT LEVEL IS LOW TOP UP WITH COOLANT RUN FOR 5 MINS SWITCH OFF WAIT A COUPLE MINS THEN START AGAIN
STEVE
SOURCE: HP 6940 will not print
Turn the printer off
Open the back door and
gently turn the paper roller upward until it clicks. Make sure the door is securely closed. Wait a few more minutes then turn the print back on. I hope this helps.
SOURCE: from left hand side 10 keys not working
You might check settings first. The keyboard might be set to a mode where those keys have some function besides notes. Try a master reset and see if hings start working.
If it was working and now those keys don't, a fault has probably developed. There may be problems with connections to the keyboard, or there's been a component failure.
Sometimes getting into these things and accessing the keyboard is a challenge, and it's possible to do more harm than good. If it needs repair, you're probably better off taking the keyboard to a musician's store in your area and asking them to give you an estimate for the work (or to recommend a servicer if they don't do the work themselves).
SOURCE: BMW 318 SE warning light
I drive a 2000 5series and the only light that sounds similar is the radiator low water warning light. worth a check.
Click on the "Start" button in the lower left
corner of your computer screen to open the Start menu so you can change the
mouse sensitivity. Locate the control panel link on the right-hand column of
the Start menu and click on the link.
Wait for the Control Panel manu to open and then locate the
"Search Control Panel" bar at the top of the menu on the the
right-hand side. Type in "mouse" (no quote marks) in the window and
locate the mouse menu at the top, left side of the menu.
Locate the link that says "Change Button Settings"
at the bottom of the mouse menu and click on the link. When the mouse
properties window appears, locate the tabs at the top of the window and find
the one that says "Pointer Options."
Click on the "Pointer Options" window tab and
locate the heading that says "Motion." In the Motion section, find
the slide ajustment bar that is labeled "Slow" on the left side and
"Fast" on the right side of the bar.
Move the bar according to your desired speed and
preferences, and click on the "Apply" button on the lower right-hand
side of the window.
Click the "OK" button on the lower left-hand side
of the window, which will take you back to the default window. Verify that the
mouse sensitivity is according to your needs and readjust if necessary by
repeating these steps.
Good luck
do rate the solution if got help
