Question about Bazooka EL1204 Car Subwoofer
My bazooka is making a rattling noise
Whenever my left bazooka thumps, there is a weird rattling noise coming from it. What the hell can it be?
  • wetbakerv Dec 12, 2007
    Is that an easy fix?
    Sergeant:
    Champion:
  • 306 Answers
The voice coil is blown.
Posted on Dec 11, 2007
  • cory casper
    cory casper Dec 12, 2007
    Only if the sub is designed for coil replacement. youl have to contact the manufacturer for that info.
Loud thumping from under drivers side that started with a squeal.
16 costly car noises - Bankrate.com
www.bankrate.com/finance/money.../16-costly-car-noises-1.asp...
BankrateYou should not ignore certain thumping, banging, clicking and squealing sounds. These sounds often rear their heads or intensify whenever the driver takes ... Hissing or sizzling under the hood: Heard when the engine is first shut off, .... my rear right wheel makes a loud bang when switching from park to drive/reverse.
Sounds coming from drivers side front wheel - AnandTech Forums
forums.anandtech.com > Social > The Garage
AnandTech
Dec 1, 2009 - 21 posts - ‎10 authors
Sounds coming from drivers side front wheel The Garage. ... slightly left, I get a slight metalish-squealing sound coming from the drivers side front wheel area. ... but before I start the wild and expensive goose chase of bringing it to mechanics I ..... Those twoloud clunks when turning hard right give it away.
Ford Explorer Questions - Thumping from front end - CarGurus
www.cargurus.com > Questions > Ford > Explorer
CarGurusDec 22, 2009 - Thumping from front end - I have a hard thumping noise coming from ... without problem then I'll take a turn or something and it will start. ... I just recentlystarted having a rubbing and thumping and squeaking noise in the right front sidewhen driving ... Thumping sound coming from under the truck 4 answers.
Car Noises: Consumer Reports - Consumer Reports Online
www.consumerreports.org/cro/...noises/.../index.htm
Consumer Reports
Feb 03, 2016 | Cars & Trucks
Rattling noise that stops when you push in clutch also cluch peddle has been hard to push in since clutch replaced a year ago
Whenever you hear a tap, rattle or thumping noise take to a mechanic or someone who knows cars you do not want to blow a rod through the block. It could be starting to freeze take it in!
Mar 18, 2015 | Cars & Trucks
2000 jeep wrangler with 35 inch tires making a rattling noise on front passenger side
make sure that the inside of the rim is tight on the hub and not sitting off it
loose/ incorrect wheel stud nuts will also cause the noise
Apr 12, 2017 | 2000 Jeep Wrangler
Struts noise?
I would tend to believe it's more likely a worn sway bar bushing or link if it's a rattle or a small clunk, if it's a loud clunk probably a strut, try bouncing he back of the car when parked, if you get the clunk probably a strut if only when driving,turning,braking probably just a bushing on the sway bar
Jan 18, 2014 | Toyota Camry Cars & Trucks
Clicking in the engine
here are few components that can cause such problem.Its advisable to click the link below and follow the troubleshooting to correct the problem.
Engine makes noise? http://howtobyme.blogspot.com/2011/12/engine-makes-noise-and-cooling-fan-belt.html
Chirping sound coming from engine? http://technoanswers.blogspot.in/2012/01/chirping-sound-coming-from-engine.html
--------- Vehicle making Clunk Thump Thud noise? http://howtobyme.blogspot.in/2012/03/vehicle-making-clunk-thump-thud-noise.html
Car Engine Overhaul Tips? http://vwrepairhelp.blogspot.com/2011/11/car-engine-overhaul-tips.html
HOW TO PERFORM A BASIC ENGINE TUNE UP-OIL CHANGE
http://schematicsdiagram.blogspot.com/2011/08/how-to-perform-basic-engine-tune-up-oil.html
Rattle noise from engine? http://whatisbyme.blogspot.in/2012/05/2005-toyota-corolla-rattle-noise-from.html
These will help.
Thanks.
Jul 21, 2012 | 1999 Ford Explorer
Making noise whenever it runs(circle).
Hello, what kink of noise? I know what the problem is. inside of the dryer there are two plastic roller with ball bearing pressured into the hub. Because of the head generatored in the dryer the bearing will loose their grease. This will bearing rattle with thump/thump and squeaking.
Now if the noise is in the front of the dryer then the felt seal will be need to be replaced. I hope that I could be of some service to you. GB...stewbison
Sep 24, 2011 | LG Dryers
Front suspension noise-dull rattle-thumping sound,bumpy roads
look at the front lower engine mount. I had similar noise which has been driving me nuts, thought may be thesway bar links, put it on friends hoist and saw that the front engine mount (mounted to bottom of lower radiator support) was cracked and the rubber bushing inside very worn with pieces missing. odd thing is that reving, or putting into gear never caused it to make a noise, just certain bumps. I ordered part from Autozone,hopefully it gets here before the holiday week end is over.
Good luck
May 15, 2010 | 2005 Dodge Caravan
Thumping noise in chevy tracker 2000model
this noise sounds like your right cv axle. wou might want to have that checked out, they can do great damage if broken while
Feb 20, 2009 | 2000 Chevrolet Tracker
A rattling noise
You have a problem with the microwave stirrer motor. Cost of part is near $90 and will require 2+ hours to get to, exchange and close back up.
Either get a new microwave of put up with the noise (which I did for 6+ years).
Nov 18, 2008 | Whirlpool GH8155XM Microwave Oven
Bazooka EL1204 Car Subwoofer Logo
292 people viewed this question
Top Bazooka Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
rd2xpld
Are you a Bazooka Car Audio and Video Expert? Answer questions, earn points and help others
