Question about Compaq Presario 5000 PC Desktop
Video hardware error
I just bought a new Compaq SR5262NX . I set it up with my Sharp LCD Monitor LL191A-B. I keep getting a video hardware error when I am on my computer.
Product
Windows
Problem
Date
12/9/2007 5:51 PM
Status
Solution Available
Description
A problem with your video hardware caused Windows to stop working correctly.
Problem signature
Problem Event Name: LiveKernelEvent
OS Version: 6.0.6000.2.0.0.768.3
Locale ID: 1033
Files that help describe the problem (some files may no longer be available)
WD-20071209-1751.dmp
sysdata.xml
Version.txt
Extra information about the problem
BCCode: 117
BCP1: 849A0008
BCP2: 8B9E0E90
BCP3: 00000000
BCP4: 00000000
OS Version: 6_0_6000
Service Pack: 0_0
Product: 768_1
Server information: 7ae4d040-4e90-4f3f-a637-67bc0964aa5c
When I try to get a solution, it says "no solutions found"
Can anyone give me a tip on what to do?? I would greatly appreciate any help I can get.
thanks,
Debbie
    Sergeant:
    Champion:
  • 317 Answers
With another monitor uninstall anything related to your Sharp LCD, boot up a couple of times, then reinstalled as instructed.
Hope That Helps!
Posted on Dec 11, 2007
3 Suggested Answers
  • 6 Answers
SOURCE: Problem signature: Problem Event
probable memory/ram problem
best guess...........install memory cooler fan/ low price-low wattage-good idea
Posted on Nov 27, 2009
  • 75 Answers
SOURCE: Problem signature: Problem Event Name:
Check the following:
1. If you have installed new devices on your system please remove the device.
2. Update Antivirus and run a full system scan
3. Reinstall Operating System
4. Replace RAM - memory it could be the cause of the problem
Thanks. Cheers!
Posted on Apr 21, 2010
Compaq presario beeps 3 times, won't boot
3 Beeps is usually a RAM issue. Try re-seating your RAM in their slots and rebooting.
Feb 05, 2012 | HP Compaq Presario SR5262NX Desktop PC
I bought a new hp 20" lcd widescreen monitor, but my computer is 6 years old, a compaq presario sr1030nx. as you probably guessed, the images on the monitor look short and fat. my video card spec...
you can change the monitor resolution settings by right clicking anywhere on your desktop, then click properties. Try changing the settings until you find one you like. If you pick a setting that your computer and/or monitor cannot do, it will reset to the last setting after a few seconds. When you find one you like, click ok. You can change these settings anytime you want.
Aug 22, 2011 | Computers & Internet
Error message: Input device is out of range
The PC video resolution is set too high for your monitorto handle. You need to set the PC video resolution to your monitor native resolution, which is 1280 x 1024 @60Hz
Mar 22, 2010 | Compaq FP 7020 17" Flat Panel LCD Monitor
Monitor not working with Geforce 9800 GT
The resolution is set too high for your monitor and you have to throttle it down to a lower number.
Apr 09, 2017 | Dell E151FPp 15" Flat Panel LCD Monitor
Hi,I bought a Compaq TFT7020 LCD monitor and the
If your monitor came with software, install it...if not look for an update on the monitor manufacturer's website...there might be a fix for it there. If that doesn't help then check your video driver (which I would do first) to make sure it's up to date. If not find the correct driver and replace accordingly.
Dec 15, 2009 | Compaq TFT7020 (Carbon, Silver) 17" LCD...
I used CRT monitor now iconect hcl 710 Lsa model lcd monitor no signal disply. an other cpu accept his monitor working good what problem ? My cpu core 2 duo intel prosser 2 gb ram 2ghz
Possibly, the CRT monitor was set to a frequency which is too high for the LCD monitor.
Try booting in Safe Mode (press F8 at boot), then set the video for a lower resolution.
Reboot with the new, lower, resolution.
In Control Panel choose Hardware, then Scan for New Hardware and get the LCD monitor recognized.
Then, from the Desktop properties, you will be able to see all resolutions supported by the monitor.
Nov 03, 2009 | Honeywell Computers & Internet
Lcd lights got dimmer
First check to make sure the power adapter is connected to the laptop properly, if not it runs off the battery and the display is dimmer.
Second check the brightness setting, you can adjust the brightness by pressing the Fn key plus the F7 or F8 keys to adjust the brightness.
If this doesn't work then :-
The problem/fault could be one of several things. Could be the CCFL lamp, the inverter that supplies high voltage to the CCFL lamp or the video card.
The video card cannot be replaced on a laptop, it is part of the motherboard.
To determine if the video card is faulty, connect an external monitor to the external video port on the laptop, power up the monitor first and then the laptop. The video output will switch automatically to the external monitor, if you see a normal Windows image then the video card is OK.
Next, shut down the laptop, disconnect the monitor and power up the laptop. After the laptop boots up look at the LCD screen at a sharp angle and if you see a dim or dark image then the fault is a faulty CCFL lamp or inverter. Most likely the CCFL lamp is faulty, but the inverter is easier to replace.
Check out LCD Parts WEB site for service, parts and DIY info. Use this link.
www.lcdparts.net
Aug 11, 2009 | Compaq Presario M2000 Notebook
Monitor screen turns off new monitor new video card had problem
If you've replaced the monitor with a new one, it's probably not a monitor problem. Try uninstalling the video card and use the motherboard's on-board video. If that's not working, check into getting a new motherboard. If it works fine, check the settings on your video card.
Jul 15, 2009 | Sony SDM-HS73P 17" LCD Monitor
My compaq nx6110 screen goes black and on, why?
This is the issue with the monitor.This is a hardware issue.Please connect the notebook to external monitor and check .If it is working fine then it is the issue with the LCD of notebook If not then this is the issue with the video card.
And ckeck the power cables tooi think this is the issue with the monitor of the notebookAny how you can try to install the latest version of video drivers
Jan 08, 2009 | HP Compaq nx6110 PC Laptop
Compaq Presario 5000 PC Desktop Logo
199 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
