Question about Acer TravelMate 8204WLMi Notebook
Media stuttering and windows startup failure
  1. Ever since I have owned the laptop windows has had trouble launching properly - After logging in to windows there is no welcoming sound and the background then loads with no toolbar or icons, just an empty screen. This does not happen everytime but does occur regularly.
  2. When playing media the audio and video slows down and stutters, especially if the computer is loading other processes at the same time. This problem coincided with me running very low on disc space. I have now transferred data to a different hard drive but I am still suffering with the same problem. I have also done a disc clean up and reduced the number of processes that launch on start up but all to no avail.
  • Anonymous Mar 23, 2008
    I have the same stuttering video and audio problem on an HP laptop that has lots of free disk space and memory.
  • 54 Answers
Hye les_dudis,
How long have you owned this system? Some quick fixes you could try. You have too many services starting up on startup.
Go to Start, Run, and type in msconfig.
Go to the far right tap (startup), disable all, except for your anti-virus. (norton, mcafee) It'll be obvious which one is your antivirus.
Restart, and see if that helps out. If not, try do a system defragmentation.
Start, All programs, accessories, system tools, disk defragmentor. This cleans up your hard drive a bit.
If in the end, these don't help, then if you still have the windows CD, I suggest backing up your info, and swiping the hard drive and installing a fresh windows.
Hope it helps,
Posted on Dec 11, 2007
What is the empowering key for? and how do i know its working?
Launch manager is a piece of software you need to install.
If you don't already own it, then search for it in Google. If it is for corporate use, then contact your IT department or follow the standard procedure for getting the software installed.
Dec 19, 2015 | Acer Aspire 5315-2153 Notebook
After I power on HP Hewlett packard laptop what keys can I use to access startup menu
If you mean BIOS startup menu, DEL or F1
if it's windows startup menu
for XP your computer restarts but before Windows launches, press F8
For Windows 7, follow this tutorial
Need to Start Windows 7 in Safe Mode Here How
For window 8 follow this tutorrial
5 Ways to Boot into Safe Mode in Windows 8 Windows 8 1
If you means something else by startup menu, please be more specific
May 12, 2015 | HP Computers & Internet
Error code 0x0000034
Try this
Press f12 then advanced options, then Automatic repair or other options listed below:
From page 115 of your user manual-
Advanced options
Choosing this option presents you with another set of
System Restore
? System Restore allows you to use a Restore point to
return the computer to a state at which it was performing
properly. Restore points are created:
? When new hardware or software is installed
? Manually by the user
System Image Recovery
Windows® will "Recover" the Operating system using a
specific image provided by the user.
116 If Something Goes Wrong
The Windows® operating system is not working
Automatic Repair
This feature automates the repair process. The Operating
System will automatically look for problems and repair them
if possible.
Command Prompt
The command prompt is a very powerful tool for advanced
Startup Settings
In previous Operating Systems the majority of the options
found on this menu were available by pressing the F8 key
during the Windows® boot process:
? Enable low resolution video mode
Restarts Windows® using your current video driver at low
resolution. This allows you to reset your display settings
in the event they have been improperly set.
? Enable debugging mode
Starts Windows® in an advanced troubleshooting mode
? Enable boot logging
Creates a file that lists all the drivers that are installed
during startup
? Enable Safe Mode
Starts Windows® with a minimal set of drivers and
services. If the computer starts and runs in Safe Mode,
you will know the Operating System is most likely
working properly and that you should look to third-party
applications or drivers for the source of your problem.
? Disable driver signature enforcement
Allows drivers containing improper signatures to be
? Disable early-launch anti-malware protection
Allows drivers to initialize without being measured by the
Anti-malware driver
? Disable automatic restart on system failure
Prevents Windows® from automatically restarting if an
error causes it to fail. Choose this option only if
Windows® is stuck in a loop where it fails, attempts to
restart, and fails again repeatedly.
SOLVED Recovery Your new PC needs to be repaired Boot configuration error...
Feb 15, 2015 | Toshiba Satellite C55T-A5123 Celeron N2820...
When I turn on my laptop it goes to a windows error recovery page and gives me the options to launch startup repair or start windows normally. When I launch the startup repair my screen goes black and only...
Sounds like the Windows Recovery Partition is corrupted or your hard drive may be faulty.
But, first try to boot your system in Safe Mode (press F8 repeatedly as it boots) and choose Safe Mode or Last Known Good.
If it still doesn't boot properly, try the diagnostics to determine if a hardware problem - boot your system and press F 12 (or F2) repeatedly.
Hope this helps.
Jan 11, 2012 | Toshiba Computers & Internet
I cant log on all i hane is ablank screen
all i can suggest is to takeit to a specialist but if there is an option on startup called "launch in windows startup repair mode" do that as that may sort out problems on your laptop or pc
Mar 03, 2010 | Computers & Internet
At startup : PXE-E16 : Media test failure,
Sounds like a disk failure. I use a product called Spinrite that has more times than not brought disk backonline. If it is a hardware (controller board) failure you are looking at getting a new disk. Spinrite is alittle pricey but well worth it if you own multiple PC. It helps with disk health as well.
If you see the disk in Bios I would give spinrite a chance to recover sector.
Jan 03, 2010 | Fujitsu Siemens Computers & Internet
Reboot and select proper boot device or insert boot media
Try inserting your Windows CDROM at startup and look for press any key to boot from cd.
Wait 'til " Welcome to Setup" occurs and press R for repair.
Type Administrator password or just click enter after choosing
(most likely) 1. At windows prompt, type fixboot and after self
repair type exit.
The system is likely encountering a critical error and
theautomatically restart option has been selected in
the startup andrecovery options.
Right click on My Computer and select
Properties/Advanced Tab/Startup and
Recovery/Settings Button.
Under System Failure, uncheck the Automatically Restart
option. Thiswill allow the error to be displayed when
the problem is encountered.
You need to perform some troubleshooting steps to
try and locate exactly where the problem is coming
Good Luck...Nate P.
Jan 11, 2009 | Computers & Internet
Can't 'Launch Startup Repair' when Vista boots on Evesham Laptop
when you restart try to press F11 while booting..check
Jan 05, 2009 | Computers & Internet
My laptop turns on but brings up a blue screen
windows is corrupted reinstall by using windows xp cd
Jul 10, 2008 | Compaq Presario 700 470024-192 Notebook
Media Stuttering
Run your disk defrag after taking off your files. Also, get more ram so the machine doesn't use the hard drive for virtual memory as much.
Jan 01, 2008 | Acer TravelMate 8204WLMi Notebook
Open Questions:
Acer TravelMate 8204WLMi Notebook Logo
47 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
