Condenser fan and Evaporator fan are running, coils defrosted but condenser clicks on for a few seconds but does not stay on and only warm air is distributed to fridge and freezer with both at 80 degrees. how do I know if I need to replay overload relay ($175) of if condenser is shot? Thx in advance.
Either your coil is frozen (which you say is not) or condenser fan motor has lack of oil and bearings are seizing up. Motors are throw away if that's the case. If your compressor is running the fan next to it should also be running.
SOURCE: fridge and freezer warm. condenser
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong.
If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Hi
Check
the back wall or floor of the freezer section for frost. Check the freezer (
evaporator) fan to see if it is running. Check the condenser coils under the
unit for blockage from dust. Check the condenser fan (under the unit) to see if
it is running.
If you have frost in the freezer there is a problem with the defrost system and
the freezer will start to warm eventually as well as the fresh food section. If
that is the problem you can check the defrost terminator, defrost heater/s, and
the defrost timer or adaptive defrost control If used on your unit or the main
control board if so equipped. These things usually require dismantling the
freezer and other areas of the refrigerator to be checked.
There
can be many factors for the no cooling factor: the condenser coils could be
blocked with dust, the condenser fan could be bad or stuck, the freezer fan
could be stuck or bed, the freezer coils could be blocked with frost because
the self-defrost system is not working or the compressor is not running because
of a bad relay etc.
Please
check this link to get a detailed idea about your issue:-
http://www.appliance-repair-it.com/refrigerator-not-cooling.html
Please
get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
If its frozen look to defrost control.
