AFter technical support helped my husband connect his work laptop, this older laptop will no longer connect. I can see the wireless network connection, but when I click on it it just waits for the network and then times out and says to see my network administrator. I manually added the laptop to my network and it still wouldn't recognize it!
Sometimes tech support advise to use manual ip address. check out the work laptop settings. Is it manually configurated ip address? if so... use the same settings on yours, EXCEPT the ip address itself, use the same gateway, same dns, etc... in the IP address, change only the last octect (last numbers).
Was this helpful?
Yes
No
Popular Solutions for 2wire Wireless-G 802.11g ADSL
I have been trying to install a AT&T 2wire gateway. The first two units we have tried, we...
(More)
I have been trying to install a AT&T 2wire gateway. The first two units we have tried, we installed correctly, got to the end of the installation process, and upon plugging in the ethernet cord, the ethernet light doesn't light up on the 2wire gateway. HELP!!
