Question about Acer Aspire 5100 Notebook
Acer 5100, Lines throughout screen!!
I have a Acer laptop,,not quite a year old,,just color lines in the display,,is the LCD screen bad already,,very upset!!!
  • banjer23 Dec 12, 2007
    I did hook to external monitor,I get xp boot up,,then black screen,,hard one to figure.
    lines are vertical running through display,,doesnt look good.
  • 24 Answers
If it is looks horizontal lines..there is a posiblity to recover..open the lcd panel and clean it with any spirit lotion then fixit carefully...if it is horizontal line then u have to change the lcd screen.
Posted on Dec 12, 2007
    Sergeant:
    Champion:
  • 306 Answers
Connect to an external monitor, if it works fine then it is the monitor, if not its the video card.
Posted on Dec 11, 2007
Lcd acer al1917w dispay problem
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Repair Kit ACER AL1917W ILPI 031 LCD Monitor Capacitors Not the Entire...
Apr 05, 2014 | Acer Ferrari Computers & Internet
Acer aspire 5738 screen fade
From your description, you may either have a bad cable to the LCD on your laptop or the LCD screen itself is going bad. I would guess a repair shop may charge $100-200 for the parts and labor, but you'll have to check your local area for price estimates.
Since your computer is nearly 3 years old, you may want to consider purchasing a new computer, especially since they start at $300-500 brand new.
May 19, 2017 | Computers & Internet
How to remove white and black leakage screen
Your lcd screen has gone bad and needs to be replaced. To isolate that it's the screen or the video card borrow a monitor from a relative, neighbor, friend or co-worker and plug it into the laptop. If the borrowed screen displays fine without any problems then your original screen is bad. If the borrowed screen shows the white area with black leakage ink as your old monitor then the video card in the computer is bad.
Plug in an external monitor and see if thedisplay shows up on it. It can be any kind of monitor even the old big fat crtmonitors as long as it has a vga cable to connect to your computer's vgaport. If so that proves your video card is ok. The video will showon most systems when you reboot without you having to do anything. Some systemswill require you to hit the FN (Function key) + F1 thru F12. Hold downthe FN key then hit the correct key for displaying on the monitor (F1 thruF12). The correct key will normally have CRT/LCD on it or it will havethe icon of a display.
May 09, 2012 | Acer Aspire One D255-2670
On an Acer Aspire 1640z I get blue screen and lines. lines move with track pad movement. nothing readable. replaced lcd cable and inverter. thinking either lcd or motherboard
Hook it up to an external monitor. If the display is fine on the external then your gpu on the motherboard is fine and the LCD is bad. No external display means bad board. Both cost roughly the same but an LCD is much easier to replace than the board.
Apr 07, 2011 | Acer ASPIRE 1640Z COMPATIBLE LAPTOP LCD...
My acer KAV 60 screen is not working. the hard drive boots and it charges but nothing happens on the screen. It just remains black. I did't drop it or spill liquid on and it's only a year old.
In order to check what is really not functioning. Your laptop have a video port for external monitor which is color blue often at the lower back of your lcd screen or at the side. Plug the CRT or LCD monitor to your vga(video graphics adapter) port to check if your laptop is still functioning. If there is a display on your external monitor that means you have to replace your lcd monitor. If there is no display with external monitor check your memory or ram by unplugging your memory then clean it with a hard eraser the memory pin and then put it back again and turn on your computer to test if already functioning. If the above procedure didn't work you have to bring it in a computer repair shop. Have a good day!
Dec 20, 2010 | Acer Aspire One PC Notebook
My acer lcd monitor of 18.5 inch is going through a problem in which a large number of black rays are appearing and flowing up and down in the screen.... so the lcd displays very badly so wat to do my...
It depends, if the lines are due to physical damage then the warranty is no good if the screen is faulty the your fine. the way to find out is if you apply a little bit of pressure to the line and it gets bigger then its physical, if not get your warranty out
Dec 06, 2010 | Acer Aspire DualCore2GB/160GB PC 18.5"LCD...
Scrolling colored lines on the monitor, overlaying the screen.
You either have extremely screwy drivers, a bad cable or your monitor/panel is shot. Replace any of the above to resolve the issue.
May 29, 2009 | Acer X193W LCD Monitor
Screen showing funny lines and colors.
That would be the screen itself that needs replaced, if you needed the inverter board you screen would be dark and hardly visable
Nov 12, 2008 | Acer Aspire 3100-1405 Notebook
Acer 3000 Screen not working properly
This is most likely either a.) the connection to the LCD is falling out or b.) the screen itself is going bad.
If you feel comfortable to tackle this job you can buy the LCD to replace:
New LCD Screen:
http://www.lcds4less.com/AcerLaptop__acer_aspire_3000_series__laptop-screens.html
Removal Instructions:
http://www.lcds4less.com/PDF/Laptop-LCD-Removal-Instructions.pdf
Be sure to double check with the company to make sure that this screen will work with your notebook.
If you computer is still under warranty or maybe you purchased an extended warranty the manufacturer might cover replacement of the LCD.
hope that helps!
Jan 28, 2008 | Acer Aspire 3000 Notebook
Acer aspire 5050 laptop color lines on screen
you can try pulling the screen apart and re-seating the ribbon cable, but the lcd might be broken, or one of the controller lcd chips might either be cracked or broken. Trying to reseat the lcd ribbon cable might help, but if there is a visible crack in the screen- you will need a new screen.
Nov 24, 2007 | Acer Aspire 5050-3242 Notebook
Acer Aspire 5100 Notebook Logo
636 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
