Lands Phones Logo
Posted on Sep 14, 2009
I cant figure out how to set up speed dial?
I would like to store 10 numbers on my speed dial and i cant figure out how to do it can u help?
Anonymous
Level 1:
  • Contributor 35 Answers
  • Posted on Sep 22, 2009
Anonymous
Contributor
Level 1:
Answers
35
Questions
0
Helped
8107
Points
58
Go to your phone call settings and activate speed dials feature.
Then come back to your phone in normal display mode,press and hold any desired digit e.g 2,3,4,5,6,7 on the key pad and follow the prompt for assigning of phone nos for speed dialing.
I need to set up a number on speed dial and delete one.. i have a brother intellifax 4750e
Storing Speed Dial Numbers
1 Press Menu, 2, 3, 2.
2 Enter a three-digit Speed Dial number, and then press Set.
3 Enter a number (up to 20 digits), and then press Set.
4 Enter a name (or leave it blank), and then press Set.
5 Press Stop/Exit.
Changing One Touch and Speed Dial Numbers
If you try to store a One Touch or Speed Dial number in a location where a
number is already stored, the LCD shows the current name stored at that
location, then prompts you to either
1 Press 1 to change the number, or press 2 to exit without changing it.
2 Enter a new number and then press Set.
If you want to erase the number, press Clear when the cursor is to the left of the
digits.
If you want to change a digit, use left arrow or right arrow to position the cursor under the digit
you want to change, then type over it.
3 Follow the directions beginning at Step 4 for Storing One Touch Numbers or
Storing Speed Dial Numbers.
2helpful
We lost our manual and I am trying to reload our speed dial numbers. I have tried everything but can't seem to figure it out. Help?
1 Press Menu/Set, 2, 3, 1.
2 Press the One Touch key where you want to store a number.
The LCD shows the location you selected.
3 Enter a number (up to 20 digits), and then press Menu/Set. If you want to enter
a pause in the dialing sequence (for example, to wait for an "outside line"), press
Redial/Pause as you're entering digits. A dash appears on the LCD. Pressing
Redial/Pause enters a 3.5 second pause when the number is dialed.
4 Use the dial pad to then enter the name (up to 15 characters), and then press
Menu/Set. You can use the chart on page 4-2 to help you enter letters-OR-To store the number without a name,
press Menu/Set.
5 Return to Step 2 to store another One Touch number-OR-Press Stop/Exit.
When you dial an auto dial number, the LCD shows the name you've stored, or,
if you haven't stored a name, the number you've stored.
How to program speed dial for various customers
1) To program a personal speed dial number, leave the handset on-hook. Press ALM/SD followed by the DSS button where you want to store the number. Dial the telephone number to save, up to 30 digits (press HOLD to insert a 3-second pause or MSG in insert a hookflash). Press ALM/SD to store the number.
2) To dial a speed dial number, select an outside line. Press the ALM/SD button. Dial the desired speed dial code 10-98 (system speed dial) OR press the desired speed dial button on your phone (personal speed dial).
3) System speed dial numbers may only be programmed by the system administrator.
How to specify fax machine to dial '9' before fax number?
Hello ilay,
This procedure is from the Brother FAX-4100e FAQ link:
Storing Speed Dial numbers:
You can store Speed Dial locations on your machine(*). Once you have programmed the Speed Dial number on your machine, you can dial the number by pressing Search/Speed Dial, #(Pound Sign), the Speed Dial number, and then Fax Start.
*The number of locations you can store varies by machines. Please refer to the User's Guide for your machine. The latest User's Guide is available in the Manuals section.
To store Speed Dial numbers follow the steps listed below:
1. Press Menu.
2. Press the left or right arrow key to select Fax and press Set.
3. Press the left or right arrow key to select Set Auto Dial or Set Quick Dial, and press Set.
4. Press the left or right arrow key to select Speed-Dial and press Set.
5. Use the dial pad to enter the location (Speed Dial number) where you wish to store the number and press Set.
6. Enter the number you want to store (up to 20 digits) and press Set.
Note:
If you want to enter a pause in the dialing sequence (to wait for an outside line, for example), press Redial/Pause as you're entering digits. Pressing Redial/Pause enters a 3.5-second pause when the number is dialed, and a dash appears on the screen. If you need a pause longer than 3.5 seconds you can press Redial/Pause as many times as needed.
7. Use the dial pad to enter the name or company name (up to 15 characters) and press Set.
If you want to store the number without a name, just press Set.
