Back to:
Tags:
Copiers
Generic problem for all Copiers
Riso GR3770 Paper Jam, Check paper feed
posted by Manassas on Dec 11, 2007
I got an adhesive label stuck up in the center of my paper feed. Long story, short, I have to disassemble the paper feed to get to where the label had come off. I thought I had all the label off and the machine put back together, when I found after it feeds a sheet of paper, the machine stops (without making an impression on the paper), and slowly ejects the sheet; error message; Paper Jam, Check paper feed.
Any suggestions?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Dec 12, 2007
Not Rated (0)
checkitright
Rank:Wiz Wiz
Rating: 82%, 652 votes
Sounds like you forgot to plug the High voltage transformer or a sensor back
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Riso GR3770 Paper Jam, Check paper feed:
I don't want to Accept this solution
Can you Help with these Copiers problems?
Copiers
SIR, when i am using ADF to photocopy LGL size document...
Ricoh Aficio 1013F Copier
pls help me my Konica 1212 copier is showing F35 and...
Ricoh 6513 Copier
I just got a 6513 copier which I had to dismantle for it...
Konica Minolta DiALTA Di200 Grayscale...
I have a Minolta BizhubDi1610fpI need to know what the...
Toshiba COPIERS - E-STUDIO 650 Copier
My eStudio 650 doesn't print the "even" pages....
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
