Question about Brother MFC 8300 Laser Printer
Fax machine i get an error code 76 on the fax mfc 8300
  • Anonymous Mar 04, 2008
    The fax machine keeps giving us an error message that says either error message 76 or error message 78.
  • FBM47 Apr 15, 2008
    I have the Brother MFC 9650 Fax/printer giving error code 76.
    I read "the fuser" is easy to exchange, but what is the fuser (I'm from Holland) and how is it to be replaced?
    FBM
Replace the fuser. Easy job.
Posted on Mar 13, 2008
Error code 78
Usually a result of a sudden power outage. Majority of the time it can be reset without replacement of the fuser. Here is an article I wrote explaining the cause and how to reset the message.
http://www.fortwayneprinterrepair.com/wordpress/2011/09/28/brother-fax-mfc-76777879-fuser-errors/
Dec 06, 2010 | Brother MFC 8300 Laser Printer
Error Code 77 on brother 4100 fax intelifox business class
( 76 Heater harness disconnected or broken. Or heater thermistor harness
disconnected or broken when the power is turned on, the front cover is
opened and closed, or the machine exits from the sleep mode. )
( 77 Power turned off and on at the occurrence of error 76 or 78. )
( 78 Heater thermistor short-circuited. Or heater thermistor harness disconnected
or broken when the machine is on standby. )
Nov 05, 2010 | Brother IntelliFAX 4100 Laser Fax
How do I fix a machine error 78 on my brother MFC 8300?
unfortunately that specific error is pointing to a problem with the thermistor. here is the error code from Brother:78 Heater thermistor harness disconnected or broken. - SOLUTION: REPLACE FUSER UNIT
HERE is a link to other error codes and possible solutions.
Aug 30, 2010 | Brother MFC 8300 Laser Printer
MFC 8300 Laser Printer: do i receive anything after i send a fax?...
Only if you have set the fax options to automatically print a sent item/transmission report. Otherwiase you will receive nothing unless the person or company you sent a fax to decides to fax you back.
May 06, 2010 | Brother MFC 8300 Laser Printer
Will not receive fax Will not send fax Will not copy Has error Message 76 on monitor
Machine error 76 is a bad fuser lamp.Sometimes the machines will give a false code and can be reset. Unplug machine. Hold down the Menu key while powering back up. You should still get a Machine error message. Enter the number 9...The display should change to Maintenance 9 then enter 1. The Machine error will return. Enter 99 and then make a test print. If you get either a machine error 76 or 78 you will need to have service done on your machine to have either the lamp or thermistor replaced, and depending on the usage of the machine, it might not be a bad idea to replace the entire fuser.
May 13, 2009 | Brother IntelliFAX 2800 Laser Fax
Brother MFC 9030
Open the printer and check to see it your fuser is worm up. Do not touch the fuser. If it is cold. you have a problem.
You fuser may be at end of life. Need to be replaced.
cost price of fuser and labor will come close or above cost price of machine. your choice.
Good luck
Jul 24, 2008 | Brother International Plain Paper Fax
Machine Error 76
Machine error 76 is a bad fuser lamp. Machine error 78 is a bad thermistor. Machine error 77 means you hade either a Machine error 76 or Machine error 78 and turned the machine off.
Jan 18, 2008 | Brother IntelliFAX 2800 Laser Fax
How to clear a Machine Error 76
Error 76 is fuser error, you need to change the fuser but first just in case try to reset settings to factory defaults.
Nov 29, 2007 | Brother MFC 9600 All-In-One Laser Printer
Brother MFC 8300 Laser Printer Logo
266 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
