Question about E-Machines eMachines Desktop PC
Colors on myomputer are way off
I am not sure if I change the colors in the windows part or the darn computer it's self, if there is a difference. But I need help as I do not know how to fix it. My aol screen is mostly black and white, very dark and hard to read. Help anyone!
  • Duhme Apr 25, 2009
    Ok, heres the deal, it's only when I sign on in my name. If I sign on as guest I have no problem with the colors. Strange. When I use my name the whole screen looks as if it is spotty and the colors look like a messed cartoon. Help if you can.
    Thanks
    Scholar:
  • 54 Answers
This may actually be something the monitor is doing, not windows.
ON the monitor itself, you should see some buttons. Usually there is a menu button of some kind. Anyway, press some of those buttons to see if a menu comes on the screen, and then navigate your way through some options and see if you can find a brightness or contrast setting. You then should be able to change the settings with the buttons on the monitor (left, right arrow keys, or someting similiar).
Hope this helps.
-Chad
Posted on Dec 12, 2007
  • Chad Quicke
    Chad Quicke Dec 13, 2007
    did you try it?
Top and bottom menu bars are different colors, I made bottm pink but top won't change color?
make sure that the "Let windows choose... " is turned off otherwise windows takes over.
Tony
Apr 27, 2014 | Gateway Computers & Internet
When I turn on computer all I get is a totally green screen blinking gray. Cannot get on the computer
The monitor might be faulty ....do a monitor self test ...disconnect the datat cable from the monitor and turn it on ....there would be a color code , if the color code is ...
RED....GREEN....BLUE which might appear as RGB or the colors itself......then the monitor is ...if the color code is different then the monitor has to be replaced
Mar 14, 2013 | Acer America Acer Aspire AME600-UR368...
The colors of my laptop's sreen are inverted. I've tried everything I could think of (display settings, system restore,....), how do I fix this?
Click start control panel administration tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers You might need to upgrade your graphics card drivers. You might have to remove your graphics card to make sure the socket is clean restart your computer the reinstall it this should activate found new hardware wizard if your computer came with a mother board disk the drivers could be on it Click start control panel display desktop you can select a different desktop from the drop down list or a browse button where you can select different pictures this may vary depending on your operating system also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal , larger or custom settings
Always click APPLY after making any changes windows 7 Open Personalization by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization. Click Window Color and Appearance. Under Window Color and Appearance, click the color you want, and then click OK. Note If you see the Appearance Settings dialog box instead of the Window Color and Appearance window, the theme might not be set to Windows Vista, the color scheme might not be set to Windows Aero, or the computer might not meet the minimum hardware requirements for running Windows Aero. For more information, see Troubleshoot problems with Windows Aero.
Feb 28, 2013 | Dell Latitude D820 Notebook
I want to change my monitor colour temperature
When you use the Colors window to select colors for text or objects in a document, you can also assign a color profile to the document. Color profiles help ensure that the colors you see in the document onscreen match the colors in the document when it's printed or viewed on another computer.
To choose a color profile for a document:
  1. In your document, select the text or object whose color you want to change.
  2. Open the Colors window.
    In some applications, you can open the Colors window by choosing Format > Font > Show Colors or Format > Show Colors. In some applications, you can also click a button in the application's toolbar or a settings pane.
  3. Click the Color Sliders button.
  4. Choose a slider option from the pop-up menu.
  5. Drag the sliders or enter specific values to adjust the color.
  6. Click the colored box next to the pop-up menu and choose a profile from the list.
If you open your document and the colors appear in a different shade or hue than you expected, the application you're using might not recognize color profiles. Try using the generic color profiles instead.
In some cases, an application may not open documents that use non-generic color profiles.
You can create your own custom color profiles using ColorSync Utility. For more information, open ColorSync Utility and choose Help > ColorSync Utility Help.
Jan 08, 2013 | Apple Mac OS X 1063 Snow Leopard Family...
Loud humming or buzzing noise have picture but flashes all different colors resets and goes off after awhile good pic after that
The tv problems and causes are 100% is the tv colors wheel it is causes and the tv problems.The tv are having humming or loud buzzing noises sounds are the causes of the tv colors wheel going off and out control of it motor mount and spinning in at high RPM speed and different colors showing up or flahes of black and white color in the tv back ground.The tv colors wheel must have to be replace.Best hire a tv tech to do the replacement of the tv colors wheel,because have to take out many mechanicals parts before can even come to the tv colors wheel is self to replace it.
Aug 19, 2011 | Samsung HLP5067W Television
After moving, my Philips HDTV doesn't show normal picture anymore. I can hear the sound but all it shows is many different color at once shifting down just the top of the screen (and it will do this...
The tv have a colors wheel design into it tv.The tv is now having grinding noises or colors pattern mess up or tv flashes of Black&White within the color picture.Mean the tv colors wheel disc it is worn out and it is not spinning inside it motor axis anymore.If u are not mechanically incline,don't tries to change the colors wheel by ur self,will cost u more problems,than it worth trying to save some money by trying to do the job ur self.Hire a bonded tv Tech.to do the job.The tv part and the labors should cost u about $500.
Jun 14, 2011 | Philips 50PL9126D/37B 50" DLP TV
After the computer is left alone for awhile is will start flashing Acer on the screen and the power button will change colors from blue to an orange looking color. I have tried moving the mouse and...
The monitor is entering "standby" mode.
In Windows, click Start.
Click Control Panel.
Click Power Options.
Change the number of minutes before entering Standby Mode.
May 14, 2011 | Acer X193W LCD Monitor
LCD screen with weird colors and out of focus
I dont have much info for you but I hope this helps, If your LCD screen has gons through an "accident" or if it is just in it's usual old age moment, It's time to replace the screen. You can do this yourself, or you can hire someone to do it, howeven it is not that hard, Go online to find some replacement LCD screens for that model Laptop and then the rest pretty much self explanatory
May 06, 2010 | Computers & Internet
Dell 2300mp projector, colors bad
try reseating the vga cable. Try removing the cable, the green tint should disappear meaning that the color or lack of one of the primary colors blue/red/green were missing due to bad connection. or maybe you have a bad vga cable.
Feb 26, 2009 | Dell 2300MP Multimedia Projector
E-Machines eMachines Desktop PC Logo
44 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
