Not enought heat
I have a DeLonghi 6507L Oil Filled Radiator Heater it comes on and runs but it is putting out very little heat? Is there something that i should be checking to replace?
  • alberta43 Sep 11, 2008
    I have a DeLonghi 1025t oil filled radiator heater and even after 5 hours it still does not add a single degree of heat to my living room. I just bought the heater 2 months ago, (on the web) and as it was in the low 60's yesterday turned it on for the first time. It get fairly hot on the top and heat does come out if I put my hand 4 or 5 inches above it but still does nothing to add temperature to the room. HELP........
  • 3 Answers
I have the same heater and it works great in my bedroom (with a door). the room is about 12 x 14. For my living room and dining area I use 2 or 3 oscillating, ceramic, fan forced heaters spaced out.
As you say, logically...since heat rises, the heat comes off the top. Only 3 things that I can think of would make that heater not work: First, a factory defect (it doesn't heat period). Second, if you have it a room that is too large for that size heater. Third, if the room has no doors (such as a living room).
If you have a draft it can work to your advantage. By placing the heater in line with the draft it will actually accelerate the heat exchange process and distribute the heat faster for you.
Posted on Jan 15, 2009
Ew6507l - nowhere near warm enough
only made for 400 to 600 sq feet try Eden pure heater 1500 watts than cover 1000 sq feet the oil fill heater might have a switch 600 to 1500 watt there r usually a high and low to them good luck
Dec 11, 2013 | DeLonghi 6507L Oil Filled Radiator Heater
Hi Our Delonghi Rapido heater has just started leaking oil, maybe a mL or 2 a day. Can this be repaired?
When a compresser leaks oil it is dead. If this is an air/heat unit you are out of luck. If anything I said does not match the facts of your system disregard my comment.
Jul 18, 2011 | DeLonghi 6507L Oil Filled Radiator Heater
I have an oil column heater about two years old, this year it is emitting an adour, is this normal , does the oil get old?
You need to give this heater a good clean with a mild detergent and cloth with it unplugged let it dry for a few hours then try it again. The oil is sealed inside inturn you can't smell this unless it's leaking.
Cheers
May 30, 2009 | DeLonghi 6507L Oil Filled Radiator Heater
I would like to know how much is this heater minimum watts? Model: 6507L
with one switch on its 700 watts, second switch is 800 watts, thats 1500 total. even though a 14-2 wire could support this ...I would recommend a 12-2 wire with a 20 amp breaker
Mar 26, 2009 | DeLonghi 6507L Oil Filled Radiator Heater
Wheel support to heater cracked in half.
I have had the same problem, did you get a solution??? Do I need to buy the foot and the caster?
Jan 02, 2009 | DeLonghi 6507L Oil Filled Radiator Heater
DeLoghi Oil Filled heater
No need to replace. There's a loose wire/connection somewhere. Have someone with good hands open the control box and tighten. I would not suggest using it in the present condition.
Dec 29, 2006 | DeLonghi 6507L Oil Filled Radiator Heater
Heating & Cooling Logo
130 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
