I moved and now have satellite without a cable antenna. Can I tape from satellite onto my Sony SLV-D100 VCR? My satellite stations are 4 digits and my VCR won't let me input 4 digits for the channel. Help!!
    Problem Solver:
  • 10 Answers
The easy way is video out of your satellite box or tv monitor. Take this output to any of the video lines in on your VCR.
Posted on Dec 13, 2007
Have Sony VCR model SLV-N80/N70 . Cannot get it to record using Samsung TV model SLV-N80,N70.
The television has nothing to do with recording. It is only required for playback. There are a number of possibilities depending on what equipment you have. Do you have cable, satellite, antenna? Your signal source has to be connected to the VCR either through the cable connector, or RCA video jacks.
If you have straight cable, connect the cable to the "ant in" connector on the VCR. The VCRs tuner will select the channel you want to record. If you are on antenna, you will need a Digital set top box (STB) to receive any channels.
If you have a satellite, cable box or digital STB, you must go from the output of the box to the input of the VCR. You can use the standard coax cable,but I would recommend using the audio/video cables for better quality. If using coax, the VCR will have to be set to either channel 3 or 4, depending on the boxes output setting. Using A/V jacks, the VCR will be set to "Line" or "Video" input.
Feb 26, 2011 | Sony SLV-N70 VHS VCR
Sony SLV-D100 DVD Player / VCR Combo Remote not working.
Try a universal remote to determine if it is your remote or you combos IR reciever.
Jul 22, 2010 | Sony SLV-D100 DVD Player/VCR
Help SLV-900 has a screen that randomly flickers and wont play
Advice given has helped me to sort out this problem thanks
Mar 07, 2010 | Sony SLV-D100 DVD Player/VCR
I have a sony slv-d100 combo. DVD works fine, vcr NOT!
this is a mecanical problem, is some gears is broken.
Pease send to repair shop, to check
Nov 27, 2009 | Sony SLV-D100 DVD Player/VCR
How do I record from a VHS to the DVD?
Here is a link to your DVD recorder operation manual.
You can download the file of you choice.
Oct 11, 2009 | Sony SLV-D100 DVD Player/VCR
I have a Sony SLV-SE 710B VCR and a Sony Bravia HD TV I now wish to record my videos (about a 100) onto DVD. What Sony DVD recorder will take the output from this VCR and put it onto disc or do I have to...
You need to buy Sony DVD Recorder and hook Sony VCR to that dvd recorder and burn DVD directly. You can also watch VCR tape movie on TV via dvd recorder while its being burn on dvd.
Click Sony Style to select DVD recorder.
May 11, 2009 | Televison & Video
Sony SLV-D100 DVD/VCR unit won't record on a VHS tape.
Check the tab on the VHS tape be sure it is there. If not place a [piece of transparent tape on it to simulate the tab and try again.
Oct 02, 2017 | Sony SLV-D100 DVD Player/VCR
Recording tv programs etc
I had same problem. With mine i could record wo the digital cable box but not with it hooked up. Would love to get some info about it.
Apr 27, 2008 | Sony SLV-D350P DVD Player/VCR
First make sure you are hooked up in back. You can go either way. Cable out to tv, Cable or RF in from antenna should be from what you are using like cable, satellite, or just antenna. Then you should have set put on channel 3 or 4 and you can switch that in back of VCR also. Then if you don't see picture on screen with vcr on then find channel that you are coming in on like for satellite you need it to be on 3 or 4, cable you can just put it on the channel you want to record. The other way are from Video Jacks the red, white, yellow. If this is the way you are hooked in then you should look for video 1, 2 or which ever you are hooked into and find on set. then look on vcr for video or aux 1, 2 or depending on the one you are hooked in to. Hope this helps. If not then tell what you are using and what you have done so far!
Aug 16, 2007 | Sony SLV-998HF VHS VCR
Home theater reception
you need to unlpug your set and reconnect everything over and see what it does.if that does not work have a tech check your system.your sony recviever is the culprit let that be checked.good luck
Apr 05, 2007 | Sony KP-53XBR45 53" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
