Question about Abit nForce2 NF7-S2 Motherboard
Power switch 760M02-GX-6LRS needs the wires putting back onto board ie:power switch reset hdd lite ect
  • 7 more comments
  • mirrorman Dec 12, 2007
    tnx for the reply
  • Anonymous Feb 22, 2008
    I bought an M6VCT motherboard at an garage sale and the guy who sold it to me didnt have the manual for it so I'm trying to find out how to hook up the power switch, HDD, reset, and so forth on the motherboard.
  • Anonymous Apr 29, 2008
    reconnect power switch leads to motherboard
    need diagram of connector positions
  • Anonymous May 23, 2008
    cannot find how the wires go back on the fpi pins on motherboard
  • Anonymous Jun 20, 2008
    Same problem but on a 6100K8ma, yoy guys have any diagrams??
  • cliveargyle Jun 20, 2008
    The same problem but on a WinFast 6100K8MA, you guys have any diagrams showing where to plug in Power SW, LED -/+ and reset??
  • Anonymous Nov 12, 2008
    I cannot frind the pins for the powerswitch
  • Anonymous Feb 24, 2009
    leads ???? for power
  • Anonymous Mar 21, 2014
    manual for user
  • 4 Answers
You could try searching for the manual for the motherboard, I have the same problem every time I disconnect a motherboard.
Sometimes it is printed on the motherboard in dead small writing which wire goes where.
Also usually motherboard manufacturers follow the "unofficial" standard io connectors.
+PLED -PLED +PSW -PSW NC NC NC NC
+HDD -HDD -RST +RST +SPK NC NC -SPK
Key:
PLED = Power LED/Message LED
HDD = Hard Drive LED
RST = Reset Switch
PSW = Power Switch
SPK = Speaker
NC = Not connected (sometimes not even there)
Note quite often the Reset switch is the reverse of everything else! (i.e. on most if the + is on the right the + is on the left for the Reset
The USB ones usually always follow the following standard
VCC -DATA +DATA GND NC (USB1)
VCC -DATA +DATA GND NC (USB2)
And usually one of the NC pins is no pin as some USB cables have that pin blanked out to ensure you connect them the right way. Note also with USB you start with the VCC then you go straight to negative data, then positive, then ground (again the - and + data bits, like the reset are in reverse of normal reading - the are right to left, not left to right!)
Finally if your not sure which cable is + and which is - the - ones are normally either black or white (most of them are white, except the speaker ones which are black - I presume that goes back to the colour scheme of red and black for positive and negative in audio equipment) and the + ones are normally some colour.
Posted on Nov 14, 2008
    Problem Solver:
  • 18 Answers
Just look for the manual of the model that you have. That is the only way you can connect it correctly. Look in the internet or the motherboard brand website itself, it surely provide the necessary documentation that you need.
Posted on Dec 12, 2007
Motherboard
The front of your computer is the Front Panel
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to; is the Front Panel header.
What you are asking for is a Front Panel header pinout.
I do not have the exact Front Panel header pinout, for your motherboard.
Tell you what I do have though..........
Looking at the Front Panel header on the Ebay link, for the Winfast 760m02-GX-6LRS; the Front Panel header looks to be below the CMOS battery, and close to the Bottom edge of the motherboard.
(Motherboard installed in computer case)
Black rectangular strip of plastic, with contact pins sticking up.
Also looks to be a GENERAL set-up for all Winfast motherboards.
(COULD be wrong here)
This is what I am referencing off of,
http://www.devhardware.com/c/a/Motherboards/Foxconn-Winfast-NF4SK8AA8EKRS-Motherboard-Review/3/
Go to the third photo down. Here you see the Front Panel wires, connected to the Front Panel header; on the motherboard.
(Below round CMOS battery)
Note that the contact pin on the Bottom row, and all the way to the Right; is NOT being used.
(I'm using a 26 inch HDTV as my primary monitor, so it may be easier for me to see)
Now look at this Front Panel header pinout, for another Winfast motherboard,
http://www.techsupportforum.com/forums/f15/winfast-mobo-front-panel-connection-558456.html
(Scroll down a little)
PWRLED is for the Power On LED (Light)
PWRSW stands for Power On switch
HD-LED stands for the HarDDrive activity LED (Light)
RESET stands for a Reset switch, IF USED.
