Question about Bunn Coffee Makers & Espresso Machines
Bunn coffee maker
I have a bunn commercial/ home stainless steel coffee maker model LX00001005 lx 04400-0001 which quit working. The switch appeared to be worn out so I replaced it but while the warmer burner started to work again the heating element did not, i.e. the water would not get hot. Any ideas.
  • 60 Answers
SOURCE: my bunn coffee maker CWTF-15 21604-0001
It sound like you are either missing the sprayhead or the temperature isn't hot enough. Check first to see if the sprayhead is there. It fits under the brew basket and looks like a little shower head - it's round and has usually five or six little holes in it. If it is missing your coffee will be weak due to the water not being spread across all of the grounds evenly.
The other thing to check is the temperature. Depending upon where you live the water should be between 185F - 200F. If the water is below that temperature the coffee may look like tea.
Posted on Feb 01, 2008
  • 131 Answers
SOURCE: bunn commercial coffee maker plug overheats, no hot water
Most likely this is your heating element, but it could also be your main thermostat
Posted on Feb 13, 2009
  • 508 Answers
SOURCE: bunn automatic coffee maker will only make half a
try cleaning with white vinegar(50/50 with water)may have calcium deposits supposed to clean once a month-let it soak overnight use coofee filter to catch deposits run numerous times then throughly rinse with water!!! :)
Posted on Jul 04, 2009
NewsView
  • 40 Answers
SOURCE: BUNN VPR commercial coffee pot, not flowing in a
The unit may simply need to be decalcified. You may need to use a toothpick to remove blockages in the spray head, and there may be a flexible wire to assist in removing blockages behind the spray head leading to the tank (refer to owner's guide). If these measures fail it may be a problem with the thermostat/electrical system. For support go to:
http://www.bunnomatic.com
Posted on Mar 05, 2010
  • 189 Answers
SOURCE: I have a Bunn NHB
If you will call customer service at 800-352-2866 with the model and date code, we will be happy to assist you with this issue.
Posted on Jan 18, 2011
I am trying for first time to start it. I put 2 pots of water in unit and checked the water jet , but it will not push water into the glass pot.
Did you plug it in and switch it on?
Do you really have a Bunn commercial coffee maker?
Did you read the instructions?
Dec 25, 2015 | Bunn 10 Cup Home Coffee Brewer
Have questions about bunn coffee makers
inside they are the same, the 'plastic on the outside' one is no doubt much less expensive, and will clean easier, the stainless will look more handsome, and fancy
Mar 07, 2013 | Bunn Coffee Makers & Espresso Machines
My Bunn BX-B just stopped working. The power is on, but the water will not heat, and the hotplate will not turn on? Is there a reset switch or some way I can trouble shoot this? Thanks,
The problem of the coffee maker is simply from the thermostat regulator. It is bad and need to be replaced. To fix this is quite expensive, and will require a professional touch from an expert that will be able to carefully disassemble am reassemble the components for you as the parts are quite sensitive to deal with.
There is no reset switch for this coffee maker, you just have to replace the thermostat before it can start working fine once again.
Hope this was helpful.
Goodluck
Elect_Comp
Jun 29, 2011 | Bunn BT10B Coffee Maker
I have a commerical Bunn coffee maker. I ran vinegar to clean it out. It dripped very slow. Now, I get a 6 minute pot, the coffee is 180 degrees, but the coffee is very weak! What is up?
Coffee maker is not pre-heating the water.The brew cycle should take about two minutes, and the coffee should be 200°F when it comes out, that is why it's weak. To clarify, is it a commercial model, or a home model (like the one pictured)? Home models will have a 'vacation switch' on the side of the unit that needs to be on to get the water pre-heated properly.
Jan 19, 2011 | Bunn 10 Cup Home Coffee Brewer
Need the back switch that turns the pot on to brew(carlingswitch) for model NHB
For Service Contact:
Bunn-O-Matic (800) 352-2866
They call it "Vacation Switch"
I work on commercial equipment (including BUNN), and they don't use any names like this one in the commercial line.
Jan 14, 2011 | Bunn NHB Coffee Maker
My Bunn BX-B coffee maker wont turn on, no light no nothing. Is there a reset switch, or fuse somewhere in it?
Did you check the switch on the side of the machine(vacation switch) to make sure there is orange/red showing? If it is, please give us a call with the model and code date and we can further assist you. Customer Service # is 800-352-2866.
Nov 11, 2010 | Bunn 10 Cup Home Coffee Brewer
How do you use/work the bunn-o-matic?
Do you have a commercial machine or home model? If you will call customer service at 800-352-2866 we will be able to assist you.
Jun 22, 2010 | Bunn RL Coffee Maker
How do you clean the stainless steel bunn coffeemaker ?
Use DeBruce Polish, we use DeBruce Polish on all of our stainless steel. DeBruce Polish also works on glass cook tops. We get DeBruce Polish at debrucepolish.com.
Apr 07, 2010 | Bunn NHB Coffee Maker
Leaking non commercial Bunn 12 cup coffee maker.
I will be happy to assist you with this issue if you would provide your model and date code which are located on the bottom of the unit.
Dec 30, 2009 | Bunn 10 Cup Home Coffee Brewer
My 10 cup Bunn coffee maker leaks from the top of the water resevoir, from the right top side and from the back top. It looses aprox. 2 cups of water onto my counter while brewing. What has happened to...
I have the same problem and I took the coffee maker apart to find out why. It has to do with a leak on a fitting. On mine I found that the fitting where the hole in the black plastic that the water flows through to get into the stainless steel tank needed to be repaired with some silicone sealant to fix the leak. Still making some coffee!
Oct 09, 2009 | Bunn 10 Cup Home Coffee Brewer
Coffee Makers & Espresso Machines Logo
74 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
evans_lloyd
Level 1 Expert
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
