Question about Microsoft Xbox 360 Console
Xbox 360 overheating
Our xbox 360 keeps overheating every 5 minutes. We have an intercooler on it and it still overheats. Is flashes red rings when it overheats and the screen turns off. Any suggestions on where we can get it fixed, we live in the GTA area, Ontario.
  • 5 Answers
For all crawling the web with this same problem, and taking it back is not an option, you will prob have to take it apart, put new thermal paste on the heat sinks, and put it back together making sure you tighten the little black screws on the back of the case real good, as these will secure the heat sinks tight on the cpu and the gpu, alowing better heat flow. If that doesnt work you can always try and replace the x clamps, and you can also raise the motherboard with erasers, etc there are many vids on youtube for this so good luck all
Posted on Mar 19, 2009
    Problem Solver:
  • 11 Answers
Unfortunately this sounds way to similar to all the people out there who are complaining about their system crashing. Before calling it quits I would check out one last thing, has the protective foil on the heatsink been removed. I read a pretty interesting article out of fan boy that found two consoles had this problem.
If it has been removed then I have the unfortunate job of telling you that you may want to trade it in. Some may suggest the towel trick, but I am not sure how effective it is going to be in this case. Sorry man.
Here is the link to the article if you are interested:
Posted on Mar 06, 2008
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1& follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Xbox 360 its one red ring
A single red ring is an overheating problem. Either get an intercooler, or buy a fan and point it at the x-box to help keep it cool. Final option is to call Microsoft and ask for a repair order
Aug 09, 2010 | Microsoft Xbox 360 Console
Xbox red with 2 red flashing lights
change your thermal pads as well. then overheat your xbox by wrapping it in towels and leaving it for about 20 minutes. let it completely cool and then turn it on again. this should reset the overheat sensor that keeps your xbox from booting
May 06, 2010 | Microsoft Xbox 360 Console
I have three flashing red lights
You have the dreaded red rings of death the only way to fix it is to send it back to micsoft it will be free if you havent had it for less than 3yrs if not you will have to pay 120dollars.
Oct 27, 2009 | Microsoft Xbox 360 Console
Xbox360 show 2 rings
2 rings means overheat
leave it in a cold place for some hours and it should be ok
Oct 21, 2009 | Microsoft Xbox 360 Console
My xbox has 2 red lights it keeps overheating but the heat sinks dnt get hot
Wrap it in a couple of towels and let it run, 10-15 minutes, it will overheat and shut down and the three red lights will be flashing, then turn it off, let it cool, 15-30 minutes, turn it back on and bam, it should work, granted its not a permanent thing but it will work from a week-month, from then on the red ring of death will appear when it shuts down instead of the 2 lights, and you can either fix it yourself, do the towel trick again, or just send it to Microsoft if the warranty is still intact. trust me it works.
Jun 11, 2009 | Microsoft Xbox 360 Console
Red Ring of Death crops up when my 360 gets too hot.
is it just the two lights on the the left? thats the code for overheated. i suggest putting it in a well ventilated area or get an intercooler.
Jan 09, 2009 | Microsoft Xbox 360 Console
X box 360
i put a intercooler and it worked great... i don't know whats wrong with yours? if all the lights are flashing then it overheated
Oct 22, 2008 | Microsoft Xbox 360 Console
2 light flashing red lights once game is on for 5-10 min.
your xbox is overheating put it in an open area and let it cool overnight i might even suggest the nyko intercooler ex
Sep 26, 2008 | Microsoft Xbox 360 Console
wrap it in towels. the reason is because sometimes you get the 3 lights because something is touching the data board but not communicating. let it sit in the towels and overheat for about 30 minutes. keep in mind leave it on!
In some cases this can also fix the four lights which means the xbox isn't able to communicate with your television. If it doesn't, get new xbox cables.
Aug 18, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
172 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
