Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Whine-no picture-audio only,1 channel
Problem happened immediately after comcast disconnectd service-30 minutes tv was turned back on & didn't work.
Briefly...direct tv installed their dish & we switched service...comcast came out apprx 1 week latr to disconnect.tv workd 30 minutes before they arrived...was turned back on 30 minutes later & didn't.Strange but may just be one of those things
  • wirecuttr Dec 17, 2007
    unable to view menu screen...have audio/no video
    spoke to rca & he/they said that problm was probably caused by amp difference connect/disconnect..probably...but I have'nt found out much about this tv yet.... by the way it is a HD56W58...a 2005 production date.
    I took the back off & don't see a projection blb like in a dlp..will probably have someone come look at it... it's just that the circumstances ...were... murphy's law
Bring up the menu screen the tv and auto program the channels this lock out all un wanted and only allow the rf tuner input channel from the box if your using rf cable hook up,if not un plug the unit for 1 min. and try it again.
Posted on Dec 14, 2007
Sony tv picture goes green
HAVE IT REPLACE WITH A NEW ONE
Sep 12, 2012 | Sony Internet TV NSZGT1
I tuned the tv on and after it scane the channels the tv came i have atleast 60 channels now i only have 29... channel 30 says audio only 30 thru 60 no picture, and then the channels say like 30.20
Is your televison set to cable mode or broadcast mode?
Who is your cable provider?
Comcast recently, in my market disabled the ability to receive the new digital format unless you use their converter box.
Jan 04, 2011 | Televison & Video
No sound on channel 3
Maybe the cable signal is defective not your tv.the other channel is ok.if you tv has a defect all channel has affected.
Jul 02, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Disconnectd AcTV from Comcast; can't reconnect!
"AV- TV" where you plug your video cable in, there will often be a name like video-1 ,2or3. If you push the AV (audio video) button on your remote you will select channel video-1 if you press another one or two times toy will get channel video- 2and 3.
Cheers Timo
Apr 29, 2010 | Accurian 16-454 Television
I have a Philips DVDR 3575H. using Comcast's
Try this set up-
Use an RCA audio/video cable for this set up (Yellow/Red/White).
Connect from the Video out (Yellow) connection on the back of the cable box to the Video in on the back of the DVR.
Connect the audio (Red/White) cables from audio out connection on the back of the cable box to the "Audio in" on the back of the DVR.
This should still get you a decent picture but not a true HD picture for your recordings.
When you set the timer to record set it to record either E1 or E2 depending on which input you connected the cable box to and ensure that the cable box is tuned to the channel you wish to record.
*** NOTE: If you keep the HDMI cable connected as you have for the cable box and watch normal TV through the HDMI input on the TV you will get HD programming for your general viewing but still have the option to record with the DVR at a lower quality. ***
Good Luck and please rate this solution....
Jan 07, 2010 | Philips DVDR3575H/37
There is sound but no picture and there is no response when using the control buttons on side of tv or the remote. I turn the tv on and change channels thru Comcast cable.
Talked to a Westinghouse tech and told to unplug for about 3-5 minutes, then re-plug. It's like having to re-boot your computer when it goes down or starts acting wacky. It worked, I got picture. Says it could happen again, maybe 1-2 times a year is o.k., if it starts to happen every few weeks, then it's something more.
Oct 14, 2009 | Westinghouse LTV-37w2 HDTV
RCA STB7766G1 Converter Box not working with Comcast cables
The RCA STB7766G1 does not support any cable or satellite connections.
Jul 22, 2009 | RCA Analog (RCA) to Digital (USB)...
No Non-Hd sound
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
Jun 19, 2008 | Insignia 26 in. LCD Flat-Panel HDTV
LG LCD HDTV 'NO SIGNAL'
To fix the problem, try turning off the TV and unplugging it from the outlet. Once unplugged, push the power button and hold it down for 1 minute. Then turn the TV back on and rescan for channels.
If the problem persists, contact LG customer service immediately as there is a problem with the memory card. The device is unable to retain scanned channels for immediate feedback.
All LG LCD automatically comes with a 1 year manufacturing warranty. You would have to provide proof of purchase to show when it was purchased. Hope this helps. The Guru
LG customer service: http://www.lg.com/us/support/index.jsp
Dec 07, 2007 | LG 42LC2D 42 in. LCD HDTV
No tv picture
Its possible that you changed the channel or the input line your TV gets the cable signal from. unless you caused more of a problem while trying to fix it, I would suggest you to go through the TV(not cable) channels to see if you can find the one that gives cable picture, or to go through the different input settings(TV/AV on older TV's, and 1, 2, 3 etc on newer ones). one general icon for the later is an arrow going into a circle. I think its the "select" button on your TV remote. Good luck
Mar 29, 2006 | Philips 30PW8402 30" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
110 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
