Question about 2wire 1800HG Router (RG1800HG00)
BT1801HG connected to ISP but still no internet access
Hi All Gurus
I have got a BT 1801HG router which is sucessfully connected to my ISP Eclipse ( they have verified the connection). The problem is when I try to access internet it takes me to gate error page saying the page is cached and close the browswer and all. Even I cleared the cache and files still the same problem.
Can some one please help. Thanks in advance.
    Problem Solver:
  • 9 Answers
How do i connect to the internet i changed me service?
hi Inga.
see if this helps you out.
To open Network Connections, click Start, click Control Panel, click Network and Internet Connections, and then click Network Connections. If your DSL or cable modem is always connected and your ISP does not require a user name and password, you do not need to run the New Connection Wizard.
How do you get access to the Internet? Internet Service Providers (ISPs) If you want to access the internet at home, you'll need an Internet Service Provider (ISP) and a router to connect to the ISP. ISPs often provide a router with their service. This means more than one computer or device in your house can use the broadband connection at the same time.
you could also go to this link and its a step by step way of finding out how to connect tp the internet,
How to connect to the internet
Nov 19, 2017 | Internet Computers & Internet
How do I access the internet
hi chris.
Internet access and broadband ' nidirect
or you can click on this link and have a read up.
How do access the internet Google Search
Nov 01, 2017 | Internet Computers & Internet
How do I connect my Netgear DGND3700 router to Fibre internet (BT infinity)
Hi there
Your Netgear router will not connect to BT Infinity directly as the built-in modem is ADSL/ADSL2+ and Fibre requires a VDSL modem as in the HomeHub5 or the BT Openreach modem. Either of these can be used with your Netgear as a subsidiary router/access point. You may now be able to get a router with a VDSL modem built in but 3 years ago it was really only available from BT and BT did not support other makes.
Hope this clarifies matters though perhaps not too helpful
Nov 08, 2014 | Network Computing Devices (NSH800S/A)...
How to resolve wifi access mode not supported
an AP is used to extend you wireless range and will connect to your router to provide network and internet access. An AP by itself cannot connect to the ISP since it does not use a WAN port
a router is an AP that will allow you to connect to your ISP for internet connection. A router can be configured to work as an AP but a AP cannot function as a router.
Feb 19, 2014 | Linksys Business Series WAP4400N...
Using WRTS4GS2 Cisco Router and could not access the internet. Remobed router and had instant access to the internet.
Contact your ISP. Some ISPs limit the number of computers that can simultaneously connect to your cable-modem. If you change computers, you have to tell your ISP.
Or, power-off your cable-modem, to "reset" it.
Connect the Cisco Router to the cable-modem.
Power-on your cable-modem.
Power-on your router.
Connect your computer to your router, and see if you get Internet access.
Dec 20, 2010 | Computers & Internet
Hi there, i'm trying to setup wireless internet using thompson tg585 v7 modem. after whole setup i could access to internet with physical connection bt not wirelessly. could you plz suggest...
1. Please ensure your wireless connection is switched ON
2. Your wireless router should be working in bridge mode.
3. Connect the ethernet port of the wireless Router to the Modem and then try accessing.
Best regards
Dec 02, 2010 | Computers & Internet
Changed ISP provider and is not able to connect to internet through linksys wireless router, model # wrt160n
Have you gone to your new ISP providers website, and surfed the internet?
I know, most routers have to be registered to gain access to the internet.
You might have to manually input the MAC address (found on the bottom of the router) to your ISP, then sometimes it takes anywhere from 5 minutes to 1 hour for the router to register, depending on your ISP.
After the router is registered, you can plug or wireless connect to the internet.
Sep 09, 2010 | Linksys Wireless-G WRT54G Router
Wireless-G WRT54GS Router (e125894): My linksys says "You are connented to the access p...
That means that your router is functioning properly on your network, communicating with other devices, but your ISP (Internet service provider) connection is malfunctioning, out of service, or otherwise experiencing a problem. Your router can't connect to the Internet because of a problem somewhere between the router and your ISP, or your ISP and the Internet.
May 18, 2010 | Linksys Wireless-G WRT54GS Router...
Trying to run wii systems update through the new BT home hub connections fine but I get an error code of 32004 can you help. Many thanks
Error Code: 32004Please check the following:
  1. Satellite Internet often causes this Error Code. You must have a cable or DSL internet connection. Other connection types, such as dial-up and satellite, are typically not compatible. Contact your Internet Service Provider if you are not sure what type of internet connection you have.
  2. Ours servers may be trying to handle an unusually high amount of traffic (especially if a new Wii update is available). Please wait a few hours and try the connection again later.
  3. Does your internet service provider (ISP) require that you log in whenever you wish to use the internet? If so, your ISP may not be compatible with the Wii console. Please contact your ISP for additional information.
If you are still unable to connect, and have waited a few hours, please try the following:
How are you attempting to connect your Wii console online?
    Wireless Router:
  1. Adjust the Wii's manual settings. Click here for more information.
  2. Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. Be sure to try both channels if the first one you try does not work. This can potentially increase the download speed. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available). (The "Channel" setting is typically found in the "Wireless" section of your router's setup utility.)
  3. If adjusting the "Channel" did not work, please review our "Slow Download Times or Errors Received While Connecting" troubleshooting tips by clicking here.
  4. Try temporarily disabling your router's firewall.* Are you using a Netgear brand wireless router? Our expeirence shows disabling the "SPI Firewall" of the router may help the connection. The "SPI Firewall" option is typically found under the "WAN Setup" tab of the router's settings. For information on accessing your router's settings, please click here and select the model of the Netgear router you own (if available).
Nov 12, 2009 | Nintendo Wii Console
Connecting a 3com hl-542 to my new broadband provider
please change the DNS ip as your new ISP given.
Jun 09, 2009 | 3Com OfficeConnect Router
2wire 1800HG Router (RG1800HG00) Logo
273 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
