Question about Olympus FE-170 Digital Camera
Olympus fe170 lens stuck
The lens of my camera tries to come out when i turn it on, and it does, but not all the way. it makes noises like its trying to but then it just shuts off. i have to press the button to make it go into review mode so the lens will go back in and turn it off.
  • Anonymous Dec 17, 2007
    Same problem lens comes out and makes a noise but no picture is seen. I have to press the review button to get it to turn off.
  • bobob Dec 22, 2007
    I have the same problem - I bought the camera less than a year ago and it broke a couple of months afterwards, so I sne tit to be repaired and it came back working ok, though now it has happened again - when I turn it on the lens extends and then the screen freezes and the lens stays stuck out. Very frustrating
  • Olympus Master
  • 4,738 Answers
The following blog outlines some repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Dec 23, 2007
The lens won't come out - it makes a buzzing noise but won't open. Like it's jammed?? Olympus FE-46
Hi.
This error indicate that focusing ring got stuck or jammed. What you can try to do is spray some compressed AIR into the lens to try to free up any sand or dust that may have worked its way in. If that doesn't help, you can gently bump the camera to try to free the focusing ring.
or.......
You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Good luck and have a nice day.
Rating the solution is highly appreciated.
Jul 04, 2011 | Olympus FE-46 Digital Camera
Is there a reset button on the Olympus fe -26? Mine froze and will not turn on, just makes a noise like maybe the lens is trying to move but nothing happens.
It seems is a lens erro for your camera, and none reset will helpful, and you can read these 2 article maybe helpful: lens error E18 and turn off and on again Commonly, there is something loose inside the lens, such as a screw. So when you try to start it, it makes noise.
Apr 30, 2011 | Olympus FE-26 Digital Camera
My camera lens won't go in and makes a funny noise everytime you try to turn it on. what's wrong?
my camera fell and tried to get the lens inn and now makes a funny noise and does not open
Jun 25, 2010 | Olympus FE-20 Digital Camera
Olympus 5020 lens stuck, turns off after power
Please check if the digital camera batteries in it are effective,if the battery have compatibility problem ,no strong enough power or voltage,the refered satuation maybe happen.Change the olympus battery for a new one ,then try again. After use some years ,the olympus battery life usually end.
Jun 02, 2010 | Olympus FE-140 Digital Camera
When I try to turn on camera it makes funny noises, the lens tries to come out and open but seems to be stuck, after a couple of attempts it stops and turns off, What can i do
My Olympus Camera when switched on the lens comes out and in 4-6 times then it goes off without the LCD screen showing anything, please help me repair it. my address misiani_bon@yahoo.com
Aug 24, 2009 | Olympus FE-280 Digital Camera
Olympus Fe-310, lens is messed. Possible sand in it but not sure.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 14, 2009 | Olympus FE-310 Digital Camera
When I power on, the lens keeps going in and out repeatedly
Turn on camera, makes grinding-type noise, then lens goes in and out several times...try to put your camera in a table lcd side down and turn it on...while lightly tapping on the sides of the lens. also try to check out this link
http://www.olympusamerica.com/cpg_section/cpg_servicerepair_warrantyinfo.asp
Nov 26, 2008 | Olympus FE-230 Digital Camera
The lens on my Olympus m760 camera is stuck in its out position. Even When i turn my camera off or take the battery out, the lens stays fully zoomed out and makes a funny noise like its tyring to retract....
this is probably caused due to a fall or so.. try to technically have a 360 look at the sides of the lens were at one instant u will notice a slight droop.. now u have to carefully push the lens in carefully with **** like motion for which a click noise will be heard... and will go back in...
Sep 16, 2008 | Olympus Cameras
Olympus FE-190 lense
If the internal lens barrel gets knocked out of alignment it will cause that condition. If the camera senses that the lens is not in the proper position or not moving, it will turn back off rather than cause more damage. Pushing on the lens barrel to try to fix it will usually cause more problems than it already has. It has to be disassembled to be repaired.
at this point you may also want to check on your warranty status.
Aug 05, 2008 | Olympus FE-190 Digital Camera
IR-300 Olympus
I had what sounds like the same problem. The camera was dropped and the shutter was stuck open. Just kept showing error message.
As I felt I had nothing to lose I began tapping it on a soft book and the shutter started to appear. I then shut it just using the end of my finger. When I then turned the camera on again it opened and shut when turned off. It has worked fine ever since.
Seems a rather poor design.
Hope this helps. Very best regards Peat.
Jun 05, 2008 | Olympus i:robe IR-300 Digital Camera
Olympus FE-170 Digital Camera Logo
325 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
