Question about Samsung 26.0 Cu. Ft. Side-by-Side Refrigerator, RS265LABP
Refrigerator warming up, frozen coils, works for two weeks then warms again
I manually go into the refrigerator and blow dry the coils to defrost them. Lasts for about two weeks then starts warming again. This refrigerator has the control panel on the front so I don;t know how to manually start a defrost cycle. This model also has a history of being affected by power surges that zap the computer. Would a surge suppresor help with that?
Thanks.
  • burbwil May 12, 2008
    defrost heater not working. How can I manually start a defreost cycle to check?
  • J Sonnier May 12, 2008
    I have a RS2533SW Samsung and the Refrigerator Side freezes up and I too have to defrost every couple of weeks. Can someone point me to the Defrost Relay or let me know what parts or where to find parts.
    Scholar:
  • 149 Answers
Surge suppressors assist in not getting the equipment zapped but id check the condition of the defrost heater if your handy with an voltmeter u select the audible tone and check the defrost heater make sure that power's disconnected. if you put one lead of the meter on one side of the heater and you put the other lead of the meter on the other side and there's a tone its good if not bad heater element. if the unit uses an adaptive defrost board suspect the board bad replace that board plus defrost thermostat.
Posted on Apr 19, 2008
I have a Jenn Air JCD2289AEW side by side refrigerator. The freezer has not been cooling properly for a few days. Now the refrigerator seems to be maybe less cool than it should be. I still get cold air...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 16, 2011 | Jenn-Air JCD2389G Side by Side...
Food defrosted pulled away from wall improved then defrosted again. Un plugged for day in case frozen somewhere, plugged back in and worked for a day. Now defrosted again. At times fridge has frozen food...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Feb 23, 2011 | Frigidaire Gallery Series GLRT83TEK 30"...
Amana refrigerator, bottom freezer. Back keeps icing up. I have unplugged and thawed it twice, within 2 weeks it is frozen again and freezer warm
This is a defrost problem most likely caused by a defective defrost thermostat. It is located in the freezer compartment behind back wall on top right hand side of coils and usually has a brown and an orange wire connecting to it. It should have continuity when checking with a volt/ohm meter when it is frozen and read open when it is warm.
I have seen many of the newer electronic temperature model bottom mounts with defective control boards as well that cause the fridge to skip the defrost cycle.
Jun 14, 2010 | Amana Refrigerators
Refrigerator is warm, but freezer works. Coils are frozen.
you are having a defrost problem, probably needs if it is a maytag, it probably needs a control.
Jun 15, 2009 | Maytag MBF2556HEW / MBF2556HEB /...
Refrigerator warm and defrost heat sheath and coil frozen solid
check see if you have frost build up in freezer could be the heater or defrost thermostart or timer board call service
Feb 07, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Refrigerator on the fritz
The defroster is not working. Ice build up prevents cold air from the freezer chest from blowing into the lower part.
The way the defroster works is this: There is a defrost timer, probably found under the refrigerator at the front, that turns on the defroster three times per day or so. That turns on a heater nested among the freezer coils. It keeps heating until the defrost thermostat gets warm; then it quits defrosting.
I think your defrost timer doesn't turn. You can turn it with a screw driver till you hear a click. Now your ice compartment should be defrosting. With ice buildup it may need lots and lots of defrosting. You might not get cooling back into the lower part for awhile, till the ice buildup melts.
By the preceding, you should know if the defrost timer needs replacing.
If you should need to manually defrost the freezer coils, they are, I think, under the floor of the freezer. To defrost them, I'm told, a hair drier works better than boiling water. The defrost thermostat is in there too, a one inch unit with two wires. It should have no continuity warm, closed circuit frozen. If it has open circuit frozen, that would be your problem.
Jun 14, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
178 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
