Symphonic WF32L6 No power. Worked fine last night. No power this morning.
  • 5 more comments
  • drjay121 Dec 30, 2007
    Same problem here. I have a WF32L6 and can't get the power light to come on all of a sudden. Any suggestions?
  • Anonymous Feb 18, 2008
    Same problem wife turned it off last night and it will not power up today.
  • boysrus May 02, 2008
    wf32l6 worked fine a few days ago. But today it will not turn on. The power outlet works fine, but the power indicator light does not come on. I'll guess it is a bad power supply - or blown fuse inside the unit. any solutions?
  • Anonymous Jun 10, 2008
    same problem here. Opened the unit up and found a blown fuse right next to the incoming power cord. Was happy as I thought this would be a cheap fix, however when I replaced the fuse and plugged it back it, it instantly blew again. There must be a short somewhere?
  • Anonymous Aug 17, 2008
    My tv just stoped this moring. Worked fine last night for the hubby. It turns on, the goes straight into standby mode. Anyone get it fixed?
  • antbo1234 Dec 18, 2008
    What the heck is a diode?
  • Anonymous Jan 28, 2009
    same problem with the blown fuse here:( TV worked fine last night, today it does not. My fuse was also blown, I replaced it and it blew right away. I may have to look into the diodes myself. I may need a little advice on what readings I should be getting. Although I have a pretty good understaning of electricty, I have no experience with electronics.
Bbailey240sx,
how did you open the box up? I tried lots of ways last night, and I can't get the thing to open!
-Blaz
Posted on Oct 21, 2008
Symphonic 32" plasma one year old-volume fades completely in and out for 15-20 minutes at the time.
Posted on Sep 24, 2008
I had the exact same issue . The TV literally stopped working 2 year after the manufacture date. Since I had nothing to loose I opened it up and found that the fuse had blown. I put a new one in and if blew also. I work with some electrical engineers and they said first to look at the Diodes. They lent me their diode checker, and the first diode I checked was bad. I'm sorry I don't have any pictures but it was one of the diodes closest to the where the power cord connects to the board. I took the board out and brought it to work and had the electrical guys pull the diode. I got a replacement diode, (.20 cents or so) and had them solder it back in. The Diode number is IN540, you can buy these online, DIGIKEY.COM is one place too look. I took it home put everything back together, including a new fuse and BOOM it fired right up. I did this about 2 weeks ago and it is still going strong, I should probably knock on wood right about now. If you have an questions please feel free to ask. I am not a TV repair guy, just someone who got lucky. Good luck!
Posted on Oct 13, 2008
  • bbailey240sx Oct 22, 2008
    Blaz,
    Do you mean the back casing of the TV? If so, I had to take out all of the screws around the entire casing of the TV. Most of them are along the edge. Make sure they are all loose before pulling off the casing. Watch the the power button panel, it will stick to the casing when you pull it off.
I have a symphonic model wf32l6 tv that has a green tint on the picture.
White balance adjustment should be done. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 08, 2014 | Symphonic Televison & Video
My Hitecker 32 inch TV suddenly will not show any inputs other than TV. Worked fine last night. Doesn't this morning. No power surges that are known about overnight.
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 01, 2014 | Televison & Video
Cant get the power to turn on,worked fine last night, it got unplugged, this morning plugged in, won't turn on and the power button just flashse
Flashing is either an error code or the set trying to boot up--some of the Mitsubishi sets if power removed will blink for a minute and then stop--then the set can be turned on.
a model number?
Apr 28, 2012 | Mitsubishi Televison & Video
Symphonic WF32L6 on power up power light flashes about twice per second for 20 seconds. Screen displays ''DIGITAL TELEVISION'' then power light flashes about 4 times per second for perhaps 10 seconds more,...
Ur Main Tuner signal board is dead.Replaced this board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish Main Tuner Signal board for the replacement.
Mar 08, 2010 | Televison & Video
Air worked fine all last night and his morning.
if the air comes on for a short time and then turns off for 15-30 minutes, the overload protection inside the compressor is shutting down to protect the compressor. this can be caused by blocked supply or return vents, improper charge, bad valves in the compressor, and a multitude of other things. the problem will have to be corrected first.
Dec 14, 2009 | Heating & Cooling
Tv wont turn on worked fine last night
If there is no power at all, then the problem is likely the power supply unit.
The PSU must be tested, then eventually replaced.
May 30, 2009 | Spectroniq PLTV3250 32 in. LCD TV
Tv won't turn on no light in front
I had the exact same issue . The TV literally stopped working 2 year after the manufacture date. Since I had nothing to loose I opened it up and found that the fuse had blown. I put a new one in and if blew also. I work with some electrical engineers and they said first to look at the Diodesmag-glass_10x10.gif. They lent me their diode checker, and the first diode I checked was bad. I'm sorry I don't have any pictures but it was one of the diodes closest to the where the power cord connects to the board. I took the board out and brought it to work and had the electrical guys pull the diode. I got a replacement diode, (.20 cents or so) and had them solder it back in. The Diode number is IN540, you can buy these online, DIGIKEY.COM is one place too look. I took it home put everything back together, including a new fuse and BOOM it fired right up. I did this about a mounth ago and it is still going strong, I should probably knock on wood right about now. If you have an questions please feel free to ask. I am not a TV repair guy, just someone who got lucky. Good luck!
Feb 13, 2008 | Televison & Video
Remote codes for Emerson Symphonic tv?
I have a symphonic tv and a emerson universal remote cannot find code anywhere for this tv???? anyone know what to do cheap tv
Dec 22, 2007 | Televison & Video
Televison & Video Logo
1,135 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
