Question about Frigidaire 24 in. PLD2850 Built-in Dishwasher
Dishwasher suddenly started leaking on floor?!
Our Dishwasher just started leaking all over the floor during a cycle and is getting progressively worse, which is when my wife decided to tell me (typical!!).
I don't even know where to begin looking when there is no clear view around the bottom to see where the water is coming from.
You guys have a 100% track record for me on here, please help try and keep that record in tact.
  • 4 more comments
  • Griles Dec 21, 2007
    one of the 4 bolts that connect on the bottom ouside and hold the round tube at the bottom inside is cracked and comes off easily causing a significant leak. How do I replace that?
  • baldy1978 Feb 20, 2008
    removed the unit from under the cabinet and found the drain hose from the upper rack was leeking at the clamp on the pump motor. the plastic hose and plastic pipe on the pump motor don't seem to meet up well. I need to know what I can put on the two diffrent types of plastic.
  • Anonymous Oct 02, 2008
    I have the same problem, I was able to isolate the problem the first time it happenned, but I cannot find the part number. I went to Frigidaire.com and they do not have my model listed....
  • Falines Jan 09, 2009
    I have a GE dishwasher and all of a sudden it started leaking at first it was a small amount that I could catch with a towel...now all of the water seems to come out on the floor. There is water collected at the bottom as well and I can't see where the problem may be
  • mchinge Feb 01, 2009
    We have a Jenn Air dishwasher which started leaking every three or four turns. Today we cleaned the gaskets, around the door, etc. It was just leaking a drop or two. Then I removed the bottom rack and added Jet Dry and started the washer. Water began gushing out the front right side-and started gathering under the unit-which it never did before. HELP The model is DW730B. any ideas?? John
  • unclea May 11, 2010
    how old is it,and how suon the it start
Can silicone be used in addition to new nuts? i would think that might help seal that opening to the heating element. thoughts?
Posted on Sep 22, 2008
You can replace the nuts. I went to fridgidaire.com and found the part number, then called around to a few appliance parts stores. Peice of cake, and only cost a few bucks. I don't trust those nuts because they crack, apparently, but the threading is super wierd so I don't see an alternative but to replace it with the same nut.
Posted on Feb 22, 2008
Does anyone know what to do about the leeking cause im not a expert on dish washers it picks it time to pack up on me lol
Posted on Dec 20, 2009
Kenmore uses the same wierd nuts and both of mine split. I ordered what I thought was a package of 2 but ended up only being one. Now waiting for the other. $3 for the part $7 for shipping and not available at Sears parts stores. Back to dishpan hands for now.
Posted on Nov 14, 2008
I have leaking from the screws holding the heating element of the same model dishwasher. The part is called heater nuts. I don't know if I need to replace the entire heating element assembly or just replace the nuts.
Any help is appreciated.
  • Michimi Jan 03, 2011
    Hey guys, I know this is too late to help the original poster, but just in case there's others out there who are looking:
    I also had a newer Frigidaire dishwasher with a leak at one of the heating element bolts that had corroded. After paying a plumber $120 to tell me the dishwasher was kaputz, I decided I'd try a little home repair before forking over another fortune for a technician or parts or worse a new dishwasher. I found this great epoxy (if interested it was Pow_R Stick Steel Hard 15 minute repair epoxy putty) which was heat resistant, drinking water safe and could cure even under water. I just used a small amount and sealed around the base of the hole by the heating element.
    I'm not a professional and a technician might scold me for my patch-work, but there's no leak so far! And it only cost me $4 Cdn. If I could have easily found a replacement nut I might have tried this first. Hope this helps!
Some water is leaking under the dishwasher and on the kitchen floor during the end of the wash cycle.
Does it leak during pump-out only?
If so , must be drain hose .To see everything,remove kick plate to isolate leak. Check hose connections. Fill and drain and observe.Or run a whole cycle with kick plate off to find leak.
Good luck
Aug 15, 2011 | Kenmore 24 in. 15689 Built-in Dishwasher
Kitchenaid dishwasher is leaking
depends. take the lower panels off the dishwasher below the door right at the floor. Once this is done you will need a flashlight. If possible lay on the floor with the flashlight and activate the dishwasher. Look for the leak at that point. If it starts leaking in the drain cycle then the impeller is leaking and will need to be replaced. These can be a little pricey so take the model and serial numbers and call an appliance parts house for the cost and it is a little bit of a hassel to replace so only you will know if you want to tackle it yourself or buy a new dishwasher. If is leaking during the rinse cycle then the gasket at the base if the washer (where the motor connects to the dishwasher itself) has gone bad and this is a bugger bear to repair. So it's up to you if you want to repair or replace.
Good luck on repairs Hope I helped you some
Dr Berry
Feb 17, 2010 | Dishwashers
Small leak during fill cycle
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
m,n,.vn
Jan 05, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
Roper Dishwasher leaks from float or float switch onto floor
you could be usiong way to mauch soap try filling only one of the soap trays or even try doing one wash without any soap at all
this unit tends to do this if you have to much soap in the unit left over from the last load...
beyond that your machine is proibaly tilted to far forward you can lift it, by lowering the front legs begind the toekick
Oct 25, 2009 | Roper 24 in. RUD4000M Built-in Dishwasher
LG dishwasher is dripping water from vent onto floor
Good that it is working. Recommend you keep a lose eye on the vent on the bottom of the door panel. This model will probably begin leaking again if it has not been retrofit with a kit that LG developed.
Please open a new problem when it starts to leak and please provide the Model and serial number when you do. Good Luck!
Mar 24, 2009 | LG LDF6810ST Stainless Steel Built-in...
Kitchenaid dishwasher makes a crunching sound during rinse cycle
Sounds like a bearing in the pump is going. This would cause a leak be careful leak will get worst.
Sep 18, 2017 | KitchenAid 24 in. KUDS02FRSS Stainless...
Leaking kenmore dishwasher
Sounds like it the inlet water hose need tightening.
Jan 10, 2009 | Kenmore 15129 Built-in Dishwasher
Dishwasher is leaking on the floor during wash cycle
If this is a new dishwasher, then I suggest you call in a warranty issue on this one.
Nov 26, 2007 | Kenmore 24 in. 16259 / 16254 / 16252...
Leaking water on floor during drain cycle
First the source of the leak needs to be identified. pull the machine out from under the counter and remove the left side panel exposing the blue float assembly. Turn the machine on and observe the fill cycle. if water comes out anywhere on the fill mechanism then the inlet valve needs to be replaced. once the machine has filled and begun to cycle cancel the program and drain the unit. observe closly where the leak is happening. a leak during drain usually indicated a leaking drain hose.
Feb 05, 2007 | Bosch SHU9915UC Dishwasher
Frigidaire 24 in. PLD2850 Built-in Dishwasher Logo
1,502 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
