Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
Disc drive on Macbook
My disc drive on a 13" Macbook won't accept a disc. it just doesn't grab it like it's supposed to.
  • 36 Answers
Try starting up your macbook while holding down the trackpad button.
I have had the same experience with my macbook (because of impact). it will have to be pushed in most of the way before it accepts it. You may have to wait for it to start working by itself.
Posted on Jan 11, 2008
  • 382 Answers
If you machine is a CORE2DUO, you should still be under applecare and a local applestore or certified service shop should replace it for free, if not, you may need the drive replaced or bypass it and purchase a firewire external.
Keep me posted.
Posted on Dec 13, 2007
How to put my mac book pro back to factory settings without reinistall disc
Use Disk Utility to erase the hard drive. ... The process of resetting a Mac or MacBook tofactory settings gets rid of all your data ... This cloned drive can be re-cloned back to the main drive if you decide to restore your Mac, or it can be used to ... This means it will no longer be linked to your iTunes account. MacBook supportnumber 1 800 726 0294 Apple Technical Help
Sep 13, 2017 | Apple MacBook Pro 13
Software disc is too small, macbook pro will not accept the disc
Hi, if the Macbook can't read the Mini discs, you can copy the contents of the Mini Disc to any USB Flash Drive by inserting the Mini Disc in any Desktop Computer's CD/DVD Drive. After copying the Mini disc contents to USB Flash Drive you can install in the Macbook pro. var geo_Partner = '843689b9-ba30-459d-9c4b-876924715b22'; var geo_isCG = true;
Jun 11, 2011 | Targus Portable USB Notebook Mouse &...
My Macbook 3,1 superdrive slot load optical disc drive won't accept CD's of any kind. The disc will physically get all the way in the drive (as in I cannot see any part of it or push it in any further) but...
There is no need to force the disc into the optical drive. You should be able to stick half of the disc into the optical drive and it should see it, grabbing it the rest of the way in.
But it sounds like the optical drive is failing and it will need to be replaced.
Dec 18, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I have macpro problem is my disc is not working with the eject is not still my dish is inside of my disc unit how can i remove manually pls. give me instruction properly thanks lot...
Thanks for contacting Fixya Support.
With the Macbook Pro 13" having a Superdrive or Combo optical drive, you are dealing with a slot-loaded drive. As a result, if you have a disc that is loaded into your optical drive, which will not eject, then there isn't a manual way to remove the disc without causing damage to either the optical drive or the disc itself.
In most cases, of a potentially stuck disc in a Apple notebook's optical drive, a visit to your local Apple Retail Store Genius Bar or local Apple-authorized service center would be highly recommended.
With that noted however, here are some troubleshooting steps to try from the Mac OS X side first before having to take that step and visit an Apple service provider:
- - Reboot your Macbook Pro 13"
- - Hold down your Media Eject key on your keyboard pad prior to the Apple Chime starting.
- - Keep holding the Media Eject key down while your Macbook Pro 13" boots up
- - The disc should eject before you reach your Desktop
- - When it does, simply release your Media Eject key.
If that does not work, try this:
From your Desktop:
* Click anywhere on a blank space on your desktop. Now you should see Finder listed near the Apple menu icon.
* From the Finder menu, click on Go, then Utilities from the
drop-down menu. This will take you to your Utilities folder.
* Locate and open the Terminal application.
* At prompt, type: drutil eject and press the Return key on your keyboard
This command line should eject the disc from the drive, unless there are mechanical issues with the drive.
If neither of these steps work, then I would be remiss as an Apple Certified Tech, if I did not recommend you proceed to take your Macbook Pro 13" in for service.
I hope this helps.
Best Regards,
Aug 26, 2010 | Apple MacBook Pro Notebook
I want to upgrade from leopard to snow leopard
hello, and yes it's surely the optical drive. You will have to change it or plug an external drive to read the disc.
Jan 16, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Switch on - screen is grey with flashing folder with questionmark
Hard drive is dead or the signal from the hard drive is not being read by the ide controller. I'm working on a MacBook 13 inch right now with the same issue. I had a spare hard drive and a windows Vista disc, so I installed the hard drive and inserted the vista install disc and the laptop loaded and installed Vista on the Mac with no issues. I took the hard drive from the Mac and attached an adapter to it and ran it through a usb on another laptop and the laptop could not read the files on the, the drive was bad.
Oct 24, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
My macbook isnt reading any discs.
There seems to be a problem with the superdrives in the MacBooks. I had mine replaced under extended warranty last month. If your Mac is under warranty, bring it in to the Apple store.
Several macbook users in the past have had success with their optical drive reading disks by turning the laptop upside down and then inserting the chosen CD. Might as well give that a try in your situation.
Drives are available online. Let me know if you need instructions on how to r/r the drive.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 18, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
My MacBook has started to make a whirring noise similar to what it does when it is loading a disc, but there is no disc in it.
check that anymaterial stuck in the drive insert disk and iject if problem persist go to your service provider
Apr 27, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
My macbook doesn't burn dvd with iDVD program
Hello, this can happen when the DVD's are not recognized by your Macbook, please check in apple menu, about this mac, more info, and cd/dvd player to see what dvd can your mac accept
Mar 24, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
My macbook will not start up. It just keeps the apple logo and the "thinking" symbol.
Start up from the OSX disc by holding down the 'C' key on powering on. From the top toolbar, select 'Disc Utility' from the 'Utilities' menu.
Select the hard drive in the left hand column ans run 'First Aid'.
This will diagnose and repair any problems with the hard drive unless the drive is beyond recovery, in which case you will need to replace the hard drive.
Jan 12, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
71 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
