FixYa.com
Tags:
Umax Astra 3400 Flatbed Scanner
Vauxhall astra hazard lights perminantly on (by 3 users)
posted by dazza29 on Dec 11, 2007
hi there, i have a 51 reg astra and tonight the hazard lights are permenantly it. When i put the key in to te ignition and turn to position 2 the lights work normally. However, when i take the key out again the hazards are again permenantly lit? any idea? thanks.
Darren.Jackson1@btinternet.com
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Momac6, posted on Sep 04, 2008
I have a 98 Astra. The right hand indicator is staying on, not flashing, even with the key out of the ignition. The left hand one is working fine. Help!
Comment by Swigger, posted on May 29, 2008
I have a 51 astra automatic with a fault on indicators. When switching off engine all six hazard lights are lit all the time. To avoid flat battery i have to remove indicator relay. Have replaced multi timer but not solved problem. When ignition key is in and turned all is fine, after replacing relay.
Solution #1
posted on Mar 01, 2008
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
hi there, just happen to read the problem with your hazard lights. but does the indicators work ptroperly? if not. i would suspect that indicator or hazard lights relay is blown . you can easily replace this diy stuff.. get the part from your local auto parts shop.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Scanners problems?
power supply
I have a umax 3400 scanner. I... Answer This...
free driver for astra 3400
i din't get umax astra 3400... Answer This...
scanner test keeps failing
Hi, I have a Umax Astra 3400... Answer This...
Color trouble
I have had the Umax Astra 3400... Answer This...
it's not working AT ALL
it's saying i need to change... Answer This...
Repair Service
Find Scanner Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
