Question about Canon Optura 20 Mini DV Digital Camcorder
Canon MV500 I keep getting an eject tape message, the camcorder chews tapes. Can you help ?
  • 3 more comments
  • xflem Sep 12, 2008
    My Canon MV500 video camcorder write "Remove the cassette". This command shows up when I switch on both "Camera" and "Play". The camera is absolute useless now.
  • Jamasta Oct 26, 2008
    I get "remove the cassette" error whenever I turn the camera on.
  • caseycline Oct 29, 2008
    I have the same camera and suddenly started receiving the same message.
  • share_singh Mar 02, 2009
    i am having canon mv850i, i am facing the same problem of remove the cassettte. What to be done, how much i have to spend again for repair?
  • 3 Answers
Perhaps this will help some. I realized that this problem occurs on my Canon Optura 30 (consumer mini DV) when the tape is fully rewound. Tapes that are not rewound seem to work fine. If this situation applies to you, try the following, and make sure that in the future you don't fully rewind your tapes! Fast forward your tape in a tape deck or rewinder. It should play in the camcorder now. If you don't have a machine to do it for you, you can manually advance the tape with a pointy object and a pencil (the eraser--or your pinky!). On the back of the tape, near the top (that is, opposite the side where the tape is exposed), locate the notch between the two spools (the "wheels"). The notch will have a spring-loaded slider inside, which you can hold open to free the spools. Otherwise they are locked in place and you can't turn them. Holding the slider open with your pointy object, insert the eraser in the right-hand spool (i.e., when the exposed tape is pointing down and the "spine" of the tape is pointing up). Turn the spool slowly counterclockwise, making a few complete turns, to gather up a short length of tape, enough so you have a few seconds' worth of timecode. Be careful not to leave any slack. You can turn the other spool a little bit (clockwise) to catch any slack; lift the cover on the exposed tape (by holding back the little release) to make sure it is tight. If you're not sure which spool to turn, it's the one that does *not* have a window on the front side of the tape. (If the tape is fully rewound, the spool in the window should look full.) Hope that helps, and good luck. In the future, I'll heed the common advice to use the camcorder playback as little as possible, relying on a tape deck for RW/FFand making sure to transfer material to scratch disks ASAP and then just storing that footage away in a shoebox!!!
Posted on Jun 11, 2009
SOURCE:
When I inserted a new dv cassette into the camcorder to record - it chewed the tape then the "eject" message came up, I inserted a new tape and the eject message showed up again. I have also noted a whine...
This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly or a defective clutch in the take-up spool and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Oct 03, 2010 | Canon XM1 Mini DV Digital Camcorder
Canon zr300 ejects tapes
hmmm...the only reason that usually happens is when the tape is messed up internally, or there is something stuck in amongst the head
Apr 30, 2008 | JVC GR-D250 Mini DV Digital Camcorder
Loaded tape into Samsung VP-L700U 8mm and received 'Emergency Eject' message. Tape now chewed. Repeated & ruined several new & used tapes, including cleaner tape. Camcorder was working a half...
Internal mounting screws for the tape chassis may have come loose and can no longer hold the tape in the correct position. You will need to disassemble the camcorder to access the tape mechanism.
Nov 15, 2017 | Samsung VP-L700U Camcorder
Canon NTSC ZR25 MC Digital video camcorder eating tape how can I fix it
Canon NTSC ZR25 MC Digital video camcorder is eating the tape. I've loaded a new tape and get an "eject tape" message each time. Does anyone know how to fix this issue?
Jun 24, 2009 | Canon ES75 Camcorder
Canon ZR-800 Mini DV Camcorder tape stuck
The way I can get a tape unjammed on my Sony camera is to remove the battery, plug the camera into the AC charger that is plugged into the wall outlet. Then power the camera on, wait a few seconds. Then unplug the charger from the outlet, wait a few more seconds (camera still in "on" position) and then plug it back in. I have used this method at least 3 times to get the camera to release the tape and finally eject. However, the tape is usually pulled or stretched and I use a small flat head screwdriver to wind the tape back in, but expect that portion of the video to be ruined.
Feb 23, 2009 | JVC GR-DV800U Camcorder
Canon XM2 Chewing tapes
This seams to be the problem, all the time, plus the sound goes off on most of theses camcorders, and the only way they will work is with an boom, mic.
Could I use an tape clearer when it says eject?
Aug 02, 2008 | Canon DM-XM2 Mini DV Digital Camcorder
Mv800i camcorder
well there are certain cassettes made for that camcorder. i suggest you search for what the are called and then you can buy them
May 26, 2008 | Canon MV800i Mini DV Digital Camcorder
Eject tape message
We get the eject message and then it will not eject tape.  Any suggestions
Mar 04, 2008 | Canon GL1 Mini DV Digital Camcorder
Eating tape
Diferent speed on REW and FF drum. Must cleans tape way
Nov 05, 2007 | Canon MV550i Mini DV Digital Camcorder
Canon Optura 20 Mini DV Digital Camcorder Logo
779 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
