Question about Dream Vision CINEXONE Multimedia Projector
Blinking bulb light
The bulb yellow light next to the power botton is blinking. I purchased a new lamp and replaced but is still blinking, I also vacuumed it but still did not work. What else do I need to do?
  • 3 more comments
  • bwilcox Aug 22, 2008
    How do you reset the counter??? I have an Epson EMP 713.
    Thanks
  • Anonymous Sep 22, 2008
    i have replaced the bulb and the projector works but not the bulb.
  • Anonymous Nov 21, 2008
    I have the same problem
  • kinderdesign Dec 18, 2008
    I have the same problem. Dell told me that the "lamp driver has gone bad" and that you cannot fix it. If it's under warranty (as mine is for only 19 more days!) they will ship a replacement projector. Otherwise, the bill would be $730 and I would have bought a new projector instead.
  • scnewhomes May 11, 2010
    Marrie, what happens if you don't reset the timer?  I just replaced my cinexone's lamp & didn't know to replace the timer... :(  it worked fine for a few hours but now on start up it flashes the power & yellow lamp light & there's no picture displayed.  With out the picture I cannot reset the lamp timer (per the manual)  any ideas?
Had the same symptom. After disassembling I noticed that one cap (10V 3300uF) in the power supply circuit was boiled. (the top was domed out). I replaced it with 2200uF for testing (because i didnt have another one at hand) and everything worked fine again :))
Posted on Dec 22, 2008
How do i reset the lamp to zero on my sony vpl-fx50 projector?
Posted on Apr 10, 2008
Resetting lamp timer on vpl-cx6 (among others)
To reset:
Ensure the projector is in "Standby" mode, depress the following keys in sequence within 5 seconds.
Reset, Left Arrow, Right Arrow and Enter.
Posted on Apr 05, 2008
  • 563 Answers
Hi there
You must always reset the lamp timer when replacing a bulb.
Posted on Mar 26, 2008
    Problem Solver:
  • 3 Answers
Marrie If you can help me out how to reset new lamp on NEC MT830+ projector thank you.
Posted on May 01, 2008
Lamp light is yellow. Replaced bulb still not working1
CHECK AND MAKE SURE THAT THE LAMP DOOR IS SECURE ON THE BACK OF THE TV.
Dec 16, 2010 | Mitsubishi WD-57733 57" HDTV
TV was working fine when we went to bed Monday (August 30) night. Got up the next morning and turned it on. It appeared it was going to come on, the green light flashed and then the lamp indicator light...
1. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. (LED does not stop blinking after plug in) Disconnect the USB connector from the card reader to the front from the Chassis, if the LED stops blinking after 70 seconds replace the Card Reader part # 299P271010. 7. (LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). 8. (LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A 9. (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C) See Service Tip VS-78A
Sep 08, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Lg tv will not turn on it is a micro projection 55 inch hd dlp xd hit power a hundred times and it will eventually turn on but this is what it does it will blink yellow the bulb will light up screen will...
Have you actually replaced the lamp first? A weakened lamp will often cause random shutdown or troubles during initial firing of the lamp. The LG televisions will be just the bulb itself not the complete lamp assembly. It's not hard to replace the bulb as long as you first allow the TV to cool down for a minimum of an hour. Then you will want to handle the lamp with latex gloves on to avoid getting oils from your skin on the bulb. You can find your bulb replacement at http://www.partstore.com
Nov 12, 2009 | Televison & Video
I have an LG DLP. that turns off after 15 -30 seconds
If the second light is blinking to orange or red, that is usually the lamp indicator light on an LG DLP tv. That indicates your bulb needs replaced, or something surrounding the bulb has failed (like the cooling fan for the bulb for example) IF you have a spare bulb handy, I'd replace the bulb, keeping in mind if you touch any part of a new bulb with your bare hands, you just cut the life of the bulb by more then half.
Jul 30, 2009 | LG RU-52SZ51D 52" Rear Projection...
3rd lamp purchased within 2 yrs
There is a slight chance that you might have an issue with a defective ballast, I mean 3 lamps in 2 years, it's too much. The best way to go here is replacing the ballast, that might solve the issue.
Jul 25, 2009 | Mitsubishi WD-62327 62" Rear Projection...
TV was working earlier, today came home no green power light no nothing
I looked up the manual online - after you replace the bulb, you need to reset the bulb life timer. Using the TV remote push the menu button, SETUP menu, select the lamp reminder option to reset the hours to zero. That might help the status indicators.
Sep 04, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Panasonic PT-50LC13 Power Light Blinking Yellow
My Panasonic PT-50LC13 when turned on has a green light for a few seconds you can hear the fans turn on and then you have a yellow/amber light that starts to blink 8 times i have replaced the bulb and the door is closed any ideas?
Apr 01, 2008 | Panasonic PT-50LC13 50" Rear Projection...
NEC VT 470 projector won't work at all
Try pressing the HELP button. Don't release and press the power button. The LED lights should blink. Release then try to power on again.
Jan 11, 2008 | NEC Replacment Lamp Projector Lamp for...
TV will not power on 4 red blinks
I found the following suggestion on avsforum.com and it worked perfectly (going through the lamp door).
Nate
Quote: Originally Posted by Civicsixxx After some digging around I found that four blinks means there's a problem with a fan. I took the back cover off, used a screw driver to manually spin the fan near the lamp a few revolutions, plugged it back in and it powered right up! I guess it was just stuck or something. I'm a longtime lurker not much of a poster, but this happened to me to yesterday. I used civicsixxx's advice and this works. However you don't have to take anything apart. All I did was take out the lamp then put your hand in carefully to the right and you'l feel the fan just give it a spin and plug back in the light and the TV your good to go. Hope this helps.
Dec 12, 2007 | Sony KDS-R50XBR1 50" HDTV
TV doesn't turn on
You really should give make & model number when posting, it helps us immensely, your lamp and possibly the ballast is bad, start with a new lamp first, odds are very good that it will fix your problem, can`t help more without manufacturer and model number, good luck, ps, order the original lamp, generics are junk and a waste of your money.
Nov 27, 2007 | Televison & Video
603 people viewed this question
Top Dream Vision Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Marvin
Marvin
Are you a Dream Vision Office Equipment and Supply Expert? Answer questions, earn points and help others
