Question about Toshiba Satellite 5105-S501 Notebook
Toshiba wont power on
I have a Toshiba Satellite 5101 laptop and it will not turn on. Originally, my video card was not working properly; my screen had a bunch of weird lines accross it. I then opened the laptop to see if the video card had come loose. After I put it back together, it did not turn on. When I plug the power cable, both the battery indicator and the power cable indicators light up. Then when I try to turn it on, the power cable indicator starts to flash (orange). Does anyone know what is going on?
  • 3 more comments
  • ccortez08 Dec 12, 2007
    So I checked every connection and made sure that they were properly secured; however, this did not solve the problem. This time, when I tried powering it on, it momentarily began to start up (for about 2 seconds) and then it shut off. Then, the orange LCD power cord indicator starts to flash indefinitely. Now, when I press the power button, it does not start at all; no response. Any suggestions on what is going on?
  • ccortez08 Dec 14, 2007
    Ok...once again I took the computer apart and put it back together. Once I did this, I hit the power button and this time it turned on. It works except for some minor details. This time, the fan is spinning faster than normal and it will not turn off (before, it would turn on and off as needed). Also, I think my video card is going bad. The computer randomly goes into a "low resolution" screen mode. Once I restart, it goes back to normal. What do you think is going on?
    So most likely the video card is not defective?....How do you know if the video card is defective?
  • enjer Jan 24, 2008
    hi!! i think i have the same problem!! i was working less than an hour and the she just turned off! y tryed to power upthe computerbut the orange LCD power cord indicator starts to flash indefinitely. Now, when I press the power button, it does not start at all; no response.maybe you can help me!! my laptop si a toshiba satellite 5205-sp505
    I have a Toshiba Satellite 5205-s505 laptop and i was working adn suddenly it just turned off, i removed he battery and re-instal but nothing happend . When I plug the power cable, cable indicators light up and the battery was ok, both were green. Then when I try to turn it on, the power cable indicator starts to flash (orange). Does anyone know what is going on? the orange LCD power cord indicator starts to flash indefinitelyand the battery indicator is off. Now, when I press the power button, it does not start at all; no response. Any suggestions on what is going on :(
  • 26 Answers
My brother reflow the solder on several of the memory chips on the video board for my wife 5105 s501 and it fixed the problem that we were having with the video. If you do a search you will see that the video card is the weak link on this laptop. Kinda doubt if you could find a good use video card for this laptop. I would worry that any used video cards for this laptop will also have problem.
Posted on Oct 24, 2008
Hi Folks,
I have a Toshiba 5101-S501 and gave me the same problem. I wanted to replace my Video Card, but unfortunately I am not getting the Card (Nvidia Geforce4 440 Go) at all. Can someone help me if I could get the same Video card in your country? Can I replace with some other Card? Please help me!
Thank you,
Ron
P.S. Can someone sell your Card?
Posted on Oct 15, 2008
    Sergeant:
  • 324 Answers
Good afternoon!
From what you have told us, I would suspect that something got jiggled or joggled during the opening and putting back together process. I've done that to myself, in the past. ;o)
What I do in a case like this is as follows:
1-Power down and remove the battery (Leave the battery out until you get it running again)
2-Open it back up and disconnect and reconnect each and every cable and connector that I can find.
3-Remove and reseat the memory module(s)
4-Try to power back up.
If this doesn't do it, get back to me for some more diagnostics/ideas.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thank you, and have a super day!
Ron-
Posted on Dec 11, 2007
  • Ron Roske Dec 12, 2007
    OK! Looks like we're going to have to take a little time and earn our pay on this one.
    Let's take it down to "barebones" and see what happens.
    By bare bones, I mean to disassemble to the
    point that you only have the a/c adapter, motherboard, 1 stick of memory and
    the display hooked up. Be sure to remove the battery and leave it out until we are done with this procedure. At this point, if it doesn't come up farther than it
    does at present, you more than likely have a bad motherboard.
    If it does show signs of life, start reconnecting one item at a time, and try
    to power up after replacing each item or connector. If you replace/reconnect
    something and it no longer does anything, you have just located the part that
    is bringing your system down.
    Using this approach, I have seen memory cards, hard disk drives, keyboards,
    mice, touchpads, floppies, cd readers all cause this type of problem.
    Ron-
    Sergeant:
    Champion:
  • 317 Answers
You might have snapped a cable with you re-assembled your LCD, check for that.
Do you have more information or questions?
The more information you provide to us, the better we can help.
Thanks!
  • Baja Data / Jay Arias-Chavez
    Drivers for the screen must be reloaded. Normally video cards don't default to low resolution.
    Video cards; they either work or don't.
    They don't 'kind of' work. Driver reloads from scratch work wonders!
Satellite - LED light on with AC power cord but blank screen and doesn't turn on
video card is the number 1 issue for Toshiba satellite models, need to reheat the mounting of the video card.
avoid disassembling the unit, what I did was.
*blow dryer (for the hair)
1.use the blow dryer to heat up the side of your Toshiba, point at the exhaust, located on the left side, do this for 35 seconds.
2.after using the blower, turn on the power button again and see what happens =D
hopefully it will work.
NOTE:
I had the same problem and it solved the issue.
Jul 09, 2014 | Toshiba Computers & Internet
Laptop screen lights, no display but exterior vga plays
either bad lcd panel or the power inverter for the lcd has gone bad.
Mar 27, 2014 | Toshiba Satellite L775-s7307 Laptop...
Intermitently, my screen goes dark, but the
1.)It could be your video card
2.) Yes it is expensive for a laptop
3.)I would first check your screen setting for turning off display...
If you are using vista:
-Right click on your desktop then choose personalize
-Then click screensaver
-On bottom click on "change power settings..."
- On the left click on "choose when to turn off the display"
Your monitor can turn off without your computer being in sleep mode.
Dec 26, 2009 | Toshiba Satellite A105-S4334 Notebook
Toshiba laptop P100-ST9612 majors problems--NOT fixed by Toshiba.
oooo man that ones a doozy, if its the one with the go9700 video card its a pretty bad model. the card brand new is 700+ from toshiba. i have run into that problem quite a bit.
Nov 30, 2009 | Toshiba Satellite A105 Notebook
I have a Toshiba Satellite A305D-S6848. Last
Connect an external monitor to your laptop. Start your laptop and use Fn+F5 buttons (or those appropiate to your model) to send the video signal out to the external monitor. If you do not get any image on the external monitor it means that most probably the mainboard is damaged (video card or even more). Expensive to fix or replace. Have it checked by a professional.
Oct 06, 2009 | Toshiba Satellite A305D-S6848 Notebook
When I turn the computer on the screen doesn't work
This is the monitor not being attached to the Graphics Card properly.
Sep 14, 2009 | Toshiba Satellite M45-S331 Notebook
try turning off and then remove battery and plug in a/c cord.turn back on..still nothing let me knowRICHARDM69
Aug 24, 2009 | Toshiba Satellite A135 Notebook
Screen Issue
I would check to see if the RAM has become loose, if you can reseat the RAM. Do you hear any beeps when nothing is displayed?
Aug 18, 2009 | Toshiba Satellite M35X-S161 Notebook
Describe your Toshiba Satellite® L10 PC
You most likely have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 04, 2009 | Toshiba Satellite L10 Notebook
Monitor not showing anything
Man your toast. Google JB Technologies, they specialize in laptop repair. Good thing you admit the water thing b/c alot of latops have a special chem on the motherboard that changes color if exposed to water or liquid.
Jul 29, 2008 | Toshiba Satellite M45-S165 Notebook
Toshiba Satellite 5105-S501 Notebook Logo
343 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
