Coleman Mach III Air Conditioner
Problem for Coleman Mach III Air Conditioner
My coleman 13,500 roof a/c year 2000 does not blow
By krukov on Sep 14, 2009
My coleman 13,500 roof a/c year 2000 does not blow as cold as used to. I have cleaned the top condenser coils, with no help. It also at times will seem to pull a heavy load when I assume the compressor kicks in, very heavy that the generator bogs way down, then runs free, i believe the compressor is shutting down as cooling worsens, it was 85 outside and the coach continued to get warmer. The AC unit has shut down completely before, not sure why I waited 30 minutes and it restarted.
Solution #1
posted on Sep 14, 2009
Not Rated)
A_HVAC
Rank: Wiz
Rating: 85%, 45 votes
if the compressor started and stoped means
1 thermostat need settings
2 compressor over heated due to low suction pressure need to check and repair the leak then charge the freon
Was this helpful?
Yes
No
Popular Solutions for Coleman Mach III Air
Questions and Unsolved Problems for Coleman Mach III Air
Do you recommend Coleman Mach III Air Conditioner?
Answer
Answer
Replaced condenser and had health problems. Now cant find wireing diagram to reinstall. Thank youfor... (More)
Answer
installing to volvo 36ft bus need installation requirements for water drainage, electrical and... (More)
Answer
water is entering through unit. i think the previous owner sealed around weep holes. how do i fix or... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioners Experts
Top Air Conditioner Repairmen
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
