Question about GE WDSR2080D Top Load Washer
Water continues to fill
I have a GE washing machine (model WDSR2080D) that is less then a year old and a little stream of water runs even with nothing selected. When the washing machine is spinning, you can hear the water still running. Any ideas or suggestions would be appreciated.
  • 1 more comment
  • roadblock Dec 11, 2007
    After additional research, it appears that it is a "Faulty Water Inlet Valve". So, how do I fix and/or replace that?
  • roadblock Dec 12, 2007
    I went ahead and took the control panel off to find the inlet valve. I can say that it is the cold side solenoid based on this: I turned the water off, unhooked the cold water hose from the washing machine and stuck in into the basin. I turned the water on and there was no water coming from the washing machine, just the cold water hose. No continous running of water! So, I can't replace just the bad solenoid, I have to buy a brand new inlet valve ($54.95 on GE's website). Do you think that the test I ran was enough to eliminate any other problems that may exist? Thank you!
  • roadblock Dec 13, 2007
    I did some searching and found that part on eBay for $25 (brand new, same model #) and on a couple of other sites for less then GE's $55. Thanks for the help. I work with networks and told several of my clients and co-workers about this site. Outstanding job. Happy Holidays!!
    Champion:
  • 249 Answers
You replace 'that'by turning off water going to 'it'remove top of machine,take off hose's on valve,fit them to new valve,with the wireing,do it step by step.buy,eire
Posted on Dec 12, 2007
  • eamonn close Dec 13, 2007
    My test for water valves as a rule!If you can blow through them,replace them! wires and hoses disconnected of course!$55 a bit saucey but what can you do!
Water filling
sounds like a faulty cold water solenoid
Sep 25, 2017 | GE WDSR2080D Top Load Washer
When the water is entering the tub it immediately goes out the outflow. The tub will not even fill up a little bit. What could be the problem? thanks
The drain hose outlet must be located higher that any expected water level in the tub. If too low, gravity drains the tub as it is filled. Extend the (a) drain pipe up to the proper level, even if you are using a floor drain to carry away the water. Hope this helps!
Jan 27, 2011 | GE WDSR2080D Top Load Washer
My GE washing machine drains the water after the rinse cycle but does not start spinning. It just sits with the water pump running and does nothing. This doesn't happen with every load but seems to be...
Most likely the tube from the tub to the water level switch is full of "gunk" so the washer still thinks there is water in the machine, and therefore will not spin. Take the front panel off by pushing in the retaining clips at the top seam between the front panel and the washer top. Pull the thin hose off the left side of the tub and clean it out. (or cut off an inch or so, but you can only get away with that once or twice). To help prevent re-occurance, every two or three months you can fill the washer to the lowest level with hot water and several cups of bleach (no clothes) and run it through a cycle. Rinse at the ex-large setting to make sure all traces of bleach are gone before doing another load of laundry.
Nov 12, 2009 | GE WDSR2080D Top Load Washer
Water dose ot stop when washer is full. It continues to run.
If you disconnected power and water still flowed, replace the water valve. If water stopped flowing when power was disconnected, clean out tube from tub to water level switch.
Jun 07, 2009 | GE WDSR2080D Top Load Washer
GE top load will fill with water, not spin, agitate, empty water
very familiar with this look under machine if black dust found it has a broken motor coupler, very easy to change
Dec 22, 2008 | GE WDSR2080D Top Load Washer
Floods overflow tube when pressure hose plugs at outer tub
I usually see this problem from people who rarely or never use liquid bleach. To prevent recurrence, fill washer to lowest water level, hottest water, with several cups of liquid bleach, and run a complete cycle with no clothes. Do this once every couple months if you are in an area of the country with water conditions which seem to encourage the formation of the gunk that clogs that water level tube you mentioned. Sometimes switching to a different type or soap, fabric softener, or reducing the amounts of those will also help greatly. This should be a FixYa for your problem.
Dec 06, 2008 | GE WDSR2080D Top Load Washer
GE 1996 top loader agitation but good spin cycle
check the motor, the timer,the water level indicator in side the machine on the basket it will have a tube with a little box attached to it. It may be clogged or malfunctioning.
Apr 27, 2008 | GE WDSR2080D Top Load Washer
Washer continues to fill after full, then spills all over floor until manual shut off
This is an indication of a pressure switch malfunction. Post back with your washer brand name and model number and I can tell you how to check it.
Feb 23, 2008 | Washing Machines
GE WDSR2080D Top Load Washer Logo
107 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