8. Return to STEP 5 to store another Speed Dial number or press Stop/Exit to exit the menu.
[Here's the web address for the Brother FAX-4100e FAQ]
http://welcome.solutions.brother.com/BSC/Public/Templates/FaqEndPage.aspx?NRMODE=Published&NRNODEGUID={30FA9470-D303-4B5B-8BDC-89B1CBA491AE}&NRORIGINALURL=%2fBSC%2fpublic%2fus%2fus%2fen%2ffaq%2ffaq%2f000000%2f002000%2f000004%2ffaq002004_010.html%3freg%3dus%26c%3dus%26lang%3den%26prod%3dfax4100_us&NRCACHEHINT=NoModifyGuest&prod=fax4100_us%C2%AE=us&c=us&lang=en#one_7
[Here's a link to the FAX-4100e users guide]
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002079/FAX4100e_UsaEngUsr.pdf
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
5helpful
How to enter phone numbers into the memory/speed dial?
The manual from the GE web site is here:
http://www.home-electronics.net/ge/pc/IB/29267GE3_IB.pdf
It's a pretty straightforward process, Pick up the handset press STORE a location (0-9) STORE dial the number STORE
With only 10 storable numbers it's pretty thin, but you also have the last 50 CID numbers to dial. If you live in an area with more than one local area code (overlays) and mixed 10 digit dialing, it looks like you may have some programming to do to make it dial CID numbers properly.
Carl
9helpful
2answers
How to set up Speed Dial on a Uniden phone?
My Mom had this same problem.   I found these instructions on Uniden's website (uniden.com) under the "Owner Manuel" section.
Here you go - good luck!
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers (up to 20 digits each) in the speed dial
memory. To store number in memory:
1) When the phone is in standby, press [memory]. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number.
 (To enter a 2-second pause between numbers, press [redial/
pause]. Each pause counts as a digit. )
3) Press [memory] again.
4) Select the speed dial location where you would like to store the
number ( [0] to [9] ). You will hear a confirmation tone indicating
that the number has been stored.
NOTE:
• Storing a number to a speed dial location will
overwrite the any previously stored number without
warning.
• When storing numbers into memory and the handset is idle (i.e., no key is
pressed) for more than 0 seconds, it will beep rapidly, and then the phone
will return to standby.
Dialing a Stored Number
1) When the phone is in standby, press [talk], and listen for a dial tone.
2) Press [memory] and enter the speed dial entry ([0] – [9]) that has the stored number
you want to dial. (If you enter a digit that does not contain a stored number, the
handset will beep rapidly, and the phone will not dial.)
Chain Dialing
The speed dial memory is not limited to phone numbers. You can store any number (up
to 20 digits) that you need to enter once your call connects. This is referred to as Chain
Dialing. An example is a frequently refilled prescription number. Store your pharmacy
phone number in one speed dial and your most frequently refilled prescription number
as another speed dial. To use, once you ring your pharmacy's automated prescription
line, simply press [memory] and the speed dial number where you stored your account
number.
Erasing a Stored Number from Memory
1) With the phone in standby, press [memory] twice.
2) Press the number of the speed dial entry. A tone indicates that the stored number is
erased from memory.
4helpful
2answers
Speed dial access
It's easier if you have access to the database to put in names with the numbers, but in the simplest sense, you can take a piece of paper, write down locations, and start entering numbers.
PROG
They are added in sytsem speed dial from the first extension or one designated as the manager's phone. PROG **1234 gets you into programming and 001 is the system speed dial area. With a combination of NEXT's and ENTER, you can be looking at SD 000 (ie PROG **1234 NEXT NEXT ENTER NEXT) and you're ready to enter a speed dial in bin 000. The complete number starts with an access code (9) plus the number as you would dial it. For example 918005551212 ENTER puts that number in bin 000. NEXT will step to 001.
USE
Press INTERCOM or select a line and press AUTODIAL and dial the 3 digit code. If your installer was lazy, you will have a problem as "9" selects the highest line in a trunk group, one that you might not have. In that case, he'll either have to program the system properly, or you will always have to pre-select a line to use speed dial.
Notice that this is just hte instructions for SYSTEM speed dial. I guessed that it was what you're looking for. Personal speed dial is a different set of instructions and it could be either under a button or in your 10 or 100 number personal directory (so that's where the 2 digit SD's went :-))
Anyway, if you need those instructions and can't find them in the user manual, please post back.
Carl
17helpful
Uniden power max 5.8 speed dial
Press and hold a number key (0-9) associated with the speed dial until the phone number appears, and then press talk/flash or speaker on the handset or speaker on the base. The number stored in the speed dial is dialed.
Speed dialing
There are two types of speed dial and the programming varies with the system you have.
System speed dial is programmed from the operator or manager's phone or PC and they reside in system program 001.
Personal speed dial numbers reside in my system at location 10.
You can try PROG 10 and see what the display says.
The user manual has instructrions for programming personal speed dials.
Carl
2answers
Storing numbers in memory
1) Pick up the handset and press the STORE button
2) Dial in the number you wish to store
3) Press the STORE button again to indicate that you have completed the number
4) Press the location where you want to store the number (i.e. 1, 2, …9, or 0)
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
