Question about Brother DCP-8020 Laser Printer
Brother DCP8020 the document feeder has suddenly stopped feeding the pages. i've tried cleaning the roller but it hasn't helped. any solutions?
  • Brother Master
  • 1,113 Answers
Left hinge is broken.
Posted on Dec 12, 2007
  • 1 more comment
  • Soulvisitor
    Soulvisitor Dec 16, 2007
    if you are sure that the hinge aint broke then give me some more info is roller turning, does paper move at all, is a mark left on original from feed roller?
    Pic of hinge that breaks above
    Pic of feed roller assembly that could also be your problem
    Link to purchase parts to suit
  • Soulvisitor
    Soulvisitor Dec 19, 2007
    Push down and on left top rear corner, whilst appling pressure load document, does it feed from doc feeder when pressing copy? If it does Hinge, if it dont feed assy.
  • Soulvisitor
    95 times in 100 of these repairs it is hinge, 3 x feed assy, 1 x doc feed switch, 1 x entire doc assy......!
Brother dcp 7040 prints grey film over the page
someone cheaped out and got the el cheapo paper.
The low quality paper has paper dust on every page....
when the printer feeds this cheap paper thru the machine it drops the dust onto the tonor cartridge rollers and causes the roller to accumulate toner on the roller... this in turn is transfered to the pages being printed.
check your machines operation manual. There may be a clean cycle you can try to run to clean the rollers...
I had to buy a new toner cartridge for mine when this happened.
Apr 17, 2013 | Brother DCP-7040 Laser Multifunction...
Multiple pages feed when printing on hp 7410
  • If the automatic document feeder (ADF) does not pick up any pages at all, the rollers inside the automatic document feeder need to be cleaned.
  • If the automatic document feeder picks up multiple pages instead of single sheets, the separator pad inside the automatic document feeder needs to be cleaned.
SolutionLoad one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.note.pngNOTE:If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water. If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually. Follow the procedures below to remove the face plate from the front of the automatic document feeder, access the pick assembly inside the automatic document feeder, clean the rollers or separator pad, and then reattach the face plate.
Please Click on this link to know more in detail.
Apr 01, 2012 | HP OfficeJet 7410 All-In-One InkJet...
My fax is having a problem feeding pages through the document feeder, it doesn't always grad the page, and if it doesn't get it, it acts like it has a paper jam, what is causing this?
Open the document feeder. Inside you will find a grey feed roller. Cleaning this roller with a cloth dampened with water will help with these paper jams in the document feeder.
Sep 29, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Paper Jam whilst doing a multi page scan
The rollers that pull the paper through could need a cleaning. With general usage these parts do get worn down. By having your printer cleaned by certified technician it would resolve this problem.
May 28, 2010 | Brother MFC-260C All-In-One InkJet Printer
Document Feeder Jamming.
The feed rollers may be worn out and need to be replaced, you can try cleaning the rollers with some alcohol, this may also make it feed better. but if it starts to act up again it might be time for new rollers.
Hope this is of some help.
Apr 30, 2009 | Office Equipment & Supplies
Pages sticking together when transmitting
This is caused by the feed and separator rollers are dirty or worn out. The simplest thing to try is to clean the feed rollers. you will need a cleaning solution, isopropal alcohol works very well. Available at local drugstores. you can approach this one of two ways, you can open up the document feed section and manually clean the rollers or put a few drops of Alcohol in the center of a piece of paper let it soak in a little and pass it through the document feeder, the paper should have a streak on the last half of the page if it made contact with the rollers. For best results do this a couple of times, for better results do both the manual and the pass paper methods.
Hope this is of some assistance.
Apr 20, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Canon PC 1080 F ADF Problem
call canon for instructions on how to clean feed roller and ADF path; otherwise probably need new seperator pad and possibly paper feed roller
Aug 08, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Document Jam Error Message on Brother MFC-8660DN
I had the same problem with a Brother MFC-8460 and called Brother's support line. The solution that worked for me was to lift the top cover where the sheets of paper go through when you fax. On the right of the black rectangluar piece with grey roller there is a slot in the tray with a black lever inside. The black piece was stuck down inside the slot and had to be popped back out. Once it was out I hit the stop button and it was fixed!!
Mar 03, 2008 | Brother MFC-8660DN 5-in-1 Laser...
Scanner excludes front page
This is not the only solution, but this might help.
Put a blank page in as the first page and see if all of your documents scan completely.
You may need to clean the ADF. Try the following:
Cleaning the Automatic Document Feeder
You may need to clean the ADF feed mechanism if your
documents do not feed easily into the ADF, or several feed in at the
same time.
To clean the ADF:
1. Dampen a soft cloth with some isopropyl rubbing alcohol
2. Press the ADF cover release on the top left of the scanner body
to open the Automatic Document Feeder cover.
3. Wipe the feed roller from side to side. Rotate the roller to clean
its entire surface.
4. Wipe the pad from top to bottom. Be careful not to snag the
cloth on the springs on either side of the pad.
5. Close the cover when you’re finished.
NOTE: Please be careful when cleaning the roller. The roller is
designed to rotate in one direction only. As you’re cleaning the
roller, make sure it rotates easily, and continue rotating it in that
direction while wiping it clean. Do NOT force the roller to rotate
in the opposite direction. Forcing the roller to rotate will damage
it, and may cause the scanner to feed pages incorrectly.
Please let me know if this has helped and thank you. Binary Bob
Dec 05, 2007 | Xerox DocuMate 252 Path-Through Scanner
The document feeder keeps trying to feed
You have a bad Document transfer sensor. Sensor is located under the doc. transfer roller.
Nov 15, 2006 | Sharp FO 6600 Plain Paper Laser Fax
Brother DCP-8020 Laser Printer Logo
79 people viewed this question
James Cagle
James Cagle
Jim Keysor
