Question about Sony UP DR100 Thermal Photo Printer
Sony up-dr 100 error 0007
Error 0007 mecha trouble
This may well be a failure of the cutter switch sensor to reset. This worked for me.
Turn Off the Printer.
Remove both side panels and the plastic panel on the INSIDE of the DOOR on the right hand side. Then close the door and remove the plastic panel UNDER the door. This is held in place by two screws.
You will see a white gear on the bottom right hand side of the door. It is on the underside of the door. Turn this gear untill you can see the cutter move smoothly across the bottm of the door and return to the right side of the door. Listen for a click. This is the switch resetting. Close the door and power up the printer if you still get an error code 0008 or 0007 repeat the resetting process by turning the gear. BE SURE TO TURN OFF THE PRINTER!!
Posted on Aug 11, 2009
Mecha errror what is the problem of my sonny mini-hifi components when i turn on mecha error appear on the screen then turn off itself
It's a Sony problem, I hate to say. My amp does the same thing. Check your speaker wires for a short, if no short, then the auto protection circuit in your Sony is shot - mine was too, and it costs a fortune to fix it - cheaper to buy another one, I hate to say.
Apr 22, 2014 | Sony Audio Players & Recorders
Mecha trouble problem cutter pos
- in my case I received the error "mecha trouble cutter pos"
I removed both side panels and the panel directly in front of the cutter
this gave me access to the cutter assembly where I found that the cable that runs the cutter had fallen off of the pulleys.
I was able to get the cable back onto the pulleys and now the printer works perfectly
Feb 20, 2012 | Sony UPDR150 Thermal Photo Printer
How to fix mecha error on sony mhc-gx555,-stops-responding,-or-displays-mecha-or
Jan 09, 2012 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Why My sony Mini Hi-FI MHC-GZR88D says Mecha Error
How to resolve mecha error in sony mhc-gzr88d
Oct 08, 2011 | Audio Players & Recorders
I'm getting a "Mecha Trouble
checking the gear by taking off both side panels and the panel directly in front of the cutter helped me - in my case I received the error "mecha trouble cutter pos"
problem was, the cable that runs the cutter had fallen off of the pulleys and after a bit of fussing, I was able to get the cable back in place and a working printer.
Sep 15, 2011 | Sony UPDR150 Thermal Photo Printer
Mecha error shows on the dashboard and goes off. Normally shows when the engine is first started in the morning.
I presume the "Mecha error" is in actuallity the "Check Engine" light? If so, the engine (powertrain) computer (PCM) would have stored a Diagnostic Trouble Code (DTC) in its memory. Find out what, if any, codes were recorded/stored in memory... we can take it from there.
Jun 10, 2011 | 2006 Hyundai Tucson
i need best solution for mecha error 03 kodak printer 6800
Mar 15, 2010 | Kodak 6800 Thermal Photo Printer
Mecha Error 0005
oooohhhh k
1) when you turn the printer on does the printer make a lot a noise and then display "ready"
-If not there may be mechanical issues with your printer
Nov 13, 2008 | Sony UP DR100 Thermal Photo Printer
Error message
Problem: The Printer does not detect the home position of the cutter during initialization.
Either there is a scrap piece of paper obstructing the path of the carriage that houses the cutter blade or there has been an impact on the lower side of the printer causing a bend in the metal that holds the home switch. This switch will trigger a sensor telling the printer that the cutter has reached the home position(right side)
Solution:Remove the paper scrap or Remove the door panel and check for damage on the right side of the cutter blade path and bend the metal piece to realign the switch so that the plastic carriage makes contact when reaching the right side.
Nov 30, 2007 | Sony UP DR100 Thermal Photo Printer
Kenwood 10 disc changer
i have a sony mini Hi-Fi Component System MHC-GX470. I comes on, the Radio and Tape deck plays well. the CD Player says "mecha Error" and hangs. CAN YOU PLEASE HELP ME???
Jun 23, 2007 | Kenwood KDC-CMP59FM 10-Disc CD Changer
Sony UP DR100 Thermal Photo Printer Logo
546 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
