Question about Wacom (PTZ930AC) Graphic Tablet
My trusty old Wacom tablet is dead.
It just quit. No status light... just dead. I've checked the power source, etc. Should I try opening it up to look inside?
It is a VERY old 6x9 tablet -- Model UD-0606-r
  • jrw3 Jan 11, 2009
    I removed the pc power supply to test another system. When reconnected all worked normally except the Wacom Intuos GD-0405_R. No power light. Any ideas welcomed.
This is a year later but I have just had the same problem. It will be a wire broken off the power socket that piggy-backs the 9-pin serial connector. The whole internals have been set in wax which makes it almost impossible to repair.
I require a replacement cable or a wiring diagram for the connector and then I will be able to repair it.
I am trying to see whether it is possible to buy a replacement cable as a spare part
Posted on Jun 09, 2010
    Problem Solver:
  • 6 Answers
First off, Check the warranty on it. If the warranty is up, You should open the thing up and check it out. Look for dust, cut wires, blown fuses, and see if anything is corroded. Get back at me if you find anything.
Posted on Jul 01, 2009
When I'm using Photoshop CS4 with my Wacom Bamboo Fun tablet, the screen tracking for the tablet only works for half the tablet. This happens with everything else as well, not just Photoshop...
Go to Control Panel, and open bamboo properties. There you select the "pen" tab. In the pen tab you will see tracking. Select pen mode and details. You can map the pad there. After mapping pen mode try it in mouse mode as well. Best of luck!
May 28, 2011 | Wacom Bamboo Fun USB Tablet with Cordless...
Wacom tablet stopped working, blue light on.
Since you are running Windows Vista on your PC this is the driver you should have downloaded.
Click Here
Serial cables are not hot swappable. The computer and tablet should be turned off before you plug them in.
Apr 10, 2008 | Wacom (PTZ930AC) Graphic Tablet
Wacom Intuos 3 problems
Hi Bengref
Just talked to WACOM USA about a similar (but not exactly the same) problem with my Intuos 3. One of their procedures was;
go to the ALL Programs directory,
go to the the WACOM TABLET directory
open the WACOM Tablet Properties window
click on the "About" button
while holding down the CTRL key, click on the "Diagnose" button
click on the "recalibrate" button
Another procedure
go to the All Programs Directory
go to the WACOM Tablet Directory
click on the :WACOM Table Preference File Utility"
Under "My Preferences" click on remove
Good Luck
May 19, 2010 | Wacom Intuos3 Graphic Tablet
Tablet quit working. Left for vacation (1 week) came home plugged it in and it no longer worked. WACOM TABLET CTE-440
Had the same problem and just solved it. Very easy. Turn off your computer. Pull the power cable. Wait about 5 minutes. Plug it back in and power it back up. No more USB not working prompt in your device manager and your tablet should be back and running.
Nov 01, 2009 | Wacom Intuos3 Graphic Tablet
Wacom tablet (Model ET-0405-U) Driver?
Wacom tablet drivers can be found at: Driver Update Software for XP Vista 7 8. Used it many times before. have a nice day
Oct 03, 2009 | Wacom Graphire Grape (ET0405UGRAPE)...
Wacom pen does not function
Unfortunately I had the same problem.
Its from moisture in the pen, could be from humidity or something spilling on it. Try searching google for information on how to fix wet electronics. (Im quite sure youre not supposed to use heat)
Sep 16, 2009 | Wacom (EP130EPE) Digital Pen
Dead Zones on Tablet
Yes, you have a hardware problem. The 'dead zones' are known as dead pixels. Click on the link below to contact Wacom for repairs/warranty claim:
Note: If you feel that these dead pixels do not interfere with your tasks then you have the choice to continue working on it.
Sep 11, 2009 | Wacom (PTZ930AC) Graphic Tablet
Wacom serial power to usb connection
If your table has a USB connection and requires a powered USB port, then don't waste your money or time. If it's the other way around and the table is powered from another source, the converter will likely work.
Jul 19, 2008 | Wacom (PTZ930AC) Graphic Tablet
Intuos tablet keeps fading out
If ur wacom has a touch pad for scrolling, i've found that touching it briefly wakes up the wacom.... but apart from that, it is very annoying how it keeps fading off like that.
Apr 11, 2008 | Wacom (PTZ930AC) Graphic Tablet
Serial to usb wacom tablet problem
I just got Vista and it killed my Intuos2 w/serial to usb also, but here's a half solution:
Download Wacom driver 4.78-6 Make sure you remove any other Wacom drivers, tablet, and reboot. Install 4.78-6 driver and select serial port when the choice pops up. Plug in your tablet with the serial to usb adapter, wait a few seconds and click retry. Complete the install and reboot.
Your Wacom tracking should work now, but certain things might not work like pressure sensitivity and you'll get annoying error "reinstall driver" pop-ups.
I think you can aslo buy a PCI-serial card for your computer and skip the serial-usb adapter since Vista doesn't support the adapter for Wacom tablets.. but I'm not sure if there's a working Vista serial Wacom driver either.. or ever will be. The age of XP and Legacy support is at an end my friends.
Dec 03, 2007 | Wacom (PTZ930AC) Graphic Tablet
Wacom (PTZ930AC) Graphic Tablet Logo
954 people viewed this question
Top Wacom Computers & Internet Experts
Level 1 Expert
William F. Bryant Jr
Level 1 Expert
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
