Insect like noise in hp pavilion laptops
There is a constant low insect like noise, in my new hp pavilion dv2500 laptop.its very irritating. its low but stays on all the time of the computer operation. how can i remove it?
  • 1 more comment
  • venumadhav Dec 11, 2007
    actually the sound comes under the key board.There are these three small lights at the left end of the keyboard, One of them for power and the other for battery and the third one i dont know, the third light flickers and it is associated with the very low insect like sound.......
  • cybersoc Aug 02, 2008
    I have the same exact problem with a HP Compaq NX9030. When I remove the battery and still keep the power connected the sound disappears.
  • Anonymous Dec 26, 2008
    I also noticed that an insect like noise starts coming from inside my notebook at regular intervals. This is quite irritating especially if you connect the notebook to some external speakers.
    Sergeant:
    Champion:
  • 317 Answers
Does it happen when you plug in the AC adapter or in any way it's turned on?
Where is the sound coming from? LCD? DVD Drive? Battery?
Please check back with us when you have more info..
Thanks!
Posted on Dec 11, 2007
Hp pavillion dv2500 laptop- LEDs glow, fan noise may be heard briefly, display remains black, and computer fails to startup or boot
This sounds like the possibly infamous Nvidia GPU defect. It is caused by heat, over time the solder fractures and separates from the board. Typically the solution is either repair it (temporary fix) or get a new board and hope for the best.
Jun 03, 2011 | HP Pavilion dv6707us 15.4" Widescreen...
Hi i have problem on my laptop hp pavilion dv2500 pc . my problem is right hinges broken where i buy part and cost
Check out Ebay for used but good parts. You will be pleased with the result!
Hope you get it fixed soon.
Nov 15, 2010 | HP Pavilion dv2500t Notebook
Hi, I have hp pavilion dv2500 laptop. I have display problem.pls help how to rectify it. If i connect exteranl CRT monitor Display is coming . Pls tell me how to disassemble the laptop.
You might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
In this service manual, you will find an illustration of how to disassemble the laptop & replace either the LCD cable or screen inverter board:
http://h10032.www1.hp.com/ctg/Manual/c01295820.pdf
Sep 17, 2010 | HP Pavilion dv2500t Notebook
How to replace motherboard on a hp pavilion laptop
You'll find the maint & service guide at this site http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&product=3747185&lc=en&jumpid=reg_R1002_USEN
Download the HP Pavilion dv2500 and dv2700 Notebook PC - Maintenance and Service Guide 5mb it has everything you need there.
Jul 02, 2010 | HP Pavilion DV2940SE Notebook
Hi' I have HP dv2500. When i restart computer, numlook get on
Start your computer in bios mode (press whichever key gets you into it), look through the bios sections for turn number lock on on startup turn that function off.
That will fix the problem.
Feb 20, 2010 | HP Pavilion DV2500T 14.1" NOTEBOOK LAPTOP...
I could not able to switch on the HP Pavilion dv2500 Laptop. Power is not getting in to the system.
i think it is your motherboard failure
try sending it back to its manufacturer
Nov 26, 2009 | HP Pavilion dv2500t Notebook
Hp dv2500 wont turn on
does the laptop plug in tightly to the power socket
if not the pavilion part to get the system power needs replacement
contact a local technician and state the power adapter plug-in on the motherboard needs replaced
these commonly go bad on pavilions
it should cost you less than 100usd to repair
or rma the laptop if you have warranty coverage left on the hp dv2500
good luck
Sep 28, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Insect buzzing noise.
If you feel the that the HDD or the fan is not making the insect buzzing noise then you maybe right it is the RAM... Open the ram slot and check how many RAMS are in there if there are two then remove the top RAM and keep it aside and start the system to check if the other RAM is making the noise...If there is no sound then check the same RAM which is in the system in the other slot and check if you are getting the noise...Then remove the RAM and then place in the RAM that was kept outside to check if the same happens...If the same happens at a particular slot then the slot is the problem and not the RAM....If one RAM is making a problem then you need to contact HP for the RAM....Please contact me if you need any guidance further down from here
Aug 18, 2009 | HP Pavilion dv9000z Notebook
Clacking noise hard drive on HP Pavilion dv2700 Laptop
Laptop hard drives can be a bit louder than the new desktops and because you're closer may be more noticable. The sound from that youtube is about normal - this video is the sound of the heads crashing - mechanical drive failure. http://www.youtube.com/watch?v=LRj6dP1Pi1Q
Just to be safe - BACKUP your important data and if you don't have the install disks, make a set.
Feb 28, 2008 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
189 people viewed this question
Alun Cox
David Payne
David Payne
