Question about Compaq Presario 5000 PC Desktop
Mtp devices driver
The software for the mtp driver cannot be installed why?
  • 1 more comment
  • rmcqueen Dec 11, 2007
    mtp driver software doesn't install at all.
  • Anonymous Dec 20, 2007
    samed
  • Anonymous Dec 31, 2007
    im having the problem of it said mtp device cant be installed cant find software i have the k1m
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Hello Rmcqueen
You need to make sure your PC compaq model, there is a lot models 5000 for each particular driver, but, there is a label somewhere that tells you exactly your PC model, you only have to make sure what model is. then you can download drivers, according.
good Luck
Posted on Dec 12, 2007
My walkman nwz-b152f shows boot error
First, you go to DEVICE MANAGER. Under PORTABLE DEVICE, there is your WALKMAN. Right click on the WALKMAN. Choose UPDATE DRIVER SOFTWARE. Then, LOCATE AND INSTALL DRIVER SOFTWARE MANUALLY. Then, choose LET ME PICK OF DEVICE DRIVERS ON MY COMPUTER. Currently you are using MTP USB DEVICE...so, now choose USB MASS STORAGE DEVICE. Then, click next. Once u have done all this, format your walkman. Your walkman should be fixed. :)
I had the same problem with you before, and i tried this. My walkman has working like usual, now. I'm using Windows 7. So, best of luck!
P/S : U also can change back your driver to MTP once your walkman had fixed by doing the same step. ^^
Feb 11, 2012 | Sony Audio Players & Recorders
I installed my sony NWZ as MTP device, but now i want to go back to simpler UMS (standard usb connection) ive tried removing the mtp drivers from device manager, but it always just auto installs... Can...
Since there's no easy option in the Walkman's settings to switch back and forth between MTP and UMS, there's a little trick to un-do the MTP drivers so that the unit becomes a straight USB Mass Storage drag/drop unit. You have to go into Device Manager (Windows XP), find the Walkman in the Portable Devices group, right click, then select Update Driver. Then select "No, not this time", then Next. Select "Install from a list or specific location (Advanced) then Next. Select "Don't Search, I will choose the driver to install", then Next. (Be sure to check the box beside Show Compatible Hardware) Highlight USB Mass Storage Device, then Next. (To revert back to MTP, just do the same thing but choose MTP instead of USB Mass Storage Device.) Personally, I'd never go back to the MTP mode. Having the Walkman seen by the computer as just another USB mass storage device allows the drag/drop transfers to go much faster
May 05, 2009 | Sony NWZ-A829 Digital Media Player
Driver
1. Make sure you Windows Media Player 11 (Goto Help --> About WMP --> v??)
2. If you do not have it, install it from this location: http://www.microsoft.com/mediaplayer   3. Change the Mode on Device: Go into Menu --> Settings --> USB Mode:Auto Detect/MTP/MSC   4. Select MSC and it should work. If it does not try Powercycling your device (turn it off and then turn it on).  5. Try other modes as well.
Keep the device in AutoDetect Mode and follow the instructions below:
i. Connect your Device
ii. Right click on My Computer and select Manage
iii. Select Device Manager
iv. At the right hand side look out for Portable devices and click on the + symbol to display your device
v. Right Click on the device and select Update Drivers
vi. Select 'No, not at this time' and click Next
vii. Select 'Install from a list or specific location' and then click Next
viii. Select 'Don't search, I'll choose the driver to install' and then click Next
ix. Select 'MTP Device' and then click Next. This should install the device and then should be ready for use
Jan 17, 2009 | SanDisk Sansa m240 MP3 Player
Error Installing Utilites Software
. Connect your ML648B to your computer with Windows XP or later.
2. By default your computer will recognize ML648B as GPX MTP Device. (Wait for few seconds to a minute allowing your Windows computer to recognize and install necessary drivers for the device for first time as MTP Device.)
3. Press the POWER button from top of your ML648B, to change it to USB mode connection. You will also see USB on the screen of ML648B. (Wait for few seconds to a minute allowing your Windows computer to recognize and install necessary drivers for the device for first time as USB device.)
4. ML648B will now mount 2 drives, one as Tools (as CD-Drive) and second as Removable Disk (Drive) – under My Computer on your Windows Desktop.
5. Double click & open Tools, and run Setup.exe to start installing Video Conversion Software tool.
6. Select defaults options and finish the installation by clicking on Close or Finish.
7. If asked, click on Continue Anyway on Windows XP or Install this driver software anyway on Windows Vista.
<!--[if !supportLineBreakNewLine]-->
<!--[endif]-->
Jan 15, 2009 | GPX ML648B MP3 Player
Having problem adding this device to my computer
1. Connect your ML648B to your computer with Windows XP or later.
Dec 30, 2008 | GPX ML648B MP3 Player
I have a Gigaware 4GB MP3 GX400 4-420
Download the drivers from Creative Labs, or with the disk included with the MP3 player.
Dec 27, 2008 | Creative Labs ZEN Vision:M Digital Media...
Sansa e250 - MTP Mode not working with Windows Vista
Get the vista compatible software from Sandisk's website
Aug 08, 2008 | SanDisk Sansa e250 MP3 Player
Creative zen v plus
i had the same problem but solved it, it seems that the usb driver does not always install with the software installation so you must install using the DEVICE MANAGER make sure first your mp3 player is connected, so ( copy & paste) your software to desktop, then go to CONTROL PANEL, then SYSTEM, then HARDWARE then DEVICE MANAGER, in device manager you should see ( zen v plus ) with a yellow question mark above it, which means the drivers are missing, click onto that and follow instructions to install the drivers which you will find in the software you have pasted to desktop. good luck, tony spain
Mar 22, 2008 | Creative Labs ZEN V Plus MP3 Player
MTP device not found in XP with WMP 11
solve your problem from my post:
http://amritbera.blogspot.com/2008/11/mtp-problem-solved.html
May 22, 2007 | SanDisk Sansa e260 MP3 Player
Compaq Presario 5000 PC Desktop Logo
154 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
