Question about Acer AL1916W 19" LCD Monitor
Screen resolution I mistakenly bought a wide screen monitor. How do I make it display a picture of normal proportions?
  • Anonymous Dec 13, 2007
    I try almost everything...
I had the same problem. R click INT EXP, Properties, RUN (drop menu) click on Maximize.
Posted on Jun 07, 2009
Try setting the native resolution of the monitor in your Video Card, try 1440 x 900 in 24 bit
Posted on Jan 10, 2008
  • 238 Answers
Hi, try playing with the aspect ratio .. let me know
Cannot get the picture wide
Firstly you have not mentionrd thr Make & Model of your monitor.
Assuming it's a LCD Monitor you could try the following:
Modern monitors have a 'native resolution'. While most LCD monitors can display a wide variety of screen resolutions, the native resolution will always look best, since this is the screen resolution that matches the number of pixels inside the display. Any other screen resolution may look blocky or distorted, since the number of pixels used in the picture will not match the actual number in the display.
You can adjust your computers display resolution easily. For best results with your monitor, you should use the latest display drivers and monitor drivers and run your monitor in its native resolution. For more information on updating your display drivers, see this link.
Also have a look at this video
May 20, 2012 | Computers & Internet
Sony bravia picture to large for screen
Sir press the screen mode button in your remote below input select button, press the screen mode button repeatedly to select smart, 4:3, wide, zoom, or 14:9.
  • Smart- Display conventional 4:3 broadcast with an imitation wide screen effect. The 4:3 picture is stretched to fill the screen.
  • 4:3- Display conventional 4:3 broadcast non-wide screen TV in the correct proportions.
  • Wide- Display wide screen 16:9 broadcast in the correct proportions.
  • Zoom- Display cinemascopic letter box format broadcasts in the correct proportions.
  • 14:9- Display 14:9 broadcasts in the correct proportions. As a result, black border areas are visible on the screen.
Sep 27, 2011 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
The HANNSPREE monitor that I just bought is great except for one thing. As a photographer, the HANNSPREE screen is too wide in relation to the normal photograph sizes. The horizontal linear distortion...
The best way to adjust the screen is to adjust the screen resolution until you get a correctly proportioned image.
First display an image such as a square or a circle on the screen.
Go to Control panel - Display - Settings tab and start with 1024 X 768 screen resolution adjustment
click Apply and the check your image.
Repeat the adjust screen resolution select the next highest screen resolution setting, repeat thia process until you get the best image.
Jan 24, 2011 | Computers & Internet
Acer wide screen monitor 20'' font and images all
Right click on the desktop in a clear area and scroll down to either resolution or properties. From this you can experiment with resolution settings to see which setting best fits your display. After each setting change the computer will ask you if you want to accept the changes, it will give you 15 seconds for each change.
Jun 26, 2010 | Acer AL2016W 20" LCD Monitor
Hi, I was recently given a Samsung Syncmasster 2333sw flat screen monitor that I hooked up to my old Dell Dimension 8200 desktop.The monitor says the optimum resolution is 1920x1080 pixels. The maximum the...
hi bob you should be able to adjust the screen size via the menu on the monitor itself, (Available in Analog mode only) Note When TV signal is input in AV mode ,select “Screen Fit “to adjust vertical position in 0-6 levels. Image Size Note Supplied for the wide models only such as 16:9 or 16:10. You can change the size of the screen displayed on your monitor. PC signals • Auto - The screen is displayed in accordance with the screen aspect ratio of the input signals.• Wide - A full screen is displayed regardless of the screen aspect ratio of the input signals. Note • Signals not available in the standard mode table are not supported.• If the wide screen which is the optimal resolution for the monitor is set on your PC, this function is not performed. AV signals • 4 : 3 - Sets the picture to 4:3 normal mode. • 16 : 9- Sets the picture to 16:9 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • 4 : 3 - Sets the picture to 4:3 normal mode. • Wide-Sets the picture to 16:10 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note • It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • When the panel is of 16:10,the screen size options include “4:3”,”wide “,”Screen fit“.hope this helps
Jun 22, 2010 | Dell Dimension 8200 PC Desktop
I bought new monitor Compaq S1922a and picture stretched horizontal. I have HP intel with Vista. How to adjust VGA to make picture normal?
if the whole image is too long you can adjust it from tthe image driver will be in the right side on the task bar near the programs that are opened all the time ..and named like the video card you are using and usually will display when hoovering the resolution in the resolutions and choose one that fits best...and confirm ..
To adjust just the the picture from the desktop ..right click on the there choose the desktop image ..or change image ..and you will have 3 possibilities for adjusting the picture to ...stretch..and tile.. see them one by one ...if non of the stile will make it visible in a normal way ..then you should change the picture,,and choose a wallpaper that it is in the same form and big enough to fit....
T change a picture on the wallpaper it is enough to right click on it when its opened ..and choose it to be set as wallpaper from the list of tasks...
May 31, 2010 | Computers & Internet
The pictures are too wide all people look fat
You most likely have a wide screen and the screen resolution needs to be adjusted to suit the monitor.
Go to the Control Panel - Display and adjust the screen resolution until you get a normal image and correct screen aspect screen ratio. Start with a screen resolution of 1024X768 and gradually increase it until you get an image that suits your screen.
Oct 01, 2009 | Acer Computers & Internet
I bought a 1600x900 monitor and now pictures are distorted
Your screen's ratio is oriented to playing wide screen formatted movies. Set your screen resolution to a ratio that's more or less 2 to 1 and you'll have a more realistic depiction of people on photos.
Aug 16, 2009 | Samsung SyncMaster 204B (Silver, Black)...
Samsung Syncmaster 551V Display is too wide
You can adjust the monitor picture size settings & position from the menu button on your monitor.
Apr 23, 2009 | SAMTRON 55V 15" CRT Monitor
Widescreen reset
Go to the control panel and click display and reset it the way you want it. You may have to do this everytime you play your game.
Apr 25, 2017 | 3G Technology GEM GL-822A/B 17" Flat Panel...
Acer AL1916W 19" LCD Monitor Logo
164 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