Note where it has a Positive ( + ) sign, next to the pin for the PWRLED.
This is the pin the + wire from the Power On LED connects to.
It is the SAME for every LED that connects to the Front Panel header.
Let's number the contact pins, to make the explanation easier;
Starting at the Left side, Top row; going towards the Right;
Pins 2, 4, 6 and 8. There is NO Pin 10.
Starting on the Left side, Bottom row; going towards the Right;
Pins 1, 3, 5, 7, and 9.
Pin 2 is for the Positive wire.
Pin 1 is for the Positive wire
If the LED's are dim, (PWRLED, and HDD LED), OR; the LED's do not light up, switch the wires around.
(Pin 9 is N/C.........Not Connected. This is probably a 5 Volt test point, that was used by the factory)
There is a method you can use though, and find out what the individual contact pins are, in the Front Panel header;
Use an LED with two wires
Computer (Power Supply) plugged into power, go along the top row, and touch two pins at a time, with the two wires of the LED.
Example; Pins 2 and 4, as shown in the pinout.
Did the Power Supply come on?
No?
Go to the next two pins. Try again.
When the Power Supply comes on, you naturally know that is the two contact pins; for the Power On switch.
DO NOT touch them again. In fact connect the Power On switch wires.
Power Supply on, computer running;
Now go back along again;
1) LED light blinks?
You have the HarDDrive activity LED, contact pins.
2) LED light stays on?
You have the Power On LED, contact pins.
3) Computer restarts?
Those are the Reset switch, contact pins.
4) Nothing happens?
May be contact pins for a speaker, or contact pins that are not used.
(Speaker is for hearing BIOS Beep Codes.
You have a Piezo buzzer, to the Left of the CMOS battery; for that)
Post back in a Comment, as to the results.
If possible, I would like to ask upon you; to post the Front Panel header pinout; when you find what it is.
That way when a person in the future also has this same problem; the solution will be posted on the internet, for them to find.
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 30, 2013 | Leadtek Winfast 760m02-gx-6lrs Socket 754...
I need drivers for windows7 32bit
you will find it on the manufacturers website
Jan 23, 2013 | Foxconn Winfast 760gxk8mc 760m02-gx-6lrs...
Can i upgrade the ram
if you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
you should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible
hope this helps
Sep 11, 2012 | Generic 760m02-gx-6lrs - Winfast...
Winfast pc760m02-gx-glrs motherboard layout
Read the manual and it will tell you the process.
Get onlineand got to www.google.com In the google search box type: "WinfastSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Look for manuals throughout the site.
Jun 05, 2012 | Leadtek Winfast 760m02-gx-6lrs Socket 754...
Hi ! I've got a Winfast 760M02-GX-6ls
First, ensure that the leads from the motherboard to the internal speaker are connected.
Second, try "flipping" the connector, at one end, to make sure that you got the "positive" and "negative" leads correctly connected.
Third, put a multimeter onto the leads on the motherboard, and then turn the computer on,
and watch to see if the multimeter records any voltage where the "beep" should be.
Fourth, try replacing the AMD CPU, if only temporarily.
Aug 02, 2011 | Computers & Internet
661m04-mx-6l foxconn motherboard i need a diagram to tell me where the pins go onto the motherboard the ground ones reset power hdd ect ect ect.
All motherboards use the same pin connections for the front panel switches and led's.
There is a nine pin connector. 5 pins on the top row 4 on the bottom.(orient the board to get this view)
Starting with the top row , Pled+, Pled-, PWR SW, Ground. empty pin.
Bottom row. HDLED+, HDLED-, Ground, Reset, dummy pin.
Jan 09, 2011 | Computers & Internet
Motherboard wire hook up I pulled the wires : Power LED, Power SW, H.D.D. LED off the motherboard, don't know the pattern to put them back on.
its simple, start from left power led next to power led is power switch, just below power switch put hdd and next to hdd put reset . thats it done.. all boards have the same module.....
Nov 24, 2009 | Computers & Internet
Winfast 760m02
I HAVE VGA AND AUDIO DRIVER FOR MODEL NO:PC 760M02-GX-GLRS
PLEASE HELP ....................
Aug 19, 2008 | Computers & Internet
Abit nForce2 NF7-S2 Motherboard Logo
1,182 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Rommel Balcita
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
