Question about Sharp VC-H812U VCR
Can i program the vcr to record one show weekly?
I would like to know if there is anyway i can program this vcr to record the same program weekly without having to put each week in?
How do I set a program to record weekly, can do it 24 hours ahead up to one week.
On the timer record screen, move the cursor left to the 'date' field, and scroll down until the date disappears, and it only shows a day of the week. If it shows 'Mon', your programme will record every Monday.
Mar 06, 2015 | Panasonic DMR-EZ47V DVD Recorder/VCR
I need to record a cable show on to a vcr? how do you do it
I doubt you can do what you are asking. There are technical reasons, based on changes in television technology. Unless you understand the issues/technology, you would not be able to answer my questions.
If the output signal of the Cable TV box was NTSC (without copy protection), then you would be able to record the program on an NTSC VCR. Very unlikely at this time.
I suggest you buy a Digital Video Recorder, like the one Channel Master makes, and record your shows via a TV antenna. Over The Air OTA DVR 16GB Channel Master
Oct 23, 2017 | Sharp VC-A412U VHS VCR
I need help programming vcr to tape show
Since the V9800 has no built-in tuner, your TV set must be set to the channel your show to be taped is on. There is no way to tune it to any particular channel. Now, isn't that convenient?
Feb 16, 2010 | Samsung DVD-V9800 DVD Player/VCR
When i record spanish satalite station the recorded program goes black and white on a regular basis
Well, if the program is showing in color on the TV, then the TV is fine. If she's recording using a VCR, then I presume she doesn't have a cable box? If she doesn't have a cable box and has the cable from the wall going into the VCR and the VCR connected to the TV, then the problem is the VCR if the program appears in color when showing "live" on the TV but black and white when played back on the VCR. Does that make sense? Let me know if you understand what I'm telling you.
Feb 07, 2010 | LG 32LG30 32 in. LCD HDTV
Samsung VR5508 VHS VCR doesn't record a TV program.
I do still need assistance with my VCR problem, however, I do not want to sign up for a plan. I will find someone local to me for this problem.
Thank you anyway.
Jan 10, 2010 | Samsung VR5508 VHS VCR
Can;t record on VCR since Comcast went Digital
I have Dish Network and a DVR and I do not know what I would do without it. I can record 2 shows at once and watch to 2 recorded programs while recording two shows. But getting to your problem... It sounds like the vcr cannot process the digital signal. You could try hooking up the vcr to the rca inputs from the cable box but you will only be able to record whatever channel the cable box is on. Any way you hook them up the programming of the vcr to change channels at different times for different programs probably won't work now. It sounds like Direct TV with two DVRs will solve your recording needs.
Sep 13, 2009 | Toshiba Televison & Video
I MISPLACED MY USER MANUAL
You have to go the main menu and select record times, and day. Make sure you leave your tv set on, and on the channel that you wish to record the program on. You can set the start and stop times a few minutes before and after on the vcr, just to make sure you get the whole program. You can also set the vcr to record this program every day, any day of when ever you wish you can just manually hit "record on the vcr remote. Good luck, let me know how you make out! Thanks
Aug 12, 2009 | Televison & Video
I cannot program the vcr to record i just do not know how to I can play tapes or wath the disk but cannot recore
make sure the tv is on channel 3, and the vcr also on channel 3 -if trying to record from cable or satalite. then make sure tape is rewound all the way. do a test by hitting record on vcr. let it record for a few minutes. rewind it, then just hit play. Dont change any channels until you are ready to record the program of choice. After this test. And recording is successful. Rewind the tape again. And change the channel to your choice. Hit record at time of or go into menu of your vcr and set up a time to record shows.
Jan 04, 2009 | Symphonic WV806 DVD Player/VCR
How do I find the vcr plus coned to enter into my recorder?
Go to the TV Guide web site:
http://www.tvguide.com
You have to choose your location by zip code and if you have cable, satellite, etc. Then you can choose the day of the week and the time and find your show. When you move the mouse over the show a window will pop up a synopsis, click in the middle of the pop up and it will open another page with info about the show. Scroll down a little and on the left hand side it shows VCR+ and Tivo info. I have not used this feature because I don't know if it will let you set something to record say on a weekly basis. I use my unit to record some TV series which play weekly at the same bat time and same bat channel! Plus this unit has 16 timer record slots, twice as many as any VCR and the programing is much more flexible, Good Luck.
Mar 29, 2008 | Lite On LVW-5115GHC+ DVD Recorder
Sharp VC-H812U VCR Logo
60 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
