Installed software, doesn't work. Realized it's probably because of Vista Home that I have. Went to Zebra, downloaded drivers and install. Reinstalled with the Vista version. No printy the printer. I know it's gotta work....it came with a printed sample in the machine. Stupid Vista. Is that the trouble?
Try to make the self-test first: Power OFF Press "FEED" and keep it pressed and turn the power ON again. Did it print?! if Yes... There must be a cable problem or port. Is it USB? Serial? Parallel ? Let's say it's Parallel, go to the command line and type: "dir >lpt1" without the quotes and assuming it's connected to 1st parallel port did it print?! on serial would be "dir >com1" or, if it shows up in "Printers", pre-define it and just type: "dir >prn" Still doesn't work!? Try with a different cable, or other computer. You can use it even without installing the drivers...
Was this helpful?
Yes
No
Popular Solutions for Zebra Eltron TLP 2844 Thermal
cannot print anything from computer not pictures, documents. printer is communicating and online....
(More)
cannot print anything from computer not pictures, documents. printer is communicating and online. recently did updates for windows 7.
I am not able to print properly jewellery label (tag) in zebra tlp2844. there are 2 tags in each...
(More)
I am not able to print properly jewellery label (tag) in zebra tlp2844. there are 2 tags in each label. First one print all right, but next ones are not on the tag, printer leaves some gap. i have removed gaps between labels as well in printer properties, but still nothing. please if you can let me know how can i calibrate jewellery tag in tlp2844 Thanks
I use it to print small jewelery tags. It prints the vertical 90o bar codes fine but when I try to...
(More)
I use it to print small jewelery tags. It prints the vertical 90o bar codes fine but when I try to print the same bar code horizontally it does not print all the lines. Thought I had printer head problem but the same happens with the new one.
