Question about AOpen AX45-V (91.88I10.004) Motherboard
Hard drive shuts off?? I think.
I have a AX45-v aopen motherboard, p4 chip, ATX-250gu power supply, win XP with 1GB RAM. The problem is my pc won't power up all the time. 1st attempt at powering up, the HDD light and cpu fan turn on, the second attempt, the power light, hdd light and cpu fan turn on, I have to unplug the pc, leave it for 15-30 mins and plug it back it and it will boot up. I have checked my hard drive for errors viruses etc. NONE. I have replace the motherboard, as I was told my a tech that it was the problem but the pc is still behaving this way. I checked all the cards, ram, and componets and everything is tight.
Now the hard drive seems to be shutting off, I think. I think it is the hard drive as my monitor is configured to shut down into sleep mode when there is no signal from the computer, but the fan and lights are still on. The crashes seems random, I checked the systems logs and ran every possible system/program check that I have to check the hard drive and it found nothing wrong so I have come to the conclusion that it is hardware related. Several times when the hard drive has shut off, I can turn the pc on again right away, which contradicts the first problem I had above. Could it be that my power supply is failing to provide the proper power to the computer? Or could it be the hard drive itself?
Thanks for the help
Karen
    Champion:
  • 209 Answers
Replace your power supply, you need to upgrade this to at least 500watts to avoid problem like this, there is no problem with your hard drive its your power supply
Posted on Dec 11, 2007
Do you know what the max memory supported on the AOpen AX45-4D motherboard? Thanks!
From what I can remember the motherboard supports 2GB of ram (1x1GB in each slot).
Regards.
Jan 07, 2011 | AOpen AX45-4D Max Motherboard
I have an ax45-v that wont boot past ram check..ram check says ok but than comp freezes
Change ram bank, clean your ram, try to load windows by pressing F8 key and then in Safe Mode.
Regards;
Hassan
Jul 15, 2009 | AOpen AX45-V (91.88I10.004) Motherboard
P25g motherboard, monitor wont turn over
i think you need to try replace you're ATX power Supply or you need to try remove the other 1 of you`re memory...Thanks
Apr 23, 2009 | PC Chips P25G Motherboard
Will motherboard will support winXP pro
Hi gimondor,
The motherboard really isn't your worry. Windows XP pro requires a 300 megahertz or higher processor. You motherboard can take from 100 to 400 megahertz, so you need to know what your CPU is. If your running an intel P4 chip, and at least 128 mbs of ram, and you have at least 2 gb's of hard drive space left on your hard drive, then you can run XP Pro.
Good Luck,
And please leave a rating based on my solution.
Mark
Apr 06, 2009 | AOpen AX4BS Pro (91.89J10.001) Motherboard
Computer Will Not Boot
It sounds like it could be your processor, how did you test your processor to make sure it worked correctly? Also how manny stick off RAM do you have and the total amount in MB or Gigs.
Jan 22, 2009 | Intel Foxconn Motherboard
Asus p5p800 motherboard
seem power supply fault, because some times, it looks that power going on, it is not giving proper voltage to motherboard. check other power supply.
Oct 16, 2008 | ASUS P5P800-VM Motherboard
Ram upgrade
well u r a women so ax45v has to be thrown away
May 15, 2008 | AOpen AX45-V (91.88I10.004) Motherboard
Installing a new power supply
Those are the cables that connect to the motherboard from the power switch, to the power LED and the hard drive activity LED.
Try following the diagram on the following page to know where to put them in:
http://www.fixya.com/support/p365479-aopen_ax45_v_91_88i10_004_motherboard/manual-16477/page-29
Dec 24, 2007 | AOpen AX45-V (91.88I10.004) Motherboard
Help pc problems???
CHANGE THE POWER SUPPLAY.. BUT FIRTH..
1-UNPLUG HD AND TEST WITH FLOPPY OR CD BOOT DISK
2-UNPLUG YOUR MEDIA ROOM LIKE CD OR DVD AND TEST ONLY WITH FLOPPY BOOT DISK
3-UNPLUG VIDEO CARD AND ALL CARD ON YOUR MOTHERBOARD.. TEST ONLY WITH THE FLOPPY DISK AND ONBOARD VGA.. OR GOOD TESTED VGA CARD.
EXCUSE MY BAD ENGLISH.
CO3OV
CUBA
VICTORES45@YAHOO.ES
Oct 14, 2007 | AOpen AX45-V (91.88I10.004) Motherboard
AOpen AX45-V (91.88I10.004) Motherboard Logo
55 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
