Dishwashers
Problem for Dishwashers
Generic problem for all Dishwashers
The waste water backs up into the dis...
By richnew2 on Sep 14, 2009
The waste water backs up into the dishwasher when the sink drain appears to be intermittently plugged; there is no syphon break installed.
Best Solution
posted on Sep 14, 2009
Very Helpful)
Richie_asg1
Rank: Guru
Rating: 87%, 434 votes
Dishwasher manufacturers recommend a syphon break be fitted - but usually there is not a problem if your sink has an overflow pipe incorporated.
You have a partially blocked drain - causing wastewater to flow into the dishwasher instead.
Use 1/2 a cup of caustic soda or proprietary drain cleaner down the sink drain. Add about a pint of water, and leave overnight.
Next morning pour a full boiling kettle down the drain which should move things on and clear the drain.
You may have to repeat this process once, but is preferable to taking your pipework apart - which is next if this does not clear it.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Thank you I had a suspicion that was the problem. Very helpful. " - richnew2
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
kitchen aid model number kudco31vbs is it good
Answer
who makes the best trouble free dishwasher today that is 18" wide
Answer
Dishwasher control panel comes on and runs though cycle but actual dishwasher does nothing at all
Answer
unit appears to go through all the cycles, including pumping water into the unit and back out again.... (More)
Answer
water leaks from the bottom right corner of door of countertop model on the rinse cycle how can I... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
