Question about Actiontec (GT704WG) Router
ActionTec not allowing RDP
I have an Actiontec 54 Mbps Wireless Cable/DSL Router, I am having trouble setting it up so that i can remote into my home computer from work, i have gone through making sure that the ports are set the my box IP is set and that the actiontec is set to send to my desktop. I am able to RDP from the inside of the home network, but not from the outside. If any one has ideas on this would greatly appericate it.
    Scholar:
  • 42 Answers
There seems to be issues with RDP and VPN Routing with Actiontec Modems in that I can't get mine to work either unless I turn on DMZ hosting, and send all traffic to my Server.
Solution: Turn on DMZ Hosting and set the address to your desktop, warning, however, all traffic sent at your modem WILL be received by your computer, so make sure you have a good firewall installed.
Posted on Jan 16, 2008
How to hook up actiontec v1000h
This is a rather general question--I assume you are trying to add the router to your network.
Here is a link to the directions:
http://support.actiontec.com/doc_files/V1000H_Quick_Start_Guide.pdf
Apr 21, 2012 | Actiontec V1000 Wireless Router - 54 Mbps
My actiontec gt704wg wont work
1. Check the light status of the dsl or cable light
(solid).
2. Go through the basic setup and see if you have the correct settings.
May 22, 2010 | Actiontec GT704WG Wireless Router...
Actiontec Gt704WG wireless problem
fist try to enter modem config site at 192.168.1.1
admin user: admin
admin pws: password
wireless setup
check if wireless is on
check chanel
las step
try this with ips suport is you reset mdoem it returns to factory settings
try to reset it with a paper clip or pen hold it for 20 seconds
May 03, 2010 | Actiontec GT704WG Wireless Router...
Can a actiontec gateway wireless DSL router be connected to a comcast cable modem?I have an old DSL wireless router (gateway), can I use this as my wireless router with comcast cable internet, or do i need...
You could do it, but it's a bit of a pain in the ***** and probably not worth the hassle.
Actiontec DSL gateway was not designed to act as a "proper" router and therefore you won't be able to make it act like one permanently (well, unless there's a hacked firmware out there somewhere ;).
Of course, since it runs linux, you can telnet into it and manually set up the ip addresses on both wireless/wired interfaces and the necessary route between them. It will then work as a wireless access point for your comcast cable modem, but any changes will be lost every time you reboot the actiontec.
I've done it in the past with similar setup but quickly got tired of having to console the actiontec to add the ips and routes every time it crashed -and eventually got a proper wireless router.
So-it can be done, just not easily.
Have fun,
Raf
Nov 08, 2009 | Actiontec (GT701WG) Wireless Router
I have a dsl modem and an actiontec gt701-wg gateway
Yes this is a normal method to setup a wireless network.
To set-up and secure the wireless router from unauthorized access, follow these steps :-
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Oct 31, 2009 | Actiontec (GT701) Modem
I have AT&T DSL and want to install an Actiontec 54 mbps wireless
If the modem was pre-programmed for another service, such as Verizon, you will have to plug the modem into a wall and hold in the reset button on the back of the modem until it resets. Then load the AT&T software IF they provided you with such - the walkthrough is actually pretty good. If AT&T did not provide you the Actiontec or the software, you will have to go to Actiontec's website and download the Actiontec Installation Buddy and also follow the directions for downloading the non-proprietary version of the firmware (WARNING: do not update the player's firmware if ATT &T provided you with the Actiontec; the non-proprietary firmware will make the modem useless toward whichever service provided you with the Actiontec). Take note of the numbers taped on a sticker underneath your Actiontec - MAC Address, etc. You may need this information to complete the installation. Also, download the Actiontec manual - it will take you through the process, but it is not going to be easy to follow - know in advance that it is going to take time.
As you go through the Actiontec Installation Buddy process, it will prompt you to do a modem test - make sure the Actiontec is connected to the phone line and to your computer (via an Ethernet cable). It will do a modem test. If the modem test fails the first time, turn the Actiontec OFF, wait 10 seconds, and turn it on again. Try the modem test again - should work.
If AT&T did NOT provide you with the Actiontec, your task is going to be a bit tricky. If AT&T DID provide you with the Actiontec, it might be better to call their technical support for a walkthrough.
-Tha Mp3 Doctor
Jan 07, 2009 | Actiontec GT704WG Wireless Router...
Actiontec GT701-WG won't operate wirelessly
In looking on the internet the unit is a DSL gateway. Trying to use it on cable internet is not a real good way to set up your network because I believe the router is waiting for a DSL sync before the services turn on. I would spend the money and pick up a Linksys or Netgear G router, there around $50.
Jun 01, 2008 | Actiontec (GT704WG) Router
Actiontec (GT704WG) Router Logo
300 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
