Question about HP Pavillion ZV6000 Notebook
My spacebar on my laptop got ripped off
The spacebar gotripped off n it won't snap back on...can u help?
  • ezeboy Dec 13, 2007
    I have a zv6000 HP Pavillion laptop that doesn't power up when the power button is pressed. Do you think that it's a battery problem or something else?
  • microven Mar 21, 2008
    it brike
    Novelist:
  • 188 Answers
Hard to help with a physical problem without being there....The plastic brackets that hold the key on probably broke. I would just buy a used keyboard and install it, they are only about $30 on ebay. here is a link on how to replace it
http://h10032.www1.hp.com/ctg/Manual/c00364919.pdf
For the other guy with the power problem: It is NOT the battery. Does the machine flash any lights when you hit the power button? if the lights flash 3 times then it is not recieving power from your AC adapter.
Try another AC adapter. Be warned these use a unique ac adapter and you cant buy them at most stores, best bet is ebay most dealers and Hp want $50-$100 for them.
Posted on Dec 21, 2007
I got ripped of on my laptop
i paid so much money recently when the laptop was
a 98 the usb dosent work and the laptop online is selling for
so cheap like ying gum
that cheap
i am pissed help wanted
Posted on Jan 09, 2008
How to replace space bar on laptop
Some spacebars have a long wire on the bottom that snaps into two protruding notches on keyboard base plate.
Jul 21, 2014 | Lenovo Computers & Internet
Why does the space bar only have a centre touch point
The reason for this happening is that the metal bar under your spacebar is not properly attached. It's time consuming to properly fix it, but it's an easy fix at that.
All you need to do is remove your spacebar and metal bar (shaped somewhat like a tall C, if held sideways). On the bottom of the spacebar will be approximately 2-3 small clips in which the metal bar will snap into. Once snapped into place, you will want to look at the area where the spacebar goes. There should be two small clips at each end. With the metal bar clipped into the spacebar, you want to place the "ends" of the metal bar under the clips on the keyboard and very carefully place the spacebar into the hole on the keyboard and snap it into place. Now test it out and it should work fine. If not, it's likely that the metal bar came out from under the keyboard clips. The annoying part is snapping the spacebar into place without having the metal piece come out from under those clips, so you may need to perform this task a few times.
Here's an example image...
Jul 22, 2013 | Asus Systems Asus X501A Notebook
My daughter ripped all the keys off of my laptop, some i could snap back on, and others are broken. Can I get replacement parts?
How about if you order your key from a key replacement company. I know a reliable one. They also have video tutorials on how to fix your key. Check out: laptopkey.com
Jan 15, 2010 | Computers & Internet
How to put spacebar back on my laptop
if it is just the spaacebar cover, it should just snap back on, line the snaps up and press down ~ hope this helps
Sep 28, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
I.removed.the.laptops.spacebar.and.i.cannot.get.it.back.in.there.seems. to.be.4.little.pieces.of.white.plastic.and.two.thin.metal.wires.on.the....
The two pieces of metal should snap into small slots on either side. Then you press it straight down so the plastic piece locks into the button on the membrane on the keyboard assembly. Good Luck
Jul 28, 2009 | Acer TravelMate 5720-6462 Notebook
Spacebar on my pc wont snap back on after removal
Looks like something has been spilt down behind the spacebar or much dirt has accumulated in among the keys, or the spring has come unstuck the rebounds the spacebar back to it's original position. You will have to open the back of the notebook and try to assess what's wrong back there. I would asume that your spring has come loose from the spacebar and all that needs to be done is to clip it back into it's position, eithir that or a good clean to get rid of all the sticky matter that is back there.
Jun 02, 2009 | Balance CN6555 Notebook
Took spacebar off to clean up a pop spill...metal bar NOT attatch
There might be a metal wire if it is missing, which snaps to the keyboard, you may need a new keyboard.
If you are unsure, you should probably thake it to your local computer repair shop.
Good Luck.
Mar 15, 2009 | IBM ThinkPad T42 Notebook
Keyboard spacebar sticking
Just solved it, after a bit of tinkering...
the prongs of the floating plastic frame need to sit inside the clips of the spacebar key, you can't just clip it back on with the prongs either up or down. It's fiddly, you need a paperclip or thin screwdriver to do it, but it's stopped the sticking problem.
Oct 25, 2008 | Dell OW7658 (J4624SK8115RT7D50) Keyboard
Spacebar was pulled off
These can be tricky to snap back into place. YOu have to make sure the wire used to help hold the spacebar in place is in correctly before you can snap it back on.
You have to make sure it is on the correct way or you will install it backward and it will look funny and get stuck. If you fail to put it back on correctly you can always use a butterknife or a flathead screwdriver to pop it off and try again.
Are any of the connection parts damaged? Does it still look like it will reconnect?
Dec 11, 2007 | HP Pavillion ZV6000 Notebook
HP Pavillion ZV6000 Notebook Logo
1,536 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
